My Kenwood Split AC Crystal series has too loud beep of turning ON & all functions, that whenever I press any button on remote the sound can be hear out of the closed door.How can I reduce its sounds?
  • 61 Answers
SOURCE: AS12S4GB AIR CONDITIONER 4 BEEPING
when you restart the unit monitor the outdoor unit and see if the compressor and outdoor fan starts up . before the beeps . you can try reseting everything by disconecting all power to outdoor unit .
hope this helps please leave fead back / keep me informed
Posted on Oct 20, 2008
SOURCE: Door will not slide automatically; emits loud beeping noise
Something similar to that was happening with our Odyssey...the beeping when you are driving whether it's ongoing or intermittent is the "safety alarm" letting you know the door is not closed. The power lock is not engaging. What I do when I get the beeping while driving is hit the Door Close button. It causes the door to attempt to engage again. To fix it...we first cleaned out the space below the side running board (kids were hiding crayons and things in there), then looked for any obstructions along the top and bottom tracks. I sprayed a lubricant along the tracks (I'd suggest the dry lube kind...I used WD40 the 1st time and had streaks of it dripping down after driving), use a lube that has a long straw to spray in small places...and spray up into the track that runs the length of the middle of the car. Manually open and shut it a few times to get the tracks lubed, then try it out.
If you press the open OR close button by remote or in the car and get nothing...no movement/no noises/no beeping...then it could be the electrical circuit itself, the signal itself may be impeded...or the motor shot. Have you tried any of these suggestions before?
Posted on Mar 22, 2009
darjr
  • 378 Answers
SOURCE: how to operate lg split 1.5ton ac without remote
you can buy a universal remote control.
Posted on Jun 16, 2009
  • 81 Answers
SOURCE: LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Posted on Jul 20, 2009
  • 13 Answers
SOURCE: rear hatch will not unlock on my 05 Denali
Check the unlock mechanism for the hatch. These are controlled by an electrical motor pulling a cable. If the cable came loose you might or might not hear the click click that it makes. I would also check the fuses and relays related to the system. Usually if you can get the interior panel off all the innards are exposed. I would suggest pulling that panel off, then triggering the keyless remote and see if anything moves, that might pinpoint where it has gone bad.
Posted on Sep 28, 2009
How to remove filter light in Hitachi split AC
Ensure you replace the filter on the AC or
How to clean filter of split AC
When its turn off,not unplugged, press at the same time ''Function Button" and the ''AUTO Swing" button on your Remote Controller.
Apr 10, 2016 | Hitachi Heating & Cooling
How do I turn off the beep of the remote?
I'm not sure if this help you but I found a user Manual .This should have everything you need to know. If this doesn't help then check out at AC Repair Boca Raton and they can assist you.
Mar 03, 2015 | Samsung Heating & Cooling
Pressing the CAPS LOCK or NUM LOCK there is a beep.
launch the Toggle Keys dialog box by holding down the Num Lock button for five seconds, and clicking Yes. Thereafter, a loud beep will sound through your computer's speakers whenever Caps Lock is turned on or off. (To turn Toggle Keys off, once again hold down your Num Lock button for five seconds.)
Nov 11, 2013 | Toshiba Satellite Computers & Internet
Help have onix split system air con and remote not working and it s the only way to turn it on have tried every where to get one model no is TEM-84CHSBE heat unbearable in summer nth qld aust.
Auto-restart Presetting:
The appliance is preset as no auto-restart function by manufacture. If Auto-restart function is needed, follow the
step below to activate this function:
1) Make sure the Air-con's power is off:
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify.
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard.
The Auto-restart function is then activated. To cancel the Auto-restart function, repeat above procedure until four
Remarks: When remote controller is out of work, open the panel and you can see emergency button there, see the
The emergency button for 50, 70, 90 series is at the top right, see " ON/OFF " button there.
Auto-restart set:
the appliance is preset as no auto-restart function by manufacturer. If Auto-restart function is needed, follow the
below step to activate this function:
1) Make sure the Air-con's power is off .
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify .
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard, then Auto-restart
function is activated. To cancel the Auto-restart function, repeat above procedure until four short beeps are heard.
Oct 31, 2011 | Heating & Cooling
I have the phonemate 2970 answering machine/phone and satellite extension phone. When I turn the sat phone on I get a series of beeps and the HOLD light flashes for about 6 times then shuts down. I...
1. Remove the AC adapter plug from the back of the base unit (not from the wall); leave tel cord connected.
2. While holding down the "set code" button under the cassette lid, plug the ac adapter back into the base. The screen will then display some numbers (110) etc.
3. Hold down the HANDSET keys 1 and 2 simultaneously and then press the speaker button on top within 20 seconds.
4. Press any 3 digits on the handset i.e. 1-2-3.
5. After hearing a BEEP from the handset and base, press 2 on the handset. The base should then say "twenty-five", and the handsets will beep, confirming the new security code is enabled. Press talk or speaker on handset to confirm communication.
6. The time/day stamp and remote access code will be cleared.
7. Best to do this with the answering mach turned off.
8. Restart this procedure if anything goes wrong (may hear a series of error beeps).
I saved my manual and in it I had a fax Casio sent me with these instructions (i had this prob a few times years ago). Good luck!
Jan 18, 2011 | Casio PhoneMate PMP3875BK
I have purchased a whirlpool 1.5t ac in Jun09. I
Sounds to me as if there is a wiring issue due to the constant beep. I would suggest the replacement of the unit due to that fact alone. Could possibly be a fire hazard.
Good Luck
Dave
Aug 11, 2009 | Heating & Cooling
DELL Latitude D400 - what are the series of (blinking) icons?
sometimes this indicate a fault with memory or the system itsef.Before you begin you will have to remove the battery and the ac adapter.Remove the memory modules .Replace the battery and the ac adapter without the memory.Power it on if it comes on and beep several times then the memory is bad.If not remove the battery and the ac once again.Press and hold the power button for twenty seconds to clear the nonvol memory.Replace the memory the battery and the ac adapter.If still no go remove all the same items along with the hard drive and cd rom,Insert the battery and the ac adapter try again.If you hear a beep this time replace the battery(remember whenever you install to remove power).If nothing works and you none of the desired results you will have to replace the motherboard.
Good luck
Jul 16, 2009 | Dell LATITUDE D400 D500 D505 D600 D800...
`remote does not turn on the ac
you probably have a battery problem on your remote or the battery contacts. the is a easy way to test any remote control. Find a old AM radio the smaller the radio the better make sure is on AM and tuned to a station where you hear just static then place your a/c remote close to the radio and press any button. you will hear a beeping sound coming from the radio if you hear noting do the same whit your TV remote "just as a reference". if you hear nothing different from your AM radio then some thing is wrong whit your remote if you do hear some thing, then there is some thing wrong whit the a/c unit receiver.
Jun 11, 2009 | Heating & Cooling
Split AC 1200-BTU Kenwood Model ANK12P Pearl series Power lights ON but Unit does not become ON. Its power LED becomes ON but buzzer does not beep as it beeps with normal power ON,and no response from...
hi keen,
let me help you as I can,
first check your remote unit if it is transmitting a signal by looking at the front end of the remote using digital camera or cell phone camera, you should see a light coming on in the front end of the remote.
if there is none then the problem could be from your remote.
keep me posted thru the "ask me" button
tnx 4 using fixya
drcool
Sep 06, 2008 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
