Question about Troy Garden
Troy bilt Bronco, brake stuck. Won't allow it to move either forward or reverse
  • Troy Master
  • 1,169 Answers
Brake caliper pins are frozen in place. Requires dis-assembly, cleaning, new pins as old ones are probably rusted, and re-assembly. Don't lose or forget to put the flat metal plate between the pins and the brake pad. If corrode beyond repair replace it.
Posted on Apr 15, 2015
Troy bilt Bronco riding lawnmower brake stuck. Won't move.
Sounds like the brake caliper pins are corroded in place causing be stuck in the engaged position. The caliper needs to removed cleaned and the pins replaced
Apr 15, 2015 | Troy Garden
Troy-Bilt Horse XP, Model 13bx79kt011 - Won't Move
You need to check the belt to the hydro units is connected properly and is tentioned and not slipping in the pilleys
May 31, 2013 | Garden
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
Tiller works in reverce won't go in forward drive tines will engage but does not have power in forward .
Go to smalleng.com and watch vid on how to adjust valves. It's a great place to start. Good Luck...
Aug 16, 2011 | Mtd Troy-Bilt Bronco OHV Tiller
Belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Apr 02, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt ride-on mower will not move in either fwd or reverse
Is the parking brake on? Or if it's a hydrostatic (automatic) there is a release lever to push the unit around when it isn't running. Most of those releases are on the back of the machine, and you just push it in for drive and pull it out to push.
Was this helpful?
yes
no
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
95 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
