Question about Dragon Touch Tablets & eReaders
What do I do to fix my Dragon Touch I8 tablet, when I can't get it to turn on? If I hold the power button it just tells me to swipe down to turn off PC. It won't light up when I plug in the charger.
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
Posted on Jul 06, 2010
SOURCE: My Dell Streak 7 Tablet will not charge. When the
I can't charge my sell streak 7 (no orange and green color appear when plug in) moreover the unit can't turn on also.
I tyr hard rest also but no response at all
would you please suggest me how to do it
Posted on Sep 17, 2011
SOURCE: tablet crashed won't do anything
plug it in for 5min.then hold the power button for about a min. I hope it works it did for mine.
Posted on Dec 01, 2012
amandaellett
  • 13 Answers
SOURCE: Have the dragon touch 10.1" hd tablet everything in Chinese how do I switch it to the English language
If is itunes compatible just hook up to computer running: tunes/ if not can do reset by pressing volume up key, home key, and power key holding till reset screen appears.
Posted on Mar 01, 2013
giao_mai
SOURCE: My Samsung Galaxy Tab won't turn on, even though battery is full. What's the problem?
hi did you fix your problem?
Posted on Mar 06, 2013
What can we do with my daughters Dragon Touch tablet? The screen is frozen and it won't let you turn it off or nothing
if it has a home button at the bottom and an on/off switch on the side , press both together and hold in for at least 5 seconds
that will possibly go to a reboot of the tablet
Jan 04, 2017 | Dragon Touch Tablets & eReaders
Tab has frozen; can't turn on or off. Anyway to fix?
Hold your finger on the on/off button for about 15 to 20 seconds . That should shut down the tablet and reset it. I have had 3 tablets and everyone has reset from a frozen screen that way. Afterwards you should run your anti virus program and bolter to clean up what caused the traffic jam.
Feb 09, 2016 | Dragon Touch Touch R10 10.1 Google Android...
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
I have a dragon touch tablet model A93 and touch screen is not working. I can't tap or press anything
Can you turn it off? If so turn it off then hold the volume button down and the on button at the same time for about 10 seconds. Factory reset will be available to you then.
Hope this helps
John
Jun 13, 2015 | Dragon Touch Tablets & eReaders
I dropped my dragon touch tablet on its power button and now its indented and won't work how can I fix this
looks like it requires a disassemble and replacement of a few parts. Good luck finding parts. If u r cleaver u may be able to jerry rig something
Jan 24, 2015 | Dragon Touch Tablets & eReaders
The screen will not work on my tablet everytime I try to swipe or touch something its like its froze up how do I fix it
Press the Power button longer until your tablet shuts down. If you can restart it, find a cache cleaner software to clear the cache for more space. Sometimes, the cache takes up nearly all the available space from the tablet's ROM. This slows down the tablet considerably and also causes malfunctioning of the OS.
Jan 23, 2015 | Tablets & eReaders
How do i reset my android dragon touch tablet
Try holding power and both volumes if it reboots normally try again but let go of power when the Android pops up
Apr 17, 2014 | Tablets & eReaders
Dragon Touch Android tablet. How can I replace a broken power button?
I bearly got my dragon touch and then my power button broke?
Jan 26, 2014 | Tablets & eReaders
How do I reset my ipad
What type of reset? To reset go to settings>General> scroll to bottom of the page and you'll find reset options there. To turn off the iPad completely, not sleep, you hold the power button down until you get asked if you want to turn off, swipe and it's off. Turn on by holding down until it starts. If you want to clear the RAM hold the power button down till the turn off swipe screen appears, then hold down the home button until screen returns to normal. Hope that helps.
Sep 20, 2013 | Apple iPad Tablets & eReaders
Tablets & eReaders Logo
97 people viewed this question
Top Dragon Touch Tablets & eReaders Experts
rugby prop
Lawrence Oravetz
Are you a Dragon Touch Tablet and eReader Expert? Answer questions, earn points and help others
