Question about Hitachi Televison & Video
Hitachi tv L19a105 humming from speakers and earphone jack
3 Suggested Answers
kerguney
  • 577 Answers
SOURCE: want to connect pc speakers
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Posted on Jun 23, 2011
  • 44896 Answers
SOURCE: Hi my hitachi p42ho1au has no sound out of the tv
I am not familiar with your TV but I know my TV has a setup option that allows use of the internal speakers or an external amplifier.
Posted on Oct 19, 2012
When plugging in a wireless headphone in the audio output the tv's speakers shut down.How can I stop this
The speaker cutout feature whenever the headphone jack is connected is a hard-wired feature of the headphone connector, and cannot normally be bypassed without further electronic circuitry and the associated surgery to install a custom modification in the TV. In order to keep the TV speakers on while using the sound elsewhere, you will have to take the audio output from the IR Audio port, if there is one.
Apr 02, 2015 | Olevia LT37HVS 37 in. LCD HDTV
Tv no sound and vol no working on remote hitachi
Mrs. Tremelling: One quick and simple thing you can check: If your TV has a headphone/earphone jack, plug the phones in and out a few times. When you plug in the phones, a small switch "opens" (turns off) the connection to the speakers. Sometimes it gets a little grimy (particularly in old TV's) and sticks in the open position.
Good luck, from a retired TV tech...
May 26, 2014 | Televison & Video
Can't get any volume on my zenith tv
Put ear right to speaker to see if hum etc----if opened look to see if speaker paper is gone from old age---last is if it has a earphone jack on set that can cause this also.
Nov 01, 2012 | Zenith Televison & Video
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
Speaker is off
Most of these combo units do not have a speaker ON or OFF setting but look anyway.
If the set has a earphone jack that may be the problem--see if works with earphone plugged in.
The socket the jack goes into can get flaky as when jack is inserted it turns the sound OFF.
Also put your ear right to the speaker to see if anything at all is heard--the speaker could be bad--but check the above first.
SD TECH
May 27, 2012 | JVC TV-13142 13 in. TV/VCR Combo
No sound
Hello
If picture is OK and there is no sound output from your tv, means either its speaker or the Sound output Ic is not working. The case of speaker fault can be easly detected without opening the TV. You just place your ear very near to the speaker side and switch on the TV by AC mains [not with remote control]. You may hear a "thumb" SOUND OR A "HUM" sound from it. If any one is there the internal speaker is working fine. The fault lies in audio output Ic stage. If there is no sound said above, speaker can be suspected. Befor confirming that the speaker is faulty, if your TV has an earphone or headphone jack in front, insert the earphone or headphone socket into it, and check whether there is any sound heard from it. If there is sound from headphone, means that the headphone socket is faulty, it does not bypass the sound to the speaker. When head phone is connected, the connection to the speaker will automatically cut of. When it is pulled out from the socket, the speaker connection will resume. If the changeover switch inside the earphone socket also show this kind of trouble. If the speaker inside is found faulty, unscrew it out of place after opening the TV, go for a same type and number, impedence and shape.
If there comes the above said "HUM" sound from the speaker, surely the Sound Output Ic is faulty. Replacing it will solve the probelm. Before replacing it, check it soldering points for any loose contact. It is best to resolder all suspected point is sound section before replacing the ic.
Note: In modern TVs there will be any trace of sound, without a video signal. Without video, sound is muted. ok.
Nov 07, 2010 | Toshiba CF19H25 TV
Connect Logitech 2.1 to TV
i dont know how ur tv does not have a earphone jack i wonder now a days how they make such tv's , pls try to take sound from audio LR if it helps other wise no hope to get sound on speakers sorry pls try to find in manual if there is any hidden headphone jack some where see in manual
Feb 25, 2009 | Logitech X-530 Computer Speakers
Polaroid FLM-323B HDTV Loud Buzzing
Hi.
If your happy to remove the back casing of the the TV set.
Lay set face down on table with several towells laid out flat under it.
Undo all screws holding back on & lift it off you may need to remove tv stand to remove back.
Once back is off either locate speakers & unplug the leads from them remember to insulate the loose wires & tie them up out of the way.
Or trace wires from speakers to there plugs & sockets on main Pcb & unplug them & thats it.
Screw rear of set back on & ensure volume is set low or at zero.
http://dysonmanuals.llc.nu/
Jul 13, 2008 | Polaroid FLM-323B Television
Connection to a portable tv
The RCA set on a tv [Red /White /Yellow] are INPUT[ VCR/DVD player] not out put. Hook the speakers up the the 3,5mm earphone jack though you will need a conveerter plug like this
Jun 30, 2007 | JBL CREATURE II Computer Speakers
Televison & Video Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
