Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
Bulges in one area can it be fixed - Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
  • Intex Master
  • 1,631 Answers
What do you mean 'Bulges' and... In what?
Posted on Apr 16, 2015
Testimonial: "intex spa bulges on one side is there a way to fix it"
  • Mike Tellegen Apr 16, 2015
    I would call their customer service dept and speak with someone, and squeak loudly. Hopefully they will assist you! If it were me... I would keep emailing them and calling their USA Sales Office!!! http://www.intexdevelopment.com/index.ph...
No picture on murphy 26 in flat screen
Check with a flashlight held near the display area. If there is a movement (assuming you get the audio portion.) the issue lies with the inverter section of the power supply for the backlight.
You can open the set up and look for some bulging capacitors on the power supply board and the inverter. Replace any that have bulging or otherwise damaged tops, and those int he immediate vicinity of it. With some there might be some dark brown or black residue, bulging or not- replace those as well.
Dec 29, 2011 | Televison & Video
We have a 50" vizio
You might what to check the power supply module, for bulged electrolytic caps, on the power supply module.
Mar 01, 2011 | Vizio Televison & Video
The screen comes on for about 5 to 6 seconds then goes to a sleep like mode,,,but if i tap the input button the next mode i choose will do the same thing
It's very likely a problem with some of the capacitors in the power supply area. You can search for similar fixes here on this site. I'm ordering parts now for mine. Two of the eight tall/blue capacitors in a bunch have tops that are bulging (but I'll replace all eight since they're cheap). There's a pair of two in the middle of the same board on mine with bulging tops and there are four transistors in that same area that look like they got too hot. Most people seem to be getting away with only replacing the bulged capacitors but here is my total part list from digikey.com:
785-1106-1-ND quantity 2 (the D405-marked transistors) 785-1114-1-ND quantity 2 (the D408-marked transistors) P12389-ND quantity 8 (the 470uF capacitors) P12383-ND quantity 2 (the 220uF capacitors)
The total part list is about $7.50 with another $2.50 or less shipping. It's a pain to take apart, given the small connectors inside. The fix assumes you have soldering skills.
Go with these from digikey versus Radio Shack. They're rated for 220 degrees fahrenheit versus only 85 degrees and they're about a third less cost.
Feb 06, 2011 | Gateway FPD2185W 21 in. LCD Television
I have purchased one Getz Prime in July 2007.Paint Bulging (Blister)observed on Right Rear Doorin the Inter Space of Door Handle and the Quarter Glass. This is a Clear Sign of Propagation of Corrossion...
Given the age of the paint unless it has been completely repainted already, it is NOT cost beneficial to fork out the money in attempting to fix the oxidizing paint in the indicated area. Even if you did fix the area, once a vehicle starts to shows signs of this deterioration, it is a clear sign of the age of the paint job. Thus, with the cost of paint rework, it is not in your best interest to have this professionally fixed. However, you may want to attempt to fix it yourself by bringing the immediate area down to the shell with a trusted grid sandpaper kit. Then you may always patch it yourself for about 5 percent of what it would cost to do professionally.
Jan 24, 2011 | 1989 Hyundai Excel Hatchback
Sony Triniton 1997 TV worked fine until Saturday. Now no image or sound. can it be fixed?
Yes! I find in most cases it is due to bad capacitors in the power supply and high voltage area of the set, sometimes the capacitors develop a bulge at the top which indicates they are open.
Jan 17, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The monitor screen will not come up with the computer it turns on but will not boot up. The model number is fpd2185w
The problem is more often than not cause by the processor failure. But check the VGA cable for tamper or cuts.Try dismantling the board from all the serial bus, ATX wires and others.Clean up the whole system with a blower ( Remember to apply a good thin layer of heatsink compound paste on the processor and and re-install the whole peripherals. Then power on the system and try bringing up the BIOS setup. If that comes up fine, then re-install the OS an enjoy. Otherwise you need to get a new processor.
Sep 01, 2010 | Gateway Computers & Internet
My tyre are overair and it expanded?who can i fix it?this happen a week ago.i try to make it back to it shape and low it presure but it still expand..
I think that your tyres are faulty as the volcanisation of the tyre is uneven. It will be good to show your tyre to the manufacturere or if the bike is new to the dealer for a replacement.
Once the tyre has bulged then it is softened on this section as it is uneven and can be dangeorus.
You can use within the bulge area an inner casing but this will make the tyre unbalance and the riding will be diffficult. So dont attempt this method.
So please check this out and hope my advice helps. Good day
Aug 17, 2010 | 1996 Yamaha XJR 400
Gateway power up issue after standby
Most common parts that go bad are rge DC filter caps in the power supply and in the inverter circuits, that will be th first place to look, see example of failed monitors due to bad caps here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jul 09, 2010 | Gateway FPD2275W LCD Monitor
The screen picture bulges inwardly on the right and the left
you have defective horizontal linearity! replace the capacitor at the hot side mostly 160uf 180V or 160uf 160V.
Oct 02, 2007 | Recoton Advent Advent Q2035A 20" TV
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
151 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Charles T Nevin
Charles T Nevin
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
