Question about Sony Audio Players & Recorders
Need Sony dvd/home theater remote code for Go Video remote
    Top Expert:
  • Sony Master
  • 10,875 Answers
techman
  • 3130 Answers
SOURCE: Lost Remote for my Durabrand HT-395 Home Theater Systom
There are no codes you program into the remotes unless they are learning remotes. If you did the manual search for the code, then the universal remote will not work on that unit I'm afraid. You see you are not entering the code into the remote when you push the numbers the book tells you to. What you are doing is accessing the pre programed codes that are already programed into the remote. You cannot add any codes for universal remotes unless like I said before, they are called learning type remotes. Those cost loads of cash. Good Luck
Posted on Oct 15, 2007
SOURCE: I need device codes
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
Posted on Nov 08, 2008
SOURCE: need to program 311w U. remote to RTD215 home theatre
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Posted on May 03, 2009
SOURCE: Comcast remote codes for Sony Bravia DVD Home Theater System
This Also Works for DAV-HDX598w
Posted on Feb 19, 2010
SOURCE: push power protector showing up in sony dvd home theater system
Always be the audio amplifier IC damaged
Posted on Jun 24, 2010
Sony DVD player with 5.1 output home theater remote control imrge &remote control code number
Codes are in the remote. If it is universal, you can use code search to find something applicable to your Sony DVD player.
Nov 15, 2016 | Sony Audio Players & Recorders
I have a panasoniic universal remote coontrool dvd system eur7722xgo and i want to program my sony dvd home theater system dav-dx250 with it
If you have a universal remote, you can try using its code search feature to find a code that will control your Sony system. If you search through all codes stored in your Panasonic remote without success, you may have to try another universal remote. Programmable remotes vary in the codes they store.
Jan 04, 2015 | Panasonic Universal Remote Control For...
I have a Sony theater reciever that I bought off eBay with no remote. So I looked around and Sears was selling a Sony Universal remote RM-VZ220 saying it was compatible with my Sony STR-K670P AM/FM...
1. Make sure you have good batteries in the remote and they are installed properly.
2. Press the DVD button on the second row of the remote, then check if the Power and other buttons on the remote work with your system (it probably won't since the factory setting is for a Sony DVD player, not a home theater system).
3. If it doesn't work you need to find the correct code number for your system and enter it into the remote. Press and hold the SET button for more than 3 seconds until the SET indicator lights up. Keep holding the SET button down and press the DVD button, then release both buttons. Then enter the code 31622. If you have done this correctly the SET indicator flashes 3 times, if not start over.
4. See if the remote now controls the theater system correctly. If not, repeat the above procedure #3 with the following codes one at a time until you find one that works: 31558, 31658, 31758, 31822, 31858, 32522.
May 23, 2014 | Audio Players & Recorders
Motorola remote and sony home theater system code
you may need to set it up as two devices program a code for DVD to turn the unit on and off and a program and auxiliary code so that you can control the volume then you can teach the remote to use the auxiliary volume without having to press the aux button each time
Nov 10, 2013 | Sony BRAVIA Televison & Video
I want to program my home theater system with my dvd player\r\ndvd player is a blu ray remote is sony rmt-b104a sony htss360 is home theater system
http://esupport.sony.com/perl/model-home.pl?mdl=RMTB104A
GO TO THIS DOWNLOAD FROM SONY AND PUT YOU REMOTE CONTROL FOR YOU SEARCH YOUR CODE AFTER YOU DOWNLOAD YOUR REQUIRED MODEL.
SINCERELY.
E.CUADRA
MANAGUA, NICARAGUA.
Jul 26, 2011 | Sony rmt-b104a Remote Control
Sony DVD Home Theater System remote control code
I have the same system and one of my dogs got to the remote. I have a philips PMDVR8/PDVR8 universal remote. I was able to get the dav-hdx265 to turn on/off and do volume up and down by using code 0200. I have not been able to get the DVD functionality to work yet, but I will post if I do.
Oct 22, 2008 | Sony DAVHDX265 System
I need device codes for sony DAV HD279w home theater/dvd player controlled by comcast digital cable remote control (none of the codes work in the manual and I tried searching for code and still no luck)...
2. Type 994
4. Type 32975
Vol+ = 32975
Vol- = 31951
Power = 32719
Jul 27, 2008 | Sony BRAVIA DAV-HDX267W Theater System...
Need Universal Remote Code for Panasonic DVD Home Theater Sound System
Need a remote for a Bose CINEMATE Digital Home Theater Speaker System. Where can I find one?
Dec 26, 2007 | Bose Cinemate Digital Home Theater System...
Need a universal remote control code for sony dav-dz 100
use kameleon urc remote there are a list of codes in back of manual one of the sony codes will work
Oct 17, 2007 | Sony DAV-DZ100 System
112 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
