Daughter got door open & a lot of water still inside. Machine flashed up "clean pump" taken front bottom panel off & removed the round plug which drained all the water out. What do I do next? Thanks.
    Top Expert:
  • Washing Mach... Master
  • 10,875 Answers
Noggin
  • 944 Answers
SOURCE: smelly washing machine!
The black cover you have removed should be the only "filter"/trap in the drainage system inside the machine. The eggy smell you described has to be caused by one of 4 things; 1. Smell coming back through the drain, indicating that there is no water trap - easiest way to check this would be to disconnect the drain hose from the wall, smell the drain and see if it is the same smell or not. if so, install a water trap, or arrange the drain hose in a loop to form one. 2. Decomposing organic matter in the wet system. There could have been something in a pocket or that accidentally got in with the laundry that has somehow got stuck somewhere - possibly in a filter but also limescale can trap dirt in the system and various items can get stuck in all sorts of places. This can be solved nearly always by running through the cleaning procedure described on this link; http://ezinearticles.com/?Cleaning-Your-Washing-Machine&id=109993 if it doesnt work the first time - try it again - sometimes it can take a couple of tries but nearly always works great. there are also stronger chemicals than vinegar that you can use to clean the machine with, (but they should only be used in extreme circumstances as other components can be degraded) white vinegar is usually all you need. To remove the vinegar smell afterwards if necessary - put a teaspoon or two of baking soda through the machine on an empty hot wash. 3. Decomposing organic matter in the dryer outlet duct (or possibly in the lint filter area, but unlikely, also possibly under the machine up inside where the workings are) - rodents and insects and moss and funghi etc all love the warm moist air that comes out of the dryer and they always can find a way into the duct - something dies or poops in the duct and the smell can be unbearable - easy way to check this is to look in the duct if you can, and see if the smell gets worse if you have the dryer on. Clean the duct out with mild dilute bleach if this is the problem. 4. Some liquid detergents cause a build up slowly in the system that smell quite sewage-like (possibly some powders too, but not so common) - try cleaning out the machine and switching to a different detergent to check if that's the case. Unfortunately the Bosch website manuals page is down today - they will have a manual for your model almost certainly - it is an excellent site; http://www.boschappliances.com/site_tools/documents.cfm try again in a day or two - and you should get a user guide downloaded. An overheating motor is unlikely to be the cause of this smell, "eggy" is not associated with motor or electronic overheating problems. Hope this helps, if you cant cure the smell with these tips, then unfortunately the machine has to be taken apart and the offending item cleaned out - if you fancy trying this yourself then please ask again and we could talk you through it, Good luck :)
Posted on Apr 14, 2007
barkencoa
  • 3463 Answers
SOURCE: Bosch washing machine leaks at right bottom
The part that you removed, was the pump filter, the pump is located behind the filter, possibly, the pump itself is leaking, or the filter cover is not fastened in tight enough, pr the filter seal is defective, if after tightening, it still leaks, suggest you replace the pump.
Please rate my solution.
Thanks.
Posted on May 26, 2009
beltronic205
  • 1460 Answers
SOURCE: Wont drain water Gorenje WA61111
locate the filter and clean, this should cure
Posted on Dec 16, 2009
SOURCE: My Samsung WF218ANW/XAA front load washer will not
lefever352, I am currently trying to solve this same issue on the identical model. I removed , cleaned, and re-assembled all the water tubes and the entire pump assembly. The pump works but for some reason it is not priming into the drain tube. The pump assembly appears to have a diaphram over the outlet opening and it it looks like this might be the problem. I am still hunting the solution, BUT so far the above actions have to resolve our issue. I hope perhaps Fixya can help.
Posted on Jan 22, 2011
  • 240 Answers
SOURCE: bosch classixx 1000 express drain pump won't open?
use grease
Posted on Aug 16, 2012
Tip
E04 Error on Bosch Front Load Washer- WFMC3200UC/01- How to clean and/or change...
I kept getting an E04 error code on my Bosch washer. This means that I have a drain or pump problem. First, I need to trouble shoot before deciding to buy a new pump or to call a repair man.
1. UNPLUG THE MACHINE!
2. Make sure the machine is unplugged.
3. There is a access door on the bottom right side of the machine. It looks like a circle. Turn the circle and remove. Get Towels! If there is water in there, it will be coming out onto your floor.
