Question about Acer Aspire Computers & Internet
Overheating laptop fan working okay no blokage
How to repair
    Top Expert:
  • Acer Master
  • 6,702 Answers
Perhaps the terminal grease, supposed to be between the processor and the cooling body, has dried out, or is not there anymore. I would switch the laptop of till this is solved, to avoid damage on the processor.
overheating laptop fan working okay no blokage - 25647965-1fs3po2aj2tntmie5lqsi3vv-3-0.jpg
Posted on Apr 15, 2015
No power - blown fuse?
If it was run without the fan a thermal protect device was more than likely taken out. Check for that and replace the fan.
Mar 25, 2013 | GE Profile Spacemaker XL 1800 36"...
The fan on my laptop is not working at all my computer keeps overheating and turns off
Probably your fan is full of dust. You have to disassemble your laptop and use an air blower to clean it. Or go to a local repair shop.
Fun not running means your cpu is overheating, and it automatically shuts down your laptop. You have to repair it as soon as you can, otherwise you risk frying it all.
May 14, 2011 | Dell Inspiron 1545 Notebook
Overheating my car continuously overheat
CHECK FOR LOW COOLANT LEVEL AND REPLACE THERMOSTAT AND THE RADIATOR PRESSURE CAP.IF CAR OVERHEATING AND COOLING FAN NOT WORKING.CHECK COOLANT FAN FUSE AND RELAY.IF BOTH OKAY,HOT WIRE COOLANT FAN,IF FAN WORKS, PROBLEM COULD BE FAULTY COOLANT TEMPERATURE SENSOR,OR FAULTY PCM, IF COOLING FAN DONT WORK WHEN YOU HOT WIRE FAN.THE COOLING FAN ASSEMBLY NEED REPLACING.
Apr 22, 2011 | 1993 Lexus Es 300
The above as over heated and seems to fail after about ten minutes of being on this is an intergrated card can it be fixed without replacing the motherboard it is in an asus laptop.
I suspect that your cooling fan has stopped working or the sealing mating between the fan surface and the CPU is not intact. These fans quit working because dirt and grime gets into the fan shaft and friction slows the fan . also if the fan gets accidentaly moved on the CPU, then this breaks the heat transfer tape between the CPU. This over heating causes the CPU to fail. Open the machine and observe if the fan is running correctly.
Apr 14, 2011 | Computers & Internet
I have a 1999 Oldsmobile Alero GL Sedan that is overheating. Where is the problem?
check coolant level, make sure car have half antifreeze and half water,if coolant level okay, car overheating when starting up driving is faulty thermostat and radiator cap.if car over heat while sitting in long line of traffic.your coolant temperature sensor could be faulty, or coolant fan fuse blowed or relay failed.hot wire cooling fan if it works, problem is the wiring or pcm, if every thing working okay.check engine oil if look like milk shake or you have a lot white heavy smoke coming out the exhaust, you have a blowed head gasket.
Apr 08, 2011 | 1999 Oldsmobile Alero
Turning off in 2 minutes automatically
My guess is that the fans inside the computer have stopped working, thus leading to the overheating. AMD processors generally run "hot" (50 to 60 degrees Celsius) even with proper fans.
Take your computer to a qualified technician, for a cleaning, and proper trouble-shooting, and repair, before the overheating causes permanent damage.
Jul 27, 2010 | HP Compaq Presario 2100US Notebook
Compaq presario m2000 overheating, broken fan.
Overheating issues are considered as safety issues and are take very sincerely by Computer manufacturer. Generally, overheating occurs due to any mechanical fault. So, you may contact the customer service of the Computer manufacturer to get any sort of assistance.
Nov 17, 2009 | Computers & Internet
Overheat and switches off automatically
check the cpu fan it is not working properly need clean sometime full of dast that why always became heat. epected of overheating is automatically shut down...
repair you cpu fan disasimble you laptop then check the cpu fan
thanks
Jun 01, 2009 | HP Pavilion DV5-1000US Laptop
CPU fan not working
you need to check your power supply if this is okay you need to replace the cpu fan. the cause of shutting down is the overheating of your cpu
Jan 06, 2008 | Acer Veriton 5200D PC Desktop
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
