My tali h500 was not binding with the controller,so switched it on/off many times with no luck. now the LED lights are not even blinking when I switch it on. please advice on what the problem may be
    Top Expert:
  • Televison & ... Master
  • 74,118 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 15, 2015
  • 670 Answers
Hi Muayad,
There is nothing you can do about it yourself. Please consult some Service Tech.
pilot210
  • 39 Answers
SOURCE: Standby LED blinks 4 times
4 blinks on a Sony Bravia indicates a backlight/inverter (aka ballast) problem. These ballasts are regrettably only available with an entire LCD panel. :( You may perchance be able to find a parts outfitter online that scraps out TVs and have a used ballast.
Typical backlight problem on an LCD shows up as the screen lighting up for a second or two and going back off. The 4 blinks just confirms your problem.
Posted on May 19, 2009
budmrtn
  • 11361 Answers
SOURCE: Flashing power light
Unplug it from the wall outlet for about an hour and try again, if nothing changed, then you will need to do some troubleshooting. Check the power supply voltages first to make sure they are all OK.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 07, 2010
ekcnoel
  • 998 Answers
SOURCE: My TH-58PF12UK will not switch
it has a leaky transistor try to check the transistor besides the regulator.
Posted on Oct 12, 2010
jdvillanueva
  • 2098 Answers
SOURCE: Hi Sir My TV ( Hyundai
Hi sitinurulsha,
Just for clarification, does the unit power on fine sometimes with no problem. Does your tv now can't power up or stuck to standby mode? Let me know to assist you further...
Jdvillanueva
Posted on May 09, 2011
diodeic
  • 1622 Answers
SOURCE: i have a PDP-r06xe conected
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hoping this will help solve the problem of the television.....
Posted on Jun 23, 2011
Panasonic LED 42AS630D Power light is flashing.... the TV has no picture the remote control is not responding and the TV's front LED light is blinking...?
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Feb 03, 2017 | Panasonic Televison & Video
V911 binding I can't get my view to bind to remote, keeps blinking slow after fast blink, no solid led
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 21, 2016 | Televison & Video
Red light is blinking 6 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name and type of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Jun 04, 2015 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
Manta quadcopter won't recognize the remote
Turn on the remote controller first then heli the instructions are wrong
Dec 24, 2013 | Protocol Manta 4-Channel Radio-Controlled...
Front led light just blinks
Make shure transmitter is on and ready BEFORE powering heli and let rest the heli without any mouvement while and after powering up ( gyro setup ). Receiver maybe need to be bind for it to work, look for binding procedure in manual.
Nov 24, 2013 | SWANN Micro Attack Military Blue Gyr
Pairing instructions for motorola H500 headset
Hold the phone2_bing.gif button down for about 4 seconds.. The light should blink 2 times and then stay on to add device to your phone once connected light will go out...Hold button down again light will blink 3 times and go off...........
Jun 20, 2010 | Motorola Mobility H500 Wireless Headset
Samsung 56V, difficult to switch on the monitor
check the capacitors inside the monitor, as they may be broken, and they start screen up, just change em and it should kickstart fine
Sep 19, 2009 | SAMTRON 55V 15" CRT Monitor
Motorola H500 bluetooth won't turn on!
Hold the phone button down for about 4 seconds.. The light should blink 2 times and then stay on to add device to your phone once connected light will go out...Hold button down again light will blink 3 times and go off...........
Aug 07, 2009 | Motorola Mobility H500 Wireless Headset
I can't get my motorola h500 to pair to my nokia 2865i
To pair the headset, first turn off the headset if it’s not already off, hold the multi-function button until the LED light turns solid blue (not blinking blue) with an audio indication, then use your phone to discover and pair with the headset using “0000” as the default pass code.
May 13, 2009 | Motorola Mobility H500 Wireless Headset
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
