Question about Microwave Ovens
Keypad quit working on Sharp R3W96.It's receiving power because I have 4 flashing 0's on the digital display, but none of the buttons do anything. They don't sell the keypad or circuitboard anymore.
  • Microwave Ovens Master
  • 932 Answers
Kathy,
Unfortunately that probably means that your microwave is obsolete and you would be better off replacing it than trying to fix it. Sorry!
Posted on Apr 15, 2015
  • 3422 Answers
SOURCE: Wireless keypad cannot be reprogrammed....not able to get to "smart button".
Please CLICK HERE
Just go through the manual it will help ya..
Goodluck,
Please don't forget to rate the solution
Posted on Apr 29, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: My Craftsman 53684 keyless won't work with my Craftsman 53930DM.
I've never seen the first set of steps you mention. You always need to press the "learn" button first so the opener will be in the mode to capture the new code. As far as I know it is not necessary to hold the Enter button on the keypad (at least I never have). While the "learn" LED is lit on the opener, just key in the new code and press Enter.
Maybe you should try clearing the receiver first by pressing the "learn" button and holding it until the LED either goes out or starts flashing (depends on model). Then try reprogramming. Maybe the little computer is confused.
Posted on Dec 01, 2008
  • 3197 Answers
SOURCE: Can't reset remote keypad
Press and immediately release the SRT button and then walk over to your keypad and key in any 4 digit code you like and press enter.
Posted on Aug 25, 2009
  • 3197 Answers
SOURCE: Craftsman Model 139.53684 Security+ Keyless Entry
To answer your question the opener is in vacation mode. Press and hold for 3 seconds the button on your wall control with the lock icon. The green light will stop flashing and you will be back in business.
Posted on Dec 08, 2009
blanchettohd
  • 143 Answers
SOURCE: Keypad won't work anymore
Lets make sure you are programming it correctly, make sure the battery is new. Press and release the learn button on the motor. Within 30 seconds enter in the 4 digit code followed by the up/down button. The light bulb should flash once. If you can't get it to code in this way you will need to replace the keypad. Thanks BB
Posted on Sep 05, 2010
Replaced 20A fuse - now display blinks
Here is the parts page for your unit with an exploded view and parts list
http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R-9H84B/0958/0123245/P0050209/00001 It is possible the switch is bad the look at part number 1-6 hope this helps.
Nov 08, 2013 | Sharp R-9H84B Microwave Oven
Start button and quick minute and 0 not working
This is only a educated guess, some input is better than none:
If three specific buttons do not work the keypad either got something spilled on or in it or it is a bad.
Dec 17, 2012 | Sharp R-1492 Microwave Oven
Sharp r-509fw Keypad problem?
You need to replace the control panel, the panel is all one piece buttons and all.
Jun 10, 2017 | Sharp R-520KS Microwave Oven
I have a Sharp R-305KS stainless microwave. It is about 1 year old and until recently, I haven't had any problems with it. About two weeks ago the cancel button on the front panel started to work...
Hi and welcome to FixYa, I am Kelly.
This microwave has a 1 year warranty. You are going to need a new keypad to correct your symptom. Let Sharp pay for it.
http://www.sharpusa.com/~/media/15710197EE3140AD888B896ACDC912DD.ashx
(Choose "open" ) Then go to page 2 for contact information. Page 3 sates Parts and Labor 1 year.
Thanks for choosing FixYa,
Kelly
Apr 07, 2011 | Sharp R305KS Microwave Oven
Flashing dispaly of 4 eights, with no response from keypad
First check all door switches are properly working. If they are ok , the defect may be in the key pad. You need to replace the key pad.
May 26, 2009 | Sharp R-510HW Microwave Oven
Operating Instructions Mistral MMW17SS
Hi Bryan... I had the same problem as you in trying to work out this blasted clock!!! - by fluke I worked it out!!
Here are the steps:
1 - press the 'clock' button (to ensure the clock is displayed) 2 - press the 'cancel' button (the display will go to zero '0' 3 - use the keypad to enter the time (at this stage the colen between the hour and minute numbers will not be flashing. 4 - press the 'clock' button again (the colon will start flashing and the time will be set.
your frustrations are over my friend!
May 07, 2009 | Microwave Ovens
Clock is flashing - no other buttons will work
hi
it sound like the keypad has died does happan on sharps does the light come on when you open the door ,onother problem that can happen is if one of the microswitches is sticking from storage ,if they are not working in sync then the keypad won't work
cheers grant
Oct 22, 2008 | Sharp Microwave Ovens
Numbers 1,3, 4 and 6 no longer work
It's probably the keypad. The keypad is a thin plastic membrane type that is glued to the plastic control panel frame.
If none or only some of the pads are working, there may be some foreign substance on the circuit board, the keypad connection, or inside the layers of the keypad, the latter of which cannot be repaired.
Trouble is sometimes due to spray cleaner being sprayed directly onto the keypad. Cleaner should be sprayed on the cloth first, then use the cloth to wipe the keypad clean.
Never use an ammonia-based cleaner on plastic as the ammonia can attack and crack it.
A handy person can remove the control panel frame and see if there's any liquid inside on or behind the panel. If so, it is possible to dry it out, but often that does not work.
Another thing is to unlpug the power at the mains for several seconds. Plug it back in and see if it works. A reset may do it. At power-up, the display should flash or show a text
message. If not, a key may be stuck due to a foreign substance or a defective keypad.
We have critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
If certain keys are not working, there may be some foreign substance at the point where the green or blue plastic strip from the keypad plugs into the circuit board. To check that:
1. Be sure the oven is disconnected from the power line while you are taking it apart.
2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board.
3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector.
4. Then the keypad strip will lift out. Clean both sides of the end of the strip with a pencil eraser or alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip.
5. Put the keypad strip back in, making sure both sides are down fully.
6. While holding the strip down, push the connector back down to lock it.
7. Try the keys again with the door closed.
Also, you must have the door closed for the START button to work.
You can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from there or from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 05, 2008 | Sharp R-320H Microwave Oven
Flashing 88:88 display - no keypad response - no light
I’ve read through your problem in an attempt to find a solution to my own similar issue with my microwave oven. Other solutions (like unplug appliance overnight and reconnect to power source the next morning) did not work for my appliance.
Just as I was about to call it quits and go out to purchase a new microwave; I gave it one last try. This time, instead of pressing any and every single button on the keypad, I decided to press BOTH the "Stop/Clear" AND "Start" buttons AT THE SAME TIME. . . . . Voilà! This worked for me, but sadly, it's now May-2008 and I'm pretty sure you're own microwave is long gone since your posting appears to have been quite some time ago. Well, hopefully others that stumble through these pages with similar issues may find some assistance with my approach. Oh, and btw. . .I got this idea (which worked) from remembering the instructions on how to reset my cellphone. Many thanks, ~paul
Sep 13, 2007 | Sharp R-220HW Microwave Oven
Microwave Keypad not working
This model does have a child lock. If it's on, the display will say "LOCKED". It is turned on and off by holding dfown the "0" key for 4-5 seconds. You may also have a bad keypad, which in many cases can be replaced. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Moisture and contamination can be caused by spraying of cleaners, by storing the microwave in an unheated garage or shed, or infestation. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Repost if you need more help.
Nov 04, 2006 | LG LMVM1935 Convection/Microwave Oven
Microwave Ovens Logo
61 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
