Hi, I need help with my Presario CQ61. Its fan went off a while ago. I was just wondering if changing the fan system would change the situation? javan
    Top Expert:
  • Computers & ... Master
  • 8,204 Answers
If the fan has stop you will over heat so yes replace asap..
Posted on Apr 15, 2015
SOURCE: Speakers don work under Ubuntu 9.04 in presario cq61
ICEBOX - I had exactly the same problem! But I have just fixed it after several hours of pulling my hair out. I had tried everything I could think of, as well as lots of solutions other people had suggested, including installing the latest version if Alsa from source etc. Nothing worked, until I found these four lines on another forum. Simply paste them at the end of /etc/modules.d/alsa-base.conf and save it.
options snd slots=snd-hda-intel
options snd-hda-intel model=hp-m4
alias snd-card-0 snd-hda-intel
options snd-hda-intel enable_msi=1
Restart the computer and you should get sound out of the speakers as well as the headphone socket.
Posted on Aug 10, 2009
hmerchant110
  • 7191 Answers
SOURCE: I need driver webcam for HP Compaq Presario CQ61-115TU
You can download the required drivers from: http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=ca&lang=en&product=3938467
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Posted on Aug 24, 2009
  • 10406 Answers
SOURCE: replace a keyboard on presario cq61 laptop
If you have to ask "how", I recommend that you STOP, and take the computer to a qualified technician, to have the work done safely & correctly.
Posted on Jun 12, 2010
mariolands
  • 2296 Answers
SOURCE: compaq presario cq61 screen went
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
Posted on Jan 06, 2011
SOURCE: My Presario CQ61 won't do anything. No fans.
-Take out the battery,
-Remove main supply,
-Hold power button down for 30 secs,
-Put only power supply in, do not put battery in
-Turn laptop on
-Put the battery in
Check your AC power adapter. Is it snugly plugged into the wall or surge protector? Make sure the connection is made and it is not loose. Also, try connecting the power adapter into a different wall outlet.
Laptop power not working -::> click HERE
Posted on Apr 19, 2011
NEED DRIVERS FOR COMPAQ PRECARIO CQ61-411WM WINDOWS 7 LAPTOP
hi,
i don't understand why people ask here when doing a simple search in google you find it !!!
http://support.hp.com/us-en/product/Compaq-Presario-CQ61-Notebook-PC-series/4074240/model/4125443/drivers?openCLC=true
next time type same question in google !
Jan 24, 2015 | Compaq Presario CQ61-411WM
No screen
Hi ,
This seems to leave us with the Hard Disc .
Regards .
Apr 13, 2013 | HP Compaq Presario CQ61-420US 15.6-Inch...
Sir, i have compaq cq61 laptop & after scaned by advance care system laptop key board not working
First try a Cold Start, shut down, unplug, remove battery, plug in, reboot. Any change? If no, Do a System Restore to a date before the issue.
Jan 17, 2013 | Compaq Presario CQ61-310US Laptop
Fit my Compaq Presario CQ61?
accu Compaq Presario CQ61 100 percent compatible with you Compaq Presario CQ61. I bought two Compaq Presario CQ61 batteries from http://www.accukorting.com/compaq-presario-cq61.html two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Nov 30, 2012 | Computers & Internet
Compaq Presario CQ61-320SA Notebook PC
contact hp tech support and give them the serial no and product no of the notebook...battery connectors have gone bad
Jan 29, 2012 | Compaq Presario CQ61-310US Laptop
Compaq Presario CQ61-313US Notebook PC won't power
try to remove first your battery and use only the adapter.
Sep 09, 2011 | HP CompaqPresario CQ61310USE Notebook
I need xp drivers for compaq presario cq61-sv300
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
May 15, 2011 | Compaq Presario Notebook
Compaq presario cq61 showing battery problem concider changing your battery how can i solve it i am using windows 7
Charge your battery, it's empty. If you get this message even after you have charged it then the battery has aged and it can no longer hold its charge so you must replace it.
Apr 11, 2011 | Compaq Presario CQ61-310US Laptop
Computers & Internet Logo
David Payne
David Payne
