Error 33 in Hyundai hc 1007w Washing machine??
4 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: westinghouse lt609s Washing machine has
Possible fault in the main program controller unit. It is important to test the sequence and output of the program , the voltages to the motor during the wash cycle drive motor, the input valve and output valve voltages at the point of cycle to confirm the program controller.
Posted on Mar 23, 2011
  • 6277 Answers
SOURCE: F-33 error code on whirlpool
Whirlpool's 'F33' indicates a drainage problem.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 11, 2011
rfaber98
  • 1326 Answers
SOURCE: How error 33 in Hyundai hc 1007w ??
Turbocharger bypass valve control circuit
Posted on Apr 15, 2015
Need to know what HC means on my washing machine Kenmore Elite Oasis. wash did come thru from the bottom
hi there
HC means that the water hoses have been changed or the hot is in the cold and vice versa. put the hot water to the hot on the machine and the cold to cold and this will stop the HC code.
and on another site
The "HC" indicates that the Hot and Cold water supply lines are reversed. Shut the cold and hot water supply valves off and then remove and reverse the hot and cold water fill hoses on the washer and then see if it continues to display "HC".
what HC means on my washing machine Google Search
Aug 07, 2017 | Kenmore Washing Machines
E 70 hyndai washing machine hc-1700w
Mar 16, 2017 | Washing Machines
Electrolux washing machine showing error 33(no interlock). what do I do?thanks
Hey Desmond, thank you for your inquiry!
From my understanding your Electrolux washer is displaying an error code of 33. I am showing that is an invalid error code. This could be a miscommunication within your control panel. I would suggest performing a reset on your washer and you can do that by disconnecting power from it for at least ten minutes. If the reset does not help correct the issue and the error code comes back please comment back. Also, let us know your model number. You can locate the model number of the door frame of your washer. Once I have that information I would be able to assist you further. -Matt
Dec 04, 2015 | Electrolux Washing Machines
Error code 33 spin what to do?
check pump impeller,s not worn away
Apr 11, 2015 | Washing Machines
Frigidare ATF8000FSO error code 33
Hello edward, thanks for your post!
I see your Frigidaire washer is displaying an error code "33". However, it appears "33" is an invalid error code. Let's attempt resetting your range. You can do this by unplugging it or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "33". I look forward to assisting you. -Matt
Oct 01, 2014 | Frigidaire Washing Machines
Westinghouse lt609s Washing machine has stopped and will not progress HC error
Mar 23, 2011 | Westinghouse Washing Machines
Why is my kenmore elite (top loader) oasis washer HE is displaying a code of HC
The water inlet hoses are probably removed and reconnected in reverse, and then trigger the HC error code to flash indicating the hot and cold water inlet hoses are reversed. Reconnect the water inlet hoses properly and start a cycle then let us know what happens next.
Apr 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does HC stand for?
According to the Whirlpool "Cabrio" washer installation and maintenance manual, (Cabrio is the Sears Oasis) the HC code will come up when.
“HC” (Cold and Hot hoses switched)
This code will appear at the end of the wash
cycle to indicate that the cold and hot water
inlet hoses are switched. If an error code
does not appear, but you are experiencing
poor washing performance, check to see
whether the inlet hoses are reversed. See
“Connect the Inlet Hoses.”
Sep 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Error code HC
I recently started getting this message as well. I found out that I accidentally switched the hot and cold water lines into the washer. After switching so hot goes to hot and cold goes to cold the 'hc' message has stopped.
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore washer has a error code of hc
You need to switch over your hot and cold water lines. 'HC' means that your hot and cold are hooked up to the wrong inlets.
Mar 30, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
