New toner - big spots on printed pages - Office Equipment & Supplies
SOURCE: spots on page
You need to clean the drum unit (use a soft cloth and/or a soft paint brush) and also slide the blue slider a couple of times to clean the wire.
Posted on Oct 20, 2007
Mrvica
  • 167 Answers
SOURCE: Printed document has light spot running down entire page
you ****
Posted on Aug 20, 2008
SOURCE: Toner not refreshing
I replaced the toner, but it still says toner life ended open front cover and repalce with new one. How do I resolve this
Posted on Dec 27, 2008
SOURCE: Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Posted on Apr 11, 2009
angelus316
  • 41 Answers
SOURCE: HL-5240 is printing a big black line down the page
CHANGE THE DRUM UNIT.iT IS THE UNIT THAT THE TONER CLIPS INTO.
Posted on Jun 26, 2009
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
Hp cm2320 printer toner cartridge leaks spots
lousy answers all of them. There can be two things happening. One I have not found a cure for yet. First replace the toner cartridge, even if you just replaced it. This should resolve it. Just because you might have just replaced a toner cartridge does not mean it is not faulty.
The second part to this problem I have seen is when you print a demo page it looks fine but when you print a usage page or configuration there are speckles. This one I am working on. Yours is most likely just a faulty toner cartridge. Seen it many times.
Dec 18, 2012 | HP Laserjet CM2320nf All-In-One Color...
My HP 4ML has been printing fine until recently. Every print job, big or small, the first couple of pages print the pages mostly black, then start to fade the more pages I print in the same print job. ...
You didn't say that you swapped out the toner.
Let's come back to that point later.
Put paper in the manual feed tray.
Print something.
As soon as the paper feeds halfway into the printer, open the top cover.
Pull out the toner, look down at the paper. Is it mostly black?
If the answer is yes....replace the toner.
Vacuum out the inside of the printer and print again.
I think you have a bad toner cartridge
Feb 01, 2011 | HP LaserJet 4ML Printer
Apr 10, 2009 | Samsung ML 2010 Laser Printer
I think I damaged the drum, is this a recoverable error?
try printing 10 test pages and see if it gets at all better by the tenth one, you may need a new printer cartridge though, if you are buying refurbished toner cartridges you get a bad one every once in a while but you can usually return it
Feb 17, 2009 | IBM Infoprint 1332 Laser Printer
Oct 24, 2008 | Brother MFC-7820N Laser Printer
HP Color LaserJet 2600n Printing Problem!
franko21:
It sounds like you are having an issue with your fusing assembly. Here's the check you need. Measure the distance from the original print on the page and the exact spot where the repeat ghosting (same spot) appears on the page again. Here's the distances that identify the part having an issue. My guess and experience with this printer says it's probably fuser. Seen a lot of 2600n printers with image ghost problems and almost all are fuser related.
2.22" or 56.6mm = Fuser Upper Film
2.47" or 62.8mm = Fuser Lower Roller (Usually Backside)
2.97" or 75.4mm = Toner Cartridge - Drum (Usually One Color)
0.97" or 24.7mm = Toner Cartridge - Developer Roller
1.05" or 26.7mm = Toner Cartridge - Primary Charge Roller
2.15" or 54.5mm = ETB - Transfer Belt (Big Belt on Door)
If it should be the Fuser or Transfer Belt, consider not replacing the part as the minimum cost for either (part only) is $105.00 before shipping. The better alternative is to jump on Ebay and buy a HP refurb or new machine MINUS the supplies. They come with the Transfer belt and fuser. They are cheaper for the full machine than the replacement part. They average about $65.00 thru $90.00 landed.
Hope that helps you. If so, hit me with a FIXYA.
Aug 25, 2008 | HP Color LaserJet 2600n Printer
Spots when printing
It sounds to me like you may have 2 low or defective toners, the Cyan and the Magenta. If you have another machine like this available to you try swapping these 2 toners out to test the theory or you can take these 2 toners out and spin the drum manually (by only touching the gear) checking to see if the spots you see on the pages correspond on the applicator roll of the toners...
May 09, 2008 | Lexmark C524 Laser Printer
Draft mode?
start->control panel->printers and faxes->right click on lexmark E232->properties->advanced->printing defaults->print quality->draft->OK->OK.
Jan 12, 2008 | Lexmark E232 Laser Printer
Aculaser C1900
Sounds like you have a spot of toner on the laser lens. Pull out the waste toner bottle and toward the left of center you will see a little handle sticking out. This is the cleaner pads that wipes the lens. Pull it in and out a few times. Put the waste bottle back in and print a page or two. you should find your good as new again.
Sep 07, 2007 | Epson Aculaser C1100 Printer
23 people viewed this question
k24674
jasbo
jasbo