4. Open the cap. It looks and works like a gas cap on a car.
5. Clean any debris that you find there. Then replace cap.
6. Reach up and squeeze the hose leading from the tub to the pump. There is a little ball inside that hose which is a safety device to keep debris from entering the pump. If that ball moves freely (not necessarily easily, but freely), there is probably no debris to clean out. But, you can always check by removing the hose clamp and looking (not easy at this point).
7. If you found debris in either place, once cleared, you should be fine. The smallest item can cause this error (a hair pin, wet receipt, hair ball, etc...).
8. Replace the access door on front right.
9. Plug in machine and try another load. If you continue to get E04 code, then your pump is probably bad.
CHECKING THE PUMP
3. Remove the access door on the bottom right side of the machine again.
4. Open the cap again.
5. Put your finger in the pump motor and try to spin it. It should move, but not easily. If it moves easy, your pump is probably bad.
6. You can order a new pump motor or the whole pump assembly. The new pump assembly comes with a hose to drain your pump. The original part does not have this feature. No worries, changing the pump is easy and fairly inexpensive ($80-100)
CHANGING THE PUMP
3. You will need to remove the front panel of the machine for the easiest access.
4. Prop the machine front up. There is a metal plate that is attached to the bottom of the machine by 2 screws. Remove both screws. Lower machine back to floor.
5. Remove the door. IT'S EASY. Open door. Remove 4 hinge screws from the door (not from the frame). Be prepared to catch the door once the screws are removed.
6. Remove the front of the rubber door gasket. There is a thin round shaped wire that sits in the groove of the rubber gasket. There is a spring on the bottom of the wire, making it expandable. Gently pull the wire from the groove and set aside.
7. Remove the rubber seal from the front panel (frame of the hole) by unclipping the rubber from plastic notches around the perimeter of the hole. DO NOT Remove the rubber seal from the inside of the machine. Leave it attached.
8. Take the control panel off of the top of the machine. There are 4 screws (2 on each side). Remove the screws, gently pull out and up. No need to unplug the electrical panel. Place the panel on top of the machine.
9. There are 2 screws holding the front panel on. Remove both screws. (1 on each side, on top)
10. There are plastic clips on the inside of the panel. These work similarly to a bedrail attached to a headboard. Gently lift the entire front panel, unlatching it from the clips, then pull forward.
11. Get Towels! If there is water in there, it will be coming out onto your floor.
12. There will be 3 hoses on the pump assembly. Remove the hose clamps.
13. Reach back and unplug the pump. (Squeeze the plug at the pump motor and pull).
14. There are little rubber feet which attach the pump assembly to the bottom of the washer. Push the entire assembly back and lift up. (similar to the bedrail/headboard scenario mentioned above)
INSTALL NEW PUMP
1. Reverse the above instructions.
2. Put rubber feet in bottom and pull forward.
3. Plug in pump.
4. Attach hoses.
5. Put front panel back on and pull down to snap into clips. Put screws in.
6. Put rubber gasket back on. Put gasket on notches. Put wire ring into groove.
7. Put the control panel back on. 4 screws.
8. Prop front of machine up. Reattach bottom to plate using the 2 screws.
9. Replace door, using 4 screws. This will take 2 pairs of hands.
10. Plug the machine in and try it out.
That is all. I am not a professional. I am single mom who has to do stuff like this on my own. Since the pump did not come with instructions and Bosch refuses to tell a person how to take the washing machine apart, I tired to find instructions online, but was unsuccessful. That is why I decided to share. I wrote these instructions from memory. Hopefully, I did not miss any steps. But it really is easy. I was unable to attach pictures, so I hope my descriptions were clear enough.
on Feb 03, 2014 | Bosch Washing Machines
Hi, my washing machine is stopping frequently and E20 is flashing on the screen. What does that mean? Thanks! Ann
The drain pump and filter jammed.error E20.The drain pump getting blocked. Plug off the mains. You have to look for screws below the front kick-panel, you can raise the machine a bit to gain access to the screws, the panel comes down & out. You may find a drain hose here, on left, drain off the excess water. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out.Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter. cleaning the filter is no easy task.
1. First, make sure you have super glue on hand, the door seal is glued to the front panel, will have to be removed first then glued back in place. Using a sharp knife, carefully begin peeling the door seal and cutting the glue close to the cabinet. Do this slowly as to not damage the door seal.
