Question about Sewing Machines
My jukai8700 wont sew each time l press the peddel the belt attached to the wheel and the motor refuses to rotate.
  • Sewing Machines Master
  • 10,284 Answers
Check to make sure your machine is not set for winding a bobbin. There is usually a latch or a knob that releases the handwheel so the machine does not sew while winding a bobbin.
Posted on Apr 19, 2015
    Top Expert:
  • 10,875 Answers
Something is jammed or no power
My jukai8700 wont sew each time l press the peddel - fae48934-5983-461e-b8ec-a822ebc62432.png
Posted on Apr 15, 2015
  • 1 more comment
  • Omolola Alimi Apr 15, 2015
    Pls what do I do
  •  johnny rebel
    johnny rebel Apr 15, 2015
    unjam it or take it to be repaired,make sure there is power to it by plugging into different outlet,have someone check the footpedal to make sure it works
  •  johnny rebel
    oil it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
SOURCE: kenmore sewing machine mod 1703 motor runs but
By 'The wheel the belt is on' you mean the motor pully? If that is so obviously some oil has some how made way on the pully and the belt. Try to remove the belt and clean both wheels and the belt free of oil. This shd slove the problem.
If it doest then please send a photo of the arrangement showing pully and belt. U didnt mention if the machine is old or new. Did u oil it recently before trouble developed?
Posted on Oct 17, 2009
Zenqi
  • 208 Answers
SOURCE: when i press down on the foot peddel it will only
You just need a new foot control; a very quick and easy fix.
Posted on Feb 21, 2010
  • 980 Answers
SOURCE: Toyota 2260 sewing machine. When I press the foot
Chances are you have a small piece of thread stuck in the raceway, turn the balance wheel bac kwards and you may free it off otherwise take out the bobbin and bobbin case and the raceway if you have the type with a drop down gate and clear it.
Posted on Jun 19, 2010
SOURCE: motor runs but does not sew, like the belt is off
bobbin winder is engaged
Posted on Mar 24, 2011
  • 1552 Answers
SOURCE: Motor runs machine jams, wheel hard to turn
Unless you are a qualified service technician, take it to a technician for repair. Trying something yourself may cause more harm.
Posted on Feb 24, 2015
I have a Consew 206RB-4 and cant get the bobbin winder to work.If no thread is attached to the bobbin,the bobbin will spin correctly.But when threaded the bobbin doesnt spin Ive loosened the tension
Hi Trish,
Have you checked if that wheel which spins the bobbin winder is pressed properly against motor belt which spins the machine itself, maybe its not aligned properly or it doesn't press firmly enough against that belt, or the belt itself is old and stretched and it doesn't put enough pressure on that wheel.
Sep 29, 2016 | Consew Sewing Machines
Help hand wheel of zigzag sewingmachine refuses to move
The make/model of your machine would be very helpful in assisting us to provide advice.
Just offhand, if it is a mechanical machine, it most likely needs a good cleaning and oiling. When mechanicals are not regularly oiled, the old oil solidifies and causes the moving parts to seize. It is important to use a good quality sewing machine oil--NO 3-in-1, WD-40, cooking oil, or old stinky brown stuff from grandma's sewing box.
May 24, 2016 | Sewing Machines
Feb 24, 2015 | Sewing Machines
Why is the hand wheel of my new consew 206rb-5 so tight? the machines hums when sewing, like beeind forced, is this part of the breaking in?
contact the one you bought the machine from & tell them how
tight the hand wheel is & see what they recommend
Jun 04, 2012 | Consew Sewing Machines
The belt on my consew 7360 sewing machine wont turn handwheel when pressing foot pedal to stitch.
Your belt may be to tight you can loosen the belt at the wheel under the table. Loosen the screws and shift so the belt loosens.
Nov 14, 2011 | Consew 7360R-1 Mechanical Sewing Machine
My serger won't start. Motor is running but won't turn. Also wheel wont turn
Hi, On most of these newer machines they have a clutch that you engage to fill the bobins.
Please make sure that the clutch is disengaged for normal use. If this is all OK see that belt
is attached on motor.
Jun 05, 2011 | Husqvarna Huskylock Computerized 905
Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
Dec 12, 2009 | Kenmore Sewing Machines
Hand wheel will not turn
A FRIEND GAVE ME A SUPERLOCK 2000 WITH THE SAME PROBLEM. THE HANDWHEEL WAS HARD TO TURN AND MACHINE WONT RUN WHEN PLUGGED IN. I OPENED THE SIDE COVER WHERE HANDWHEEL IS LOCATED. FOUND THE BELT WAS DRIVEN OFF THE MOTOR. PUT ON THE BELT ON THE MOTOR, OILED THE MOVING PARTS.
WOKRING GREAT NOW.
Apr 30, 2009 | White Sewing Superlock 2000 ATS Mechanical...
Needle wont go up and down.
well,it seem that your upper camshaft was stuck due to several factor on mechanical linkages and maybe on gears.You have to isolate the checking since you have clean lower bobbins free from dirt and thread/fabrics chips.If there an opening on top of machine open it to check some mechanical destorsion or breakage.Check some broken gears inside.If nothing try to open also at the bottom of machine cover and there are also belt and gears connected to the motors and bobbins shuttle holder if so oil all shafting oil port,oil port bushing specially on bushing near hand wheel there is port for oil,
check also motor assembly of machine,you can disconnect belt from motor release the bolt holding motor adjust to lower tension belt and release the belt.Take some tools such as monkey pliers or small pipe wrench that can hold hand wheel just crack in order to move suddenly after oiling for several hours sometime bushing and shafting rushes emerged or if you have anti rush spray put in on.After cracking and you can move a little crack only by your hand several time lleft and right until all linkages free from rush.If you can move all parts and hand wheel rotate freely.Check also motor by rotating the small pulley conncted to motor if free to move.if ok put back and reassembly all parts disconnected.try to move again by hand if free to move after all asssembly.Run machine using foot pedal.
Mar 14, 2009 | Janome Sewing Machines
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
