Question about ARP Bolts Chevy 305-350 Vortec with headers except LS1 & LS6
Engine swapping? Im swapping 350chevy vortech engine putting it in my 76 cutlass what do l need? And the 76 tranny bar isn't fitting need help please.
Swap Engines
You are going to need to Swap ECU also, They are not interchangable
Mar 21, 2013 | Chevrolet Camaro Cars & Trucks
Would a C4 engine off 1985 corvette fit in a 1976 corvette
you can fit anything into anymake providing you have gas bottles and a bit of know how ,providing the bellhousing bolts are in the smae place then give it a go as iam sure it will fit ,ok modify this or that but so long as it connects to the gerbox the rest is easy
Mar 28, 2012 | Cars & Trucks
I have a 1989 mazda rx7 convertible automatic with the 13b rotary engine and im going to swap the engine and tranny for the 13b turbo engine and manual tranny,and also have ecu.is it hard to swap and how.
its not hard at all. as long as your good with your hands. and know the basics of your rx7. other then that everything bolts in. you just need a turbo driveshaft for sure. or they sell a custom driveshaft on mazdatrix.com so you can keep your N/A differential.
Apr 18, 2010 | 1989 Mazda RX-7
1984 volvo 244 auto/standard tranny-engine swap?
Totally forget about changing an automatic car to standard. That would be a very parts & labor intensive switch and is out of the question. If you have the same year and size engine this will be an easy swap. Just remove the donor engine leaving the bell housing and transmission in place in the donor car. Remove the engine from your car leaving the bell housing and transmission in place. Bolt the donor engine to your old bell housing and you are all set. Mark all connections as to not get confused. A digital camera will be of help in taking photos of how things are hooked up.
Sep 22, 2009 | 1984 Volvo 240 Series
Tranny swap
No. Engine and Computer would be lacking connections and linkages needed to operate normally. Tranny swap haundai?
May 11, 2009 | 2000 Hyundai Elantra
Need to know what other transmissions can bolt up to a 70 olds cutlass 350?
Tou can use any olds pont or buick 350 out of an earlier car that had a V-8. you can also install a 400 using a crossmember from a car that had a200r4 tranny in it. providing your car has a frame mount welded in on the left frame rail. otherwise you have to relocate the tranny mount on the exsisting crossmember.
I have an 81 buick that now has a455 olds with a th400 in it, I asol have an 80 cutlass with a 403 and th350 from a 78 pont wagon in it
the trick is to use the non lock-up version of the TH350.
Hope this helps
May 04, 2009 | 1983 Oldsmobile Cutlass Supreme
I don't know the size of the original Transmition,that came in my Cutlass supreme 1987.,i jst put a 350 rocket in the car and need a tranny,the bolt patterns,weather or not the tranny has...
If I remember correctly that engine used a 350 trans. You will need to check bolt patterns on bellhousing to make sure there are no differences in bolt pattern but I believe they are the same. With a little work you could also stuff a 400 or a 700r4 (with overdrive) unit in there but you would need some mods to do that. Don't forget that tailshaft lengths vary depending upon where the unit came from so you may need to either change tailshaft or have a driveshaft made to fit.
Apr 03, 2009 | 1987 Oldsmobile Cutlass Supreme
Engine problems
IF YOUR CUTLAS HAS A 3800 YOU SHOULD BE FINE, IF IT DOESN'T THEN YOU WILL HAVE TO CHANGE THE TRANNY TO.. AS FAR AS IS IT WORTH IT, WELL MY FRIEND THATS UP TO YOU, WHATS THE CAR WORTH TO YOU? IF YOU THINK ITS WORTH THAN IT IS, YOU WILL HAVE TO PUT SOME MONEY IN IT, BUT NOTHING LIKE A CHEAP CAR..LOL.. GOOD LUCK KEITH..
Mar 11, 2009 | 1996 Oldsmobile Cutlass Supreme Coupe
Engine swap
95-94-93 4.3 vortec are compatable engines. 97 4.3 will fit but will have problems with sensors and computer
Dec 06, 2008 | 1995 Chevrolet Blazer
Olds 88 tranny fit a Cutlass?
As long as the tags on the trans have the same numbers yes, these transmisssions are electroniclly controlled and there are internal differences even though they may bolt up, there are ID tags on all transmissions sold by GM and installed on the production line.
Dec 01, 2008 | 1995 Oldsmobile Cutlass Supreme
ARP Bolts Chevy 305-350 Vortec with headers except LS1 & LS6 Logo
219 people viewed this question
Top ARP Bolts Golf Experts
FastHarley
FastHarley
ray gallant
Ronald Prier
Are you an ARP Bolts Golf Expert? Answer questions, earn points and help others
