Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
I have had a Freeagent 250 HD connected for two months via USB1 connection with no problems. I installed a USB2 card and connected the drive. No luck connecting. After going through all the diagnostics the Event log indicates an Event 51. I have gone through Device Manger, Storage Management, driver installs, Bios checks and all USB2 connections, ports and adapters show good status. Oh, I'm presently running my printer and card reader through the USB2 card with no problems.
If reconnect to the USB1 port no problems!
  • 99 Answers
Most of the time if you get an event 51 error you will need to reinstall drivers associated with that device to fix it. I would delete the device from device manager, uninstall any software that you installed for it, then restart your computer and reinstall the software. I would do this for both the card and the drive. I would also run Windows update to see if it finds any other drivers that you do not have installed. If that does not work it is possible that the card and drive might not work properly together. The only other thing I can suggest trying is reinstalling windows
Posted on Nov 14, 2007
0 characters
3 Points
Seagate freeagent go 250 gb. was working fine for
which files.... if you have "show system files" selected in your folder options in your operating system it still won't let you open them as that is it's way of preventing you from deleting or changing them
Jul 13, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
The light on my Seagate freeagent go flashes quickly when it is connected to my computer, indicating an error. What should i do?
I had similar problem recently. I noticed that I had forgotten to connect the power supply cable to the USB hub, to which my FreeAgent Go was connected to, after I had connected all my USB devices to my computer's USB ports (after I had disconnected everything from my computer in order to isolate another issue). Reconnecting the power supply cable immediately stopped the flashing light and windows recognized the drive.
Don't know how you are connecting yours to the computer i.e. via a USB hub or directly to the computer's USB port. Note that my FreeAgent Go drive requires both USB connectors connected to the computer (or to USB hub). Two USB connectors are on one end and the other end of the cable is connected to the drive/docking station.
Hope this helps.
Jul 10, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Windows vista on Vaio laptop does not detect new Seagate FreeAgent Go 250 USB 2.0 GB drive.
try formatting your laptop again with vista O.S. but dont install anti virus after installing it because there might be some conflict with the anti virus you installed with the O.S.
Jun 27, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
External Hard Disk problem to connect
Try connecting in safe mode with networking and then check if it doesn't disconnects then scan your system with mcafee 8.5i anti virus.
Perform a checkdisk on your usb drive
Please rate this fixya
Jan 09, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Make freeagent deskot 250GB master hard drive
1) I greatly suggest against making ANY external HD your primary disk.
2) Not many computers support this.
3) The most likely method would involve reisntalling your OS (Windows/OS X) onto the drive.
4) I just noticed this thread is from three months ago... :P
Dec 28, 2007 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
1,011 people viewed this question
Top Seagate Hard Drives Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a Seagate Hard Drive Expert? Answer questions, earn points and help others
