https://www.facebook.com/help/131930530214371/?ref=u2u
What is blocking? What happens when I block someone?
You can block someone to unfriend them and prevent them from starting conversations with you or seeing things you post on your profile.
People you block can no longer:
See things you post on your profile
Tag you
Invite you to events or groups
Start a conversation with you
Add you as a friend
Blocking is reciprocal, so you also won't be able to do things like start a conversation with them or add them as a friend. Keep in mind that blocking someone may not prevent all communications or interactions, such as in apps or groups, and only affects your experience on Facebook, not elsewhere on the web.
Note: Removing a block will not restore the friend connection. If you block a friend and then remove that person from your block list, you'll need to send them a new friend request.
More info Get help for mobile apps and browsers Permalink Ā· Share
Tag you
Add you as a friend
Click in the upper-right corner of your homepage and select How do I stop someone from bothering me?
Click View Al l Blocked Users.
Click Unblock next to the name of the person you want to unblock.
Note: This will not automatically add the person back to your friends list. If you want to become friends with this person again, you'll need to send them a new friend request.
There are 2 ways to block numbers:
1. Go to Menu. Settings. Call. Call services. Call barring settings.
There you can block outgoing or incoming call groups using your provider's network settings.
2. Press menu, and then tap All friends.
In the Friends list, press and hold the friend's name you want to block.
Tap Block friend. Your friend is removed from your friends list and is added to the blocked friends list.
That is because you blocked him. To remove your friend from the blocked list, go to Account > Privacy Settings > Block Lists then edit your lists. Find your friend's name and click Unblock.
Your post is not so clear.Has your friend blocked you or have you blocked him?
I will answer you keeping both cases in mind.
If your friend has blocked you on facebook then it is not in your hands to get yourself unblocked. Your friend has to unblock you from his facebook profile.
But in case you have blocked him from your facebook profile then you can unblock him in the following manner. Go to your facebook site. Click on the 'Account' tab on the upper right hand corner of your website. Go to Privacy Settings - Block List - remove the name of your friend which will be listed there.
A block prevents specific people from viewing your profile. Any ties you currently have with the people you block will be broken (friendship connections, friend details, etc.). Your profile will not be visible to them and you will not appear in their search results or friend lists. Blocking is mutual, so they will also become invisible to you as well.
Keep in mind that blocking someone may not prevent all communications and interactions in third-party applications, and does not extend to elsewhere on the Internet.
Please note that removing a block will not restore a connection. If you block a friend and then remove that person from you Block List, you will need to send them a new friend request.
http://www.facebook.com/help/?faq=12253
