If having trouble downloading the photos to via USB (from the camera to a PC)
1) Camera to be on viewing mode
2) Clock the Menu/ok button to display the menu
3) Find the blue screen titled OPTION
4) Select the "Set-up" by clicking the Menu/Ok button
5) Select option #4
6) Select "USB MODE" and click the "Menu/Ok" button
7) Choose the icon that looks like a square with a curved bottom
8) Click the "Menu/Ok" button
...you are set! [email protected]
Insert the memory card into the
camera to format it if you are receiving error messages such as "Card
Error" or "Card Not Initialized." Press the "Menu/OK" button then press
the left/right directional button to select the "SET" option. Press the
up or down direction button then press "Set Up" and press the "Menu/OK"
to access the setup screen.
Press the down directional button to select "Option 1" and scroll down
to the "Format" option. Press the right directional button to select the
format option. Press the "Menu/OK" button to start the format process. Move away from the target or brighten the lights if the auto focus does
not work. Rotate the scenery mode dial at the top of the camera to the
"Auto" mode. Press the "Flash" button to enable the flash mode to
provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer
if the computer does not automatically detect it. Connect the camera to
the computer using the supplied USB cable and power on the camera.
Click the "Start" button then click on the "Computer" option and select
the FinePix Icon. Choose next on the download wizard to start the
download process.
button to select "Option 1" and scroll down to the "Format" option.
Press the right directional button to select the format option. Press
brighten the lights if the auto focus does not work. Rotate the scenery
mode dial at the top of the camera to the "Auto" mode. Press the "Flash"
button to enable the flash mode to provide additional lighting if
necessary.
download process.
necessary.
download process.
The Fuji FinePix F470 camera is an excellent device. Most of the controls are computerised in such a way that makes picture taking and viewing less stressful. Changing from shoot mode to playback mode is by the press of the play button which looks like an arrow the zoom lens is not manually adjustable it adjusts by the press of the W and T buttons. Here is a link to help you download the brochure, User guide and quick start guide for the camera: http://www.fujifilmusa.com/support/ServiceSupportBrowse.do?prodcat=842410&sscucatid=664271&sscucatid=664272 Hope this soultion has been helpful?
You might want to check your manual, as some Fuji camera's hve the ability to "shut off" both LCD displays. I owned a Fuji S5600 in the past and I remember that it has a button on the back for the display modes. Pressing this button multiple times could turn on one of the LCD's. If this does not solve your problem, you have to take it to a specialist.
Are you pertaining to the Focus mode? If so you can unlock it using the Focus mode selector lock switch. Press the Focus mode selector button to change the focus mode.
S-AF- Single AF M-F- Manual Focus C-AF- Continuous Focus
I would like to know more information regarding this matter.
The mode dial on these cameras break off that often that Fuji in Australia is replacing them at no charge - sort of a recall issue.
Call your Authorised Fuji digital camera repair centre, make sure they will replace it at no charge and then send/take it to them
It works fine for me. Reember it works ONLY in P mode. The problem is due to the Fuji E550 does not provide focus indicator, you have to judge the image to see when the object is in right focus.
you cannot set anything on auto mode! The camera sets itself automatically. try taking shot(AutoMode)in dimlit area or no light at all. If it's taking shots and flash isn't firing, your flash bulb is already busted! I suggest you buy a separate flash unit (they cost the same as replacing parts and service fee), a cheap one is comparable or works the same as the costly one, if you know how to set up on manual mode ( they call it compose or advance or creative mode!)