2. Remove top cover. Screws are in the back
3. Remove control console.
4. Remove screws securing the door lock. Remove all front panel screws. Remove front panel.
5. Attached to the tub there is a large, fat drain hose, inside the hose you will find a filter.
Check fig:- d735953.jpg
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Sep 01, 2010 | Frigidaire Affinity ATF7000E Front Load...
F-22 Door won't unlock!
If there is water in the unit you must remove the bottom kick panel and reach up inside the righthand side of the machine where the latch is and feel for a small round protrusion you can pull down and manually unlock the door to remove your clothes. You may get wet though if you don't open the filter on the pump in the front center. If no water there, probable new door latch needed.
May 03, 2010 | Kenmore HE2 Plus Front Load Washer
I have an Axxis+ washer/dryer. The washer is giving me an F:34 error, any ideas?
you can try this I had one of these the other day. On the bottom front of the washer you will find a round access cover, rotate it to the right to remove it, inside you will find a green cord to manually unluck the door, pull it down. Door should now be unlocked. Chances are the door won't unluck because the wash water is not draining from the washer due to a clogged drain pump. Right behind that round access cover is the water pump. Before you open the pump cleanout, soak up all the remaining water inside the wash basket of the machine, or use a wet dry vacuum to vacuum up the water. Have a shallow pan and lots of bath towels to catch the water when you open up the drain pump cleanout. Check the drain pump cleanout for lint, small socks, coins and whatever gets left in pockets of clothes.http://servicetechhelp.com/discus/messages/2801/65423.html?1241057606
May 03, 2010 | Bosch Axxis WFL 2060 Front Load Washer
4 flashes and beeping
4 flashes indicates a drain failure. Could be obstruction in drain system-first check drainhose for kinks, check where drain hose attaches to wastepipe spigot for blockage. If OK blockage may be in pump- disconnect from power, remove bottom panels to access under machine. Drain pump located front left- remove plug from pump, then there is a plastic tag on top of pump you must push down, then drain pump will turn and come off (it comes off easily if tag pressed correctly, so don't force it!!)
If pump OK, fault will be with water indicator switch-sometimes get full of muck. Open dishwasher door, remove filters and clean out any water from base. Right in the bottom right hand side of sump you will see a round black grill- this is water level indicator switch. If it looks blocked up, advise replacing (you can try cleaning, but replacing is best). To replace, access from under machine-again, this switch turns and pulls out, but can be quite difficult due to it being located behind the heating tube.
So, check hoses and pump, then press and hold start button for 3 seconds- this clears fault and resets machine. Try another cycle-if OK, problem solved. Recommend expert assistence to replace water indicator switch.
Aug 04, 2009 | Whirlpool 24 in. ADG7540 Built-in...
GE model WHDVH626FWW Front load washer won't run, can't open door
your drain pump is likely clogged,and is equipped with a clean out port. remove lower cover by 3 phillips screws on bottom front. you see the drain pump up front to the right. If there is a lot of water left in machine then have bucket/pan avail and plenty of towels. wet dry shop vac helps. you can open door and remove clothes from here. reach up on right side to where the latch is on inside (you have to go by feel) and find small round pull tab on bottom of latch/lock asm, and pull down, this will unlock door. carefull of water level when opening door.
to fix problem, unscrew cap on pump asm. water will pour out, and a tray will slide out with debris clogging pump. look inside housing for remaining ****. using finger check impeller area on right..
reassemble. machine should work perfect now. Pump is designed to be cleaned out and will not void warranty. newer machines have access port cut in panel for this clean out area.
Apr 26, 2009 | GE Washing Machines
F21 Error code flashing
Plug off the wall first. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
To manually unlock the door lock system, perform the following steps.
1. Unplug the power cord from the outlet.
2. Remove the lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a teardrop shaped tab. Gently pull the tab down approximately quarter inch, or until a click is heard.
5. The door may now be manually opened.
Apr 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The door on my front end Whirpool Duet Washer will not open?
Plug off the mains. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
For some front loader models after removing the panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment.
For the door to unlock, press & hold 'end of cycle' for 3 seconds, power shd be on for this, try door after 2 minutes. Your machine may not open if there is water inside, so first drain.
Apr 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Flashing F and alarm
Based upon your description, the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.... Hope this helps
Jun 08, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
