Stop at 4 rt program - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check pump for blockage
Posted on May 03, 2015
I have a Panasonic KX-T2345 and I need Info on programing memory stations and using "call hunt". Thanks
PanasonicKX-T2345 program buttons
To Program
Push Buttons
1 Memory slide Sw Under
Lower RT lip to Program
2 Memory light lit
3 Station button Press (Beep)
May want to write name 1st
4 Memory light goes out
5 Dial Phone number
6 Memory button Press
(Long Beep)
7 Memory light lit
...repeat 3-7 for more Ph #
8 Memory slide Sw Under
Lower RT lip to Set You are Done
PanasonicKX-T2345
Mar 21, 2011 | Panasonic Lands Phones
Tip
Frigidaire Dishwasher Error Codes and Service Test Mode
Many modern appliances have error code build in to the control programing to help with the diagnosis of a failure. Frigidaire dishwashers with display s will flash Er then a two letter error code.
Er i s a Switch error (Replace Console Pn# 154639207)
CE is a Configuration error (Replace Control Pn#154543602)
UO is a Vent that will not close. (Replace Vent Pn#154682301) or remove blockage
uF is a Vent fan Not running (Replace Vent Pn#154682301) or remove blockage
Other codes you my see in the display that are not errors
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
01-24 hours of delay
Service Test
To enter service test you must turn off the power and PF will be displayed. While in PF press and hold Pad # 1 and Pad # 7 at which time an “rt” will appear in the display. To get it out of service test Press Pad # 1 and the Pad # 7 this will return you to PF mode.
[ (#1)(#2)(#3)(#4)(#5)(#6)(#7) (#8)(#9)(10)(11) ]
Press pad # 1 Active water valve Ultimate Scrub Maxx Clean Valve on =FL Valve off =rt
Press pad # 2 Test Speed motor (1 Time) motor @ 2800 rpms Speed Wash pad ”28′ First two digits motor speed
Press pad # 2 Test Speed motor (2 Times) wash motor @2950 rpms Speed Wash pad “29′ in display
Press pad # 2 Test Speed motor (3 Times) wash motor @3150 rpms Speed Wash pad “31′ in display
Press pad # 2 Test Speed motor (4 Times) wash motor @3450 rpms Speed Wash pad “34′ in display
Press pad # 2 Test Speed motor (5 Times) turns off wash motor No light on ”rt” in display
Press pad # 3 Test Dispenser dispenser powered Normal Wash on = “Sd” off = “rt”
Press pad # 4 Test Drain pump on/off China Crystal or Party glasses on = dP off = “rt”
Press pad # 5 Test Fan dry Active vent on/off Top Rack,Eco Wash Glasses on = Fan speed off = “rt”
Press pad # 7 Test Rinse aid level none Rinse only low = RE full = RF off = “rt”
Press pad # 8 Test Soil Sensor none Wash Silencer or Wash pressure on = sensor voltage reading off = “rt”
Press pad # 9 Test Thermistor none Wash Temperature on = Temperature in °F off = “rt”
Press pad #10 Test Heater on/off Heater on/off No Heat Dry on = HO off = “rt”
on Dec 23, 2009 | Dishwashers
Need a manual for rca rt 2500 receiver,don't know how to program radio stations manually can u help me thanks Darryl
Did you try "PAC PARTS"? But I think RCA stopped selling parts! Might try a search with the model#...
Apr 23, 2010 | Audio Players & Recorders
Error code of "Er s" appears on the display and inside the light remains on at RINSE Low. HELP!
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
Service Test
Let me know how this works out for you.
