Question about Citizen Watches Citizen Eco-Drive Perpetual Calendar Chronograph Mens watch BL5403-54E
The stem on my citizen watch is turning but not changing the time or date any ideas what is wrong ?
  • Anonymous Apr 15, 2015
    I have tried that when pulled out the stem is just clicking and not moving hands or date
    Top Expert:
  • Citizen Watches Master
  • 51,154 Answers
Put your finger nail under the crown and pull it out a bit ,then turn it to adjust the hands . when finished push it back in
Posted on Apr 15, 2015
Testimonial: "I have tried that when pulled out the stem is just clicking and not moving hands or date"
I need to change the date
Changing the date for the FT500WVB watch is easy. Just pull out the stem of the watch to its first stop. Then turn the stem counter clockwise a couple of twists and the displayed date will increment (that is increase) by one day and you will hear a little click. Keep twisting the stem counterclockwise and the date will increase by one each time with a little click. Stop when you reach the correct date and push the stem back in to its fully seated rest position. Note- be careful not to change the date when the watch displays a time between 9pm and 1 am as setting the date in this time range may cause the watch to increment the date at noon rather than midnight.
Note also that if you want to set the time you just pull out the stem to its second stop position and twist the stem to advance the position of the hands of the watch. Then when the time is set, push the stem back in to its lowest rest position. So remember- first stem stop sets the date and second stem stop sets the time. That's it.
Mar 25, 2014 | Casio Forester FT500WV-3BV Wrist Watch
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 09, 2010 | Watches
Fix date n month on wrist watch
mcdevito75 here The stem has 2 positions, we all know the 1 to pull the stem out and set the time, day, date. try this, first go thru the watches 24 hour cycle to get the month you need, now slip a fingernail just under the stem (crown) and gently lift to it"s first position, it may take a few times to get used to, when you have it turn the crown (stem) to change the date easily, change the date to 1 date before the date you want, now go thru the watches 24 hour cycle to get to the date you need. Now the watch is set and will change on time at around mid--nite.
Jul 19, 2010 | Pulsar 5117 Wrist Watch
Unable to reset brietling colt, even after ajusting stem to 1st and 2nd postions.
mcdevito75 here, Let"s hope your description of the problem with your watch is wrong. Try this sequence, First, wind your watch, the automatic continues to wind your watch when you where it but to get it started, wind it 20--30 times. 2nd, your crown locks down, turn the stem Clockwise to un-lock it (the stem) now pull the stem all the way out then back in 1/2 way to set date. Set DATE to DATE before the real date turn crown counterclockwise. Now pull out crown all the way and turn clockwise to set the DATE and time (real Date) push the crown back in and turn counterclockwise to lock the crown. If this doesn"t work, look for a small watch repair shop in your area for this adjustment.
Jun 28, 2010 | Breitling Aeromarine Colt Ocean A64350...
I just purchased a vintage Seiko automatic DX and I can't figure out how to change the date and day that appears on the watch.
mcdevfito75 here"s how to change the day and date on your vintage Seiko watch, Pull the stem out to the set position and simply turn the stem (winder) every second time around to the 1--2 3 O"oClock position the day will chage, once you get the day push in the stem in all the way, NOW with your fingernail just under the stem (winder) gently lift the stem up to it"s first notch or position, with the stem at this first notch or position, you can turn the stem and the hands won"t move but the date(number) will change, simply go to the correct number / date and your done, push the stem back in a your ready to go.
Jun 22, 2010 | Bulova Watch
Cant set the date to one day before
Pull the stem out gently until it clicks once. Turn counterclockwise until the correct date appears. Pulling the stem out to the second/last click adjusts the time.
Jan 15, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
I have a citizen eco drive watch.. the day is 17 when it should be 16. How do I set to the correct day of 16 ?
When you pull the stem out it should "click" once to adjust the date and pulled farther to adjust the time. Pull to the first click and rotate counterclockwise until the correct date appears. push stem back in.
Jan 15, 2009 | Watches
How do i set the date on a citizen calibre 8700?
just full half the stem and wind the crown until the date move
Aug 25, 2008 | Citizen 8700 BL8000-54L Wrist Watch
Changing the DAY on this analog watch.
Turning it backwards didn't work on my watch. I ended up winding the time ahead several days worth to show the right day of the week (being careful to turn it to the correct 9 o'clock of the day, for me is was the first for morning.) Then I could go ahead and change the date using the first click postition of the stem.
I see that light bulb going off and you whispering "why, of course!"
Dec 03, 2007 | Watches
Citizen Watches Citizen Eco-Drive Perpetual Calendar Chronograph Mens watch BL5403-54E Logo
133 people viewed this question
Top Citizen Watches Watches Experts
alwaysreddy
Bill Boyd
Are you a Citizen Watches Watch Expert? Answer questions, earn points and help others
