Question about Miele Dishwashers
I have a miele g 641 sc plus dishwasher and it isn't heating the water but is heating to dry the dishes. Are there 2 separate elements?
  • 14 Answers
SOURCE: Miele G892 SC dishwasher not heating/cycle won't stop
could be heater pressure switch
Posted on Sep 15, 2007
  • 54 Answers
SOURCE: Dishwasher element?
dispenser is not linked that will be the solinoid valve on the dispenser. the heater could be open circuit or on the side of the wash motor is a pressure switch that is common for blocking so it will not put the heater on.
Posted on Feb 12, 2008
taran_2005
  • 10515 Answers
SOURCE: How is element removed from Miele Dishwasher
Procedure to remove element :)
http://www.acmehowto.com/howto/appliance/dishwasher/repair/heatingelement.php
Thanks.
Posted on Jan 06, 2009
  • 128 Answers
SOURCE: I have a G656 SCi Miele Dishwasher and the water
Probably the heater relay - do you have any fault codes?
Posted on Sep 23, 2009
  • 230 Answers
SOURCE: Miele dishwasher G646 SC plus water pump
I would suggest any appliance repair shop or appliance retail store should be able to order one in for you
Posted on Sep 06, 2012
Does the Miele G665 dishwashers have a heat element as no heat is coming from my dishwasher
If it like other Mieles, it has an element to heat water if required to reach cleaning temperature, but does not have a drying element. Even then, it should give off some heat in the drying cycle and be hot after finishing.
Nov 17, 2014 | Miele 24 in. G665 Built-in Dishwasher
Water not heating up and not drying
Hello
If your dishwasher is not heating properly, troubleshoot the issue. You can often repair this problem and eliminate service fees.
Incoming Water
Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat
The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan
The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Additional Concerns
If your dishwasher isn't drying your dishes properly, see if you have selected a heated drying cycle. An air drying cycle doesn't completely dry your dishes. Never overload the dishwasher, as this prevents heat from circulating around your dishes, keeping them from drying properly. Plastic and Teflon dishes don't usually completely dry. You must towel-dry these items.
Sep 12, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not heating water already replaced in line heater element no change
Hello
Possible causes;
Incoming Water; Most manufacturers recommend that the water coming into your dishwasher be at least 120 degrees Fahrenheit. If the water is too cold, then your dishes don't clean properly. Or the dishwasher must run longer to heat up the water. Test the water temperature by running the hot water on your faucet for about 2 minutes or until it gets really hot. Place a waterproof thermometer under the water. If the water is too cold, increase the water temperature setting on your water heater.
Thermostat;The thermostat is responsible for regulating the water and drying cycle temperature. If this thermostat isn't working, the heating element at the base of the dishwasher tub may not come on. Test this element by selecting the hottest temperature setting. Run the dishwasher on the shortest cycle. Let the dishwasher run for a few minutes, and open it up. If the dishwasher water is not hot or the drying cycle isn't starting, order a new thermostat from a parts dealer since this component is difficult to fix.
Heating Element/Drying Fan; The heating element heats up the water and air. Access this element by removing the bottom rack. It looks like a long black rod. If any part of this component is broken or corroded, you must order a new one. You usually cannot fix this element. The drying fan is located in the main housing of the dishwasher, and it blows air around your dishes to dry them. Check this part by disconnecting the dishwasher from the power supply and opening up the housing. Examine the fan, and see if any dirt or debris is preventing it from moving. Clean it. If the fan won't turn at all or if the motor is burnt out, order a new fan since it's difficult to repair this part.
Sep 07, 2011 | Westinghouse Dishwashers
My miele dishwaher is not heating the water thus not wahsing the dishes properly
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Apr 26, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Miele 2142 - rinse aid not being completely rinsed off dishes. Water glasses left with bad taste and must be manually rinsed to remove any residue
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 06, 2011 | Miele G 2142 SC 24 in Builtin Dishwasher
White film on dishes and still dirty.
Check rinse aid is actually dispensing - turn it up to max for a while to clear it, and check level is going down after a week.
If you suffer with hard water - your heating element may need replacing as it is probably furred up.
Jun 06, 2010 | Miele G892SC SS Dishwasher
Miele G 880 SC -- dishes not drying
Make sure you are using rinse aid. even if you are using tablets which has rinse aid built into the tablets Miele still recommend using rinse aid liquid as well.
Make sure you have the rinse aid setting on 3ml
Plastic will not dry as well as plates as it doesn't hold the heat.
You could call out a Miele service tech if it is still under warranty and he would be able to increase the drying time through his computer.
Hope this helps.
Mar 20, 2010 | Miele G880 Dishwasher
Aug 24, 2009 | Miele 24 in. G656SCi Plus SS Built-in...
No hot water, plates cold and dirty and wet
If you've installed it recently make sure the hot water tap was plumbed in and not the cold water tap, check the hot water tap temp in the house to make sure it's getting warm, there also should be a heating element located inside of the dishwaher that heats up to help the dishes dry at the end of the wash cycle, which is controled by a thermostat. If the heating element or the thermostat are bad your dishes won't dry.
Mar 25, 2009 | Miele 24 in. G638 Plus Free-standing...
Miele have cold inlet only. Either element is open circuit, or the relay that switches the element has failed. My money would be on the element first, then the relay. The machine will sit in that mode forever as it is waiting for the temperature of the water to reach a certain temp before telling the electronic unit to move to the next part of the wash. If you need assistance in how to test & how to get to these parts just let me know. But you will need an ohm meter to test the element. Regards
Aug 20, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Dishwashers Logo
94 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
