Sound volume of the tv cannot be adjusted.It is fixed.Can someone tell me what it happened and how should i fix it?Thanks
Philips crt tv 21HT1582/59z
    Top Expert:
  • Televison & ... Master
  • 74,185 Answers
Main system control IC fault.
Posted on Apr 15, 2015
  • 1 more comment
  • Anonymous Apr 16, 2015
    So that means it cannot be fixed or repaired anymore?
  • The Knight
    The Knight Apr 16, 2015
    It can be replaced. Contact any service technician. This is not a user repairable work. http://electronicshelponline.blogspot.co...
  • Anonymous Apr 24, 2015
    oic~thank you so much
What is causing the volume to to change on its own?
This is a known issue for this model, and you need to ask for a service intervention via your dealer or Philips (http://www.support.philips.com/support/catalog_selector.jsp) to repair it.
Nov 22, 2015 | Philips Televison & Video
Philips 50P8341 50 in. Rear Projection Television
normally when something like this happens, we could right away propose what can be done, in your case, since youve already changed a lot of parts on that tv, you can at anytime fix it. the tv alone is not fixed yet as of the moment but to some it up, experts have already given you some ideas on how to fix the tv. cheers. hope youll fix that tv in no time.
Mar 12, 2008 | Philips 50P8341 50" Rear Projection...
I bought a second hand philips tv 29ht2212/79r and have tuned in the channels via the interaction menu using 3 1 9 7 5 3 mute on remote and the sound wont work now. is there something i have to enter to...
open the cover of your tv look for the sound IF using a plastic precesion screw driver adjust the IF counter clock wise slowly untill you reach a good sound or clockwise...if nothong happen solder a 0.2 ceramic capacitor to your sound IF at the coil of the IF under the board the IF has two terminals for the coil.sound if is located near the tuner section..there are two IF the video I.F and sound I.F
May 20, 2010 | Televison & Video
Our Philips Magnavox Smart Series TV Shuts Off
It is possible it could be a switch but this is usually after extensive use. If it does the same with the remote control chances are it's not the switch. These sets had problems with the vertical circuit as well. I've fixed a lot of these with vertical problems. It should not run but about $80-$100 to repair if it is a vertical problem. These sets have a lot of safety cicuits as well so it could be a horizontal circuit problem as well or power supply. Kind of hard to say without a good troubleshooting. Thanks
Nov 01, 2009 | Televison & Video
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Dec 19, 2008 | Toshiba 32AF43 32" TV
BUSH LCD 17TV004 picture goes off!!!
if yo know how to solder , re solder your tv, second adjust the IF transformer by using the plastic or wood stick. IF transformer is looks like a cube made of metal with an adjustment screw at the top. try to adjust it and observe what happen.
Oct 16, 2008 | Bush 5693D 24" TV
Volume
The tv has a static sound and picture has vertical lines but is still visible. Heeeeeeelllllp. Thank you.
Jul 21, 2008 | Philips 19PR19 19" TV
Audio
I had thhis type of TV and had it serviced by a TV repair shop and they told me there is a small control board that has gone bad and costs $180.00 to replace. TV is not worth fixing.
Jul 02, 2008 | Philips 27PT6441 27" TV
Philips magnavox 25tr19 c121 problem
Still need info..? Can you replace soldered in parts.? Let me know.........................T.
Nov 16, 2007 | RCA F31672ET TV
TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Feb 05, 2007 | Philips 27PT8320 27" TV
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
Electro Med Services...
