Question about Troy Garden
Troy bilt Bronco riding lawnmower brake stuck. Won't move.
  • Troy Master
  • 1,169 Answers
Sounds like the brake caliper pins are corroded in place causing be stuck in the engaged position. The caliper needs to removed cleaned and the pins replaced
Posted on Apr 16, 2015
tmandink
  • 30 Answers
SOURCE: my troy bilt riding mower bogs down and dies after
safety switch on brake is bad
Posted on Jun 26, 2009
  • 62 Answers
SOURCE: Troy-bilt bronco riding lawn mower choke problem
Check your air cleaner...then check fuel line from pump. Pull fuel line off carb make sure fuel is present. :)
Posted on Sep 07, 2009
e-Guru
  • 3917 Answers
SOURCE: Deck belt broken, l need
You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic.
Also you can check this link to download the diagram:-
http://www.seapyramid.net/rt/belt-diagram-troy-bilt-riding-lawnmower/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 20, 2011
  • 407 Answers
SOURCE: After replacing drive belt, [954-0467],
The new belt is too tight.Look for an adjustment on the control lever or tension pulley.If that wont fix it.Remove the belt and take it to a NAPA.They can make you a new belt just 1/8 inch longer.I have had to do that with an old mower I had.
Thanks for using Fix Ya,I hope this helps.
Posted on Jun 03, 2011
  • 6468 Answers
SOURCE: I have a Troy bilt riding mower that won't pull. Model #3774513AJ609G766 but don't have a manual. It runs great but just won't pull at all. Replaced the belt, still no luck. Can someon
is the release lever on the rear of the tractor in the position to push it around?
Posted on Jun 05, 2012
Troy-bilt bronco riding mower will not travel.
Possibly need to be adjusted the pedal tensioner.
Good luck
Mai
Feb 05, 2017 | Troy-Bilt Garden
Where can I get all three belt diagrams for a troy built bronco riding lawn tractor model# 13AV67KG
Troy Bilt Deck belt Replacement - YouTube
? 11:46
www.youtube.com/watch?v=w3SrErGTyoY
Apr 1, 2014 - Uploaded by Murray Mayhem
I got a good one troy bilt bronco having problems finding the right deck belt for it. I use the model number under the seat but they are too long ..
Jul 09, 2015 | Troy Garden
Troy bilt Bronco, brake stuck. Won't allow it to move either forward or reverse
Brake caliper pins are frozen in place. Requires dis-assembly, cleaning, new pins as old ones are probably rusted, and re-assembly. Don't lose or forget to put the flat metal plate between the pins and the brake pad. If corrode beyond repair replace it.
Apr 15, 2015 | Troy Garden
Where are the grease fittings ona Troy built riding Lawnmower that has a19hp Koehler engine and the mower is called bronco
There are only 4 I know of inside the 2 front wheels on the axle and 2 on the steering knuckles.. you may have some on the deck spindles but most of them are sealed now days
Apr 24, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
I have a riding lawnmower. Troy-Bilt Bronco. It will not start,no noise,Just put a new Battery in.Where is the fuse located?
Sometimes the fuse is located off of the starter it would be an inline fuse like half turn clip or maybe under your seat. Good Luck...
Aug 24, 2011 | Garden
Deck belt broken, l need a diagram to replace new belt on a Troy bilt riding lawnmower, 42 " cut 20 Hp, model # 13AP60TG563. Thanks
May 20, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
check the battery i.e. load test it they dont last long,most of 2 seasons,then if this is o.k. clean all terminals as any corrosion will cause this also and make sure all connections are tight,it doesn't hurt even if theres no corrosion to loosen and re-tighten all connections
Apr 09, 2010 | Garden
Sep 07, 2009 | Garden
Garden Logo
241 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