Benjamin
Radio fuse
# 18 for radio and it is a 20amp...see below for all #'s got to and amps... 1-20amp-pwr outlet frt. 2-10amp-rear fog lights(export only)
3-15 amp-horn 4-10amp-hedlt low beam rt
5-10amp-hedlt low beam lft 6-20amp-bodycontrolmodule/pwr dr locks 7-spare 8-spare 9-10amp- rt pk lt /rt tail lt/trailer tow lt/cluster
10-spare 11-15 amp-flasher 12-15 amp-stop lts
13-10amp-bodycontrolmodule/cmtc/cluster 14-spare
15-10amp-pdc fuel pmp & auto shutdownrelays/skis
16-20amp-pwr outlet rear 17-15amp-rear wiper 18-20amp-radio choke relay 19-20amp-frt fog lts/trailer tow stop and turn lts
20-20amp-sunroof 21-spare 22-10amp-wiperswitch/frt and rear washer 23-10amp-lft park lt/lft tail lt 24-10amp-pdc blower motor relay 25-10amp-heatseatswitch/hvac controlhead/trailor tow battery charge 26-10amp-hedlt highbeam rt 27-10amp-hedlt highbeam lft
28-spare 29-15amp-heated seat module 30-10amp-heated mirrors/rearwindowdefrosterindicator 31-20amp-cigarlighter
32-10amp-radio/frtdoorlockswitches/bodycontrolmodule
33-10amp-skis/diagnostic connector 34-15amp-cluster/courtesy lts/radio/bodycontrolmodule/maplights/cmtc/underhood lt/vanity lts
35-spare 36-10amp-ignition run/start-orc/lft and rt siacm
37-10amp-ignition run only-orc 38-10amp-abs module/brake shift interlock solenoid 39-10amp-rear window defroster relay/flasher/backup lts
Jul 29, 2009 | 2002 Jeep Liberty
2002 jeep liberty interior fuse diagram
Jul 03, 2009 | 2002 Jeep Liberty
I don't have an owners manual and I need a fuse diagram for my 2002 jeep liberty
There is normally a diagram printed onto the the inside of the fuse case.
May 24, 2009 | 2002 Jeep Liberty
1995 chrysler lebaron
Here's what mine says- for a 95 Chysler LeBaron GTC Convertible. I didn't see anything about a fuel pump, but maybe it's connected to something else? I dunno. Good luck. Here's the info at least.
1 HTR-AC 30A, 2 POWER WINDOWS 30A C/B, 3 PWR SEAT, LKS, TOP 30 A C/B, 4-BLANK, 5 BACK-UP LAMPS 20A, 6 TURN SIGNAL 20A, 7 REAR WIPER 20A, 8 ILLUM LAMPS 5A, 9 INTERIOR LAMPS 10A, 11 CIGAR LIGHTER 20A, 12 RS AMO 20A, 13 INTERIOR LAMPS 10A. 14 BOD COMP MESS CTR 5A, 15 SPEED CONTROL 2A, 16 GAUGES AIRBAGS 5A, 17 STOP LAMPS 18 HEAD LAMP RT-LOW 10A, 19 HEATED MIRRORS 5A, 20 AIRBAGS 5A, 21 STOP LAMOS 20A, 22 HORN 20A, 23 RT-TAIL LAMP-EUR 5A, 24 LT-TAIL LAMP EUR 5A, 25 HEAD LAMP LT-HI 10A, 26 HEAD LAMP RT-HI 10A, 27 RADIO 104, 28 FRONT WIPER 20A
Mar 29, 2009 | 1995 Chrysler LeBaron
Matrox rt.2x and adobe premiere cs4
not found in RT.X100
· Adobe Creative Suite 4 Production Premium and Adobe Premiere Pro CS4 support
They cannot work together unfortunally
Jan 26, 2009 | Matrox RT.X 100 (RT.X100) Video Capture
2001 chevy silverado anti lock brakes
You most likely have a wheel speed sensor dropping out this would make abs system think one wheel is locking up and therefore activate. this usually will happen rt before you stop at around 5mph or so.Also if you have bigger tires than factory and have not had abs programmed for this size it can aggravate it
Dec 11, 2008 | 2001 Chevrolet Silverado 1500
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
