How do I clean the pump? My machine was not draining. Took off bottom right plug and drained it. What do I do next?
    Top Expert:
  • Washing Mach... Master
  • 10,875 Answers
Without the required info,make or model,do you want a generic answer or an answer based on your washer????????????
Posted on Apr 15, 2015
JOE LLAMA
  • 26 Answers
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Posted on Apr 01, 2008
futureloginn
  • 734 Answers
SOURCE: miele washing machine wont drain
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
SOURCE: Drain Pump Filter Leaks on LG TROMM WM2277HW
I had to remove the two little plastic tabs that prevent you from tightening the filter plud too tight. Grind these two tabs off and you will find youare able to tighten the pluf just a bit more and it will no longer leak.
Posted on Feb 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: Hi I have a problem with a lg washing machine it will not fill up
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG has some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
livewire874
  • 618 Answers
SOURCE: My washing machine( he2 plus) stoped working I
Two screws under the front panel.
Posted on Nov 22, 2010
Taking too long to drain
if it is taking to long to drain then this is a sign that something is plugging up the drain line.
remove the drain plug and clean the drain screen -- this will be right next to the pump body.
as soon as it is clear, the machine should be draining great.
if you are still having troubles after you clean the drain line -- then there could be a problem with the drain pump and it might need to be replaced,,,, but clean the line first as this is the most common problem.
c...
Feb 10, 2011 | Kenmore Energy Star 44092 Front Load...
My lg washer and dryer wm3431hs isn't draining. I took of the hoses in the back, cleaned the filters and still nothing please help!
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps...
Daniel
Jan 10, 2011 | LG WM3431H Washer and Dryer
Wont drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For most front loaders:
Plug off the mains. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. There is a drain hose here, disconnect & drain out. There could be a lot of water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
For some front loader models after removing the bottom toe panel, the filter is in the compartment having the white screw able lid. The big hose from the bottom of your tub leads to this compartment.
You could also check the exit hose of the washer for blocks. Next snake out your wall drain, it helps.
Jun 12, 2010 | Samsung WF337AA Front Load Washer
#MDB5100AWB-water not draining. Screens were plugged bad. Taking all apart to clean/rinse.how do you take the bottom of assembly off? Thanks for any help.
hello. to remove the lower panel you will need a phillips head screwdriver and a flashlight. get right down there and you will see that it is attached with screws. remove them and the front panel will come right off.
Regarding your water not draining issue. Begin by disconnecting the rubber drain hose, and the small pump at the low end of that hose. Examine for debris and remove it. Next inspect the trap under the kitchen sink and the garbage disposal if that is included. Chances are you will find a blockage.
Sep 07, 2009 | Maytag MDB5100A Dishwasher
E20 Error sign
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
May 30, 2009 | Frigidaire ATF6000ES Front Load Washer
HE4 front loading machine won't drain
Sounds like your pump is clogged. Take off the lower front panel via 3 ws on the bottom. Get a buch of towels, thiers gonna be water. Right in center front thier will be a white twist knob, about 3 inche in diamter. Unscrew it, this is when the water is gonna come out. If there is a secondary wall, pull it straight out with a pair of pliers. Clean out the pump, also check the little hole to the right leading into the impeller, make sure its clean. Finally put it back togther and try it out, If you get me a model # i can get you a schematic, should start with 110,thanks Dave www.washermd.com
Dec 17, 2008 | Kenmore Elite 45986 Front Load Washer
GE WJSE3110A washer, won't drain
On a scale of 1 -10, I'd rate this about a 3.5 in difficulty.
Un plug machine.
Use a putty knife to push the clips in at the seam of the front panel and the washer's top, about two inches in from each side to allow you to pull the front panel forward and then lift it off the bottom pegs.
If you took off that drain hose, you shouldn't have any water left in the machine, so take the two squeeze hose clamps off the pump hoses, the electrical wires off the pump, and the two 3/8 size bolts holding the pump to the washer's base.
Now check to see if the pump is plugged or obstructed with an object. Replace pump with cleaned out or new pump as necessary.
Dec 10, 2008 | GE WJSE3110A Top Load Washer
Won't drain
dip as much water as possible from tub..remove bottom panel remove clean out port on pump clean and reinstall
Aug 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
