Machine heats up but no steam being produced. Used it yesterday as part of spring clean
Likely the steam switch. Having the same issues. Flick the switch or shake the steam it and see if you can get it to produce stream. If so its the switch.
Posted on Nov 24, 2015
Https://sites.google.com/site/mayweathervspacquiaolivefight/-hbo-tv-manny-pacquiao-vs-floyd-may-weather-jr-live-stream
Posted on Apr 15, 2015
Steam mop is not working, even after replacing the filter. Only used three times.
Rejoice with me! I called the helpline and they told me to unplug, then stick a needle into the hole on the bottom where the steam comes through. I did that, then plugged in and turned on the steam. Black liquid came out and a little steam came out. I shut off the machine, unplugged and used the needle again. This time, a geyser of steam went up into the air from the machine! It was clogged and just needed a couple of pokes. I put the steam plate back on and just cleaned my kitchen!
Jan 26, 2014 | Oreck VersaVac Bagless Vacuum / Steam Mop
The milk steamer is not frothing. I have tried cleaning and descaling
If it does not produce steam when you switch to steam mode and wait for it to heat up, the steam thermostat needs to be replaced.
Mar 03, 2011 | Krups Espresso Novo 2100
Machine will not produce steam. Machine will heat up but not enough to produce steam. Help ...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
;a
Jul 31, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Cannot produce steam
The machine have a separate heating system for steam than hot water for steam. The steam system it might be full of scale. If you hand are good you can easily remove top panel and side panel. You can follow the teflon pipe from the steam wand and it will lead you to the steam solenoid valve and the small copper steam heating system and desasemble it both the valve and small boiler and remove any scale and dirt from it using a wire brush, shurp screwdriver and similar tool. Then poot them back together. You can try the machine with panel removed so if it needs something more to try once more again. One small tip advice. Use your camera and make pictures of everything before desasemble them, then you are safe if you forget about something. In this way you can clean everything metalic that the water pass though.
May 11, 2010 | Saeco Vienna De Luxe Espresso Machine
What happens if I use CLR in my steam iron? I have an expensive European style iron which is no longer producing steam. I have bought an iron descaler/cleaner and have repeated its use. I tried the...
The steam tank may not be heating because of mineral deposits in the tank. But also do this check first. Open up the tank reservoir cold, and drain all water out, (is it clean inside there when you shine flashlight in there? Rinse with clear filtered water only (low minerals).
Do not use CLR or anything agressive in there. You should have the main unit in full steam mode and the iron control also in full steam mode. Leave one tablespoon of water in the tank, put back together and let the pressure build. Put a clean towel on your ironing board and when iron is at full pressure and heat, hit the burst of steam and look at what comes out of the sole plate. If you see lots of white deposits look at the sole plate and see if the white chunks are coming out steam holes.
When using iron, run it till steam/water tanks are dry, the burst of steam is used in this case to clean the iron of all standing water. Pull the reservoir and allow to cool...once tank is cool drain it as well. Doing this several times should help purge unit of the heavy mineral deposits.
If you need parts, here is the Rowenta repair facility....
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Mar 12, 2010 | Rowenta DG-980 Iron
MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
Jul 25, 2009 | Rowenta DX6700 Iron
Shark steam mop
I had the same prob and found this site off google looking for the solution.
I went back to my shark and took out all the screws, some don't feel like they were coming out but it came apart. Take a pair of pliers and release the spring clip holding the hose to the heat nozzle. Then pull off the hose. Then take a paper clip, unkink it so it's sort of straight with a curve to go into the hole . Shove it in and out to clean out the hole. I got my fingers blasted with residual steam so you should let it cool first. But I think the steam bursting out helped clean out the hole. Don't throw it away till after you try that..It worked great after that. All the best, Satch
Oct 09, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
No steam, just hot water.
The steam wand has to be removed to be cleaned properly. Unfortunately, this procedure is not outlined in the manual. Just cleaning the wand on the outside or using a clip to clean the tip is not enough.
The other end of steam wand where it connects to the pressuring cabin actually swivels around a fitting. It is this fitting that you need to thoroughly clean. Years of using the machine can cause calcification around this fitting.
If you look under this end of hte steam wand, you should see a philllip-headed screw. Before you loosen this screw, you have to remove the grey trim so that the entire wand can be remove.
Once the entire wand is removed, what I just described will be much clearer.
Nov 10, 2007 | Breville ESP8XL Espresso Machine
Heating & Cooling Logo
1,865 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
