This is a $3,600 commercial undercounter fridge. Great make and I have used many of them in my 50 year catering career. There is nothing on fixing Error 13.
Hi NO(oxides of nitrogen) means high combustion temperatures.You probably have a non functional EGR valve or the passages are plugged up with carbon.(you didn't say what year the car was,so I didn't know if it was OBDII or not).
If it doenst have an adjusment on the band to losen it then take and flex the band several times but not to much you could snap it. That should help though.
Error 0701: USB Over
Error 0701: USB Over Current On HC/Port - Bus:00H Dev :1DH Fun:01H / Port:00HCurrent On HC/Port - Bus:00H Dev :1DH Fun:01H / Port:00H
Borrow or change the MAF completely,you have a LEAN combustion condition.The MAF could very well be the problem as it is the most common source lean combustion.
You will need a catalytic converter in good shape.
I recently started getting this message as well. I found out that I accidentally switched the hot and cold water lines into the washer. After switching so hot goes to hot and cold goes to cold the 'hc' message has stopped.
Unplug the cable behind the cd stack box and plug it back in and see if that helps. It worked for me. I get this problem once in a while and this always helped.
Hi have a nice day! Check EVAP Emission Control System Vent Circuit.
DESCRIPTION
The evaporative system prevents hydrocarbon (HC) vapors from the fuel tank escaping into the atmosphere where they would form photochemical smog. Gasoline vapors are collected in the charcoal canister. The Canister Close Valve (CCV) closes off the air inlet to the canister for leak detection of the evaporative emission system. The CCV also prevents fuel vapors from escaping from the canister. When the engine purges HC vapors from canister, the clean air comes into the canister through canister air-filter and CCV.
If open error message displayed is "P0447"
If shorted error message is "P0448"
