I'm getting an f 71 code on myKennmore elite smart wash steam care quiet pak 9 HE5T. What does that mean?
  • tom cassidy
    tom cassidy May 03, 2015
    Hi Kevin Daniel Weaver, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Washing Mach... Master
  • 5,323 Answers
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit." from here. Hope this helps, good luck.
Posted on May 15, 2015
Kenmore elite smart wash quiet pak hf code
i think the hf means heater fault,,,,,,,,,,,,or the thermostat
Jan 27, 2015 | Kenmore Washing Machines
The kenmore elite smart wash quiet pak 9 I opened the door and threw something else in and now a light is on thar says controls locked and it wont do anything
There should be a button on the control panel that says "open door" you need to push that button and wait for the washer to shut off before you open the door. Try pushing that button to see if that resets. My guess is that you broke the safety latch when you opened the door and it will need repair.
Mar 10, 2014 | Kenmore Washing Machines
I have a Kenmore smart wash quiet pack 9 HE5t and when I try to turn it on it make a noise but won't turn on
Please check the motor belt , the drain pump and the inlet valve. If the noise seems to come from any of these it is possible that it trips off the circuit due to a fault and so must be confirmed.
You can remove the connection to the seperate items to confirm if the panel switches on.
Jul 02, 2012 | Kenmore Elite HE5t Washer
Kenmore elite HE5t quiet pak 9 washer kocks when spinning. I thought something was lose but did not find anything. it will run to completion but get very loud for a short time. Is there some kind of...
I think possibly your machine is not on a level surface. Try rocking the machine, if it wobbles, the feet need adjusting to level the machine. It will cause damage in the long run if not levelled.
Dec 09, 2010 | Washing Machines
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite smart Wash quiet pak 9 has got the control panel set to lock mode. How can we open it?
The LOC code merely means the control responded and locked the door. You'll find a tech sheet under the top panel of the machine to help guide you thru the diagnostic process, which is fairly involved.
LOC means it thinks the control panel is locked. This gives the ERR indication when you push the buttons. To unlock it you need to hold down the Options and Select buttons together until it reacts.
I know this may seem silly but - On the top right back corner of your washer hit it with medium force with your fist, this helps.
Jun 27, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
