Question about Lenco Control Box 123sc 30072-001
I was trying to wire my wipers to match the display. swapped black with white now they only go down till i cut power to them then they go up
I bought a powabyke on ebay and when it arrived I noticed that there was wires unattached beside handlebars where throttle cable joins throttle but the colours don't match the cable coming upwards has...
if its for the key area try red red ,black black, yellow orange, white grey, blue,green , kinda the same on some tailer hookups.
the other colored wires that dont match as well are distributed to the turn signals. if they work as they should after the above mentioned hookup great!.
If not just try switching the orange and blue wires again because one is left one is right side.all the power and grounds are the same,good luck, Gary
Oct 25, 2013 | Cars & Trucks
Windshield wiper motor wiring
power wires are normally red and earth wires are normally black in car auto circuits.
Aug 25, 2013 | Porsche 944 Cars & Trucks
I trying to connect my SFC-4160 (security first color ccd camera) the wiring has been cut n there is 5 wires black,red,yellow,white and a bare wire ???? help
Inside the camera is a 4 pin connector connected to the LED Board, with the connector in hand, turn it till you see the pins inside the connector, from left to right wires 1st-white, 2nd-black, 3rd- bare wire or shield, 4th-red, yellow is not connected, the RJ45 end, face the latch away from you, wires are 1st-red, 2nd-white, 3rd-yellow, 4th-shield(bare wire), 5th-black, the LED Board has the wire positioning marked,,,,,
Nov 27, 2012 | Car Audio & Video
Flotec 1800A SUMP PUMP located in a pit in the middle of a concrete pad. I Cut the plug off the float to get the wire to fit thru a 1.5" PVC pipe (the same size used for discharge). It is...
when you are trying to connect a 2 wire system into a 3 wire system sometimes it just won't work.
try keeping your black/black and change the white with the 3rd wire if that fails try white/white and the black with the 3rd wire.
without a wiring diagram it is hard to tell what each wire is for, and like I first said sometimes these systems cannot be mixed
good luck
Aug 23, 2011 | Flotec Corrosion Resistant Shallow Well...
I want to replace the cord/plug is it easy?
Malibu power packs are 1-piece units that can't be taken apart.
However you can cut off the cord and leave about 4-6" of cord sticking out, and then splice into the cord that's sticking out.
Usually I buy heavy orange or black extension cord with male-female plugs on each end.
I cut off female end and use that end to splice into the cord that's sticking out.
How to splice wire.
Use knife and slice down the cord lengthwise... just cut through the outer plastic covering.
Pull the outer cover cover back to reveal black and white wires.
Cut off extra cover.
Cut back insulation on each black and white wire.
Now you have 2 black wires and 2 white wires/
Twist together the copper wire on whites and cover with plastic electrician tape.
Do the same with copper wires on blacks.
Now the blacks are joined/ and whites are joined, and each has tape over copper wire.
Wrap black tape around both sets of wires until all the black and white is covered with several wraps of tape.
That's it. Plug it in.
Nov 23, 2010 | Intermatic Malibu 300W Power Pack...
Cat chewed phone power supply for GE cordless phone. Its in two pieces and also gnawed in many other areas of the line. Looking for a power supply replacement Thomson Inc 5-2812 IW506 Input: 120v 60Hz 0.2A...
Get you some electrical tape and cut cord where it's chew off and splice wire ( match white and black wire with the same and ......match black and black ok,,,after that tightly wrap only matched pair one at a time ok
Dec 03, 2009 | Uniden Cordless Phone
I have a 95 jeep wrangler. I bought aftermarket tail lights that have red, black and white wires. The existing original wires are, white,white and black and a green and black wire. I need to know which...
match the blacks up they will be your grounds and the green is a ground too I believe as far as the other wires go. In the truck turn on the signals and parking lights and have somebody push the brakes matching up wires till everything works right. Do one thing at a time its not as hard as it sounds.
Oct 14, 2009 | 2004 Jeep Wrangler
2000 mustang headlights are dim
Check the headlight relay.Little plastic cube about 1 1/2" square,usually black or dark brown and white ink numbers printed on top.Bottom has blades sticking down into the wire connectors.Location will either be under the dash or under the hood,not sure exactly about mustang There will likely be other relays in the same location,and many times you can match up two relays with the numbers printed on top,and swap the relay with say...the wipers' relay,just to see if it is a bad relay.Cheap ($0) and a check worth doing
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Apr 01, 2009 | 2000 Ford Mustang
Wiring Problems
You didn't cut the plastic connectors off the factory wiring, did you? One is gray and one black.... if not, just get to a stereo shop and buy a wiring kit for your car and all colors will match. They're about $10. If you DID..... well..... we have a LOT of work to do....
Sep 11, 2007 | Car Audio & Video
Lenco Control Box 123sc 30072-001 Logo
268 people viewed this question
Top Lenco Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lenco Science and Laboratory Expert? Answer questions, earn points and help others
