Question about GE Dryers
How to enter service mode. model dpvh880gjmg - GE Dryers
  • Jerry Smith May 19, 2015
    attached is some service info. Service mode about 1/2 way down list.
    IMPORTANT SAFETY NOTICE
    This information is intended for use by individuals possessing adequate background of
    electrical, electronic and mechanical experience. Any attempt to repair a major appliance may
    result in personal injury and property damage. The manufacturer or seller cannot be
    responsible for the interpretation of this information, nor can it assume any liability in connection
    with its use.
    AIR FLOW AND SEALS
    Proper air flow through the dryer is
    essential for normal operation of the
    temperature control and safety systems.
    Air is PULLED into the cabinet from rear.
    A portion of this air is heated by the gas
    burner in the combustion chamber and
    is pulled up the rear duct into the
    diffuser. The remainder of this air
    enters the diffuser directly through
    vents and is mixed with the heated air.
    This hot air is PULLED through the drum
    rear, across the clothes load, through
    the lint trap and down the trap duct into
    the blower. From the blower the air is
    PUSHED out of the exhaust system.
    Any air leaks between the air inlet and
    the blower such as lower drum front felt
    or trap duct to cabinet front sealing will
    result in improper temperatures. The air
    being pulled down the trap duct to the
    drum outlet thermostat will be cooler
    than normal, giving this thermostat a
    false indication (delayed or no-trip).
    Leaks ahead of the blower will also
    reduce the volume of air across the
    combustion chamber causing hot spots
    and possible premature failure.
    TRAP DUCT SEALING
    To inspect the trap duct for proper sealing, remove the lint filter and look
    down into the duct. With a light examine the trap duct on all sides where
    it meets the dryer front for voids in sealing. Leaks may be sealed with
    permagum.
    • WHEN FLEXIBLE DUCT IS USED. WE STRONGLY RECOMMEND METALLIC FLEXIBLE
    DUCT
    • EXHAUST DUCT MUST BE 100 mm (4 INCH) DIAMETER
    • FOR SPECIFIC EXHAUST SPECIFICATION, REFER
    TO INSTALLATION INSTRUCTION SUPPLIED WITH YOUR DRYER
    DRIVE BELT
    The drum is rotated clockwise and counterclockwise,
    as viewed from the front, at a speed of 47-51 RPM.
    Belt tension is maintained by a spring loaded dual idler
    pulley system and driven by a pulley attached to the
    drum motor shaft.
    WHEN SERVICING THE DRYER
    The igniter functioning and the flame can be
    seen through a viewer hole located in the base
    of the dryer. Use a mirror as shown in these
    figures.
    GENERAL TROUBLESHOOTING GUIDE;
    GAS DRYER
    COMPLAINT
    YES
    NO HEAT, SHORT BURN LONG DRY TIME DAMAGE
    NO
    WRINKLES
    YES CHECK SHRINKRAGE
    SNAGS
    ONLY KNITS
    NO YES
    NO SNAGS
    YES FRONT ONLY
    CHECK
    * SEE SCHEMATIC FOR PROPER SWITCH CONNECTIONS
    WRINKLES
    SHRINKAGE
    DAMAGES
    SYNTHETICS
    ONLY
    ALL FABRICS
    ALL LOADS
    NO HEAT
    LONG DRY TIME
    CLOTHES WET
    SHORT BURN CYCLE
    IGNITER
    OPERATES?
    GENERAL CARE
    LABEL WASH AND
    DRY INFORMATION
    WASH SPIN SPEED
    GAS PRESENT?
    GAS VALVE
    GAS PRESSURE
    GAS RESTRICTION
    GAS VALVE
    CLOSES APPROX.
    1-2 MINUTES
    EXCESSIVE OR RESTRICTED
    EXHAUST SYSTEM
    SAFETY THERMOSTATS
    BACKUP THERMOSTAT
    THERMOSTAT
    TEMPERATURE
    DRUM SPEED
    SEE NOTE 1
    DRUM & INTERIOR
    SURFACES
    DRUM GAP
    THERMOSTAT
    TEMPERATURE
    WASHER BASKET
    AND AGITATOR
    SEE NOTE 2
    ALL HOOKS AND
    ZIPPERS MUST BE
    CLOSED
    WASH & DRY
    NORMAL WEAR
    OR DAMAGE BY
    COUNTERS
    DESKS, ETC.
    FLAME
    DETECTOR
    POWER BOARD
    HEAT SETTING
    MOTOR SWITCH
    1 & 2 *
    THERMOSTAT
    ARE CLOTHES
    STILL DAMP?
    DISPLAY TIMER
    OPERATES
    EXHAUST SYSTEM
    THERMOSTAT TEMPERATURE
    DISPLAY TIMER OPERATION
    WASHER SPIN SPEED
    SEE NOTE 1
    NOTES:
    1. Other factors contributing to long dry times, or clothes condition: load size, large bulky
    items, ambient temp., room size (it not exhausted outdoor), washer spin speed, washer rinse
    temperature, gas supply (restrictions), gas pressure.
    2. Small loads: Less than 3 lbs. if not treated with destaticizer could develop a static charge if
    over dried and cling to drum surface (no tumble) causing wrinkles, shrinkage, or melting. Use a
    fabric softener (washer or dryer) or add 2 large bath towels to act as a buffer when drying.
    SERVICE PARTS & LUBRICATION
    Motor........................................................................................................120-60HZ (WE17M44)
    Drive Belt ....................................................................................................................WE12M30
    Idler Pulley ....................................................................................................................WE12M8
    Drum Bearing Sleeve ..................................................................................................WE1M462
    Blower Motor............................................................................................120-60HZ (WE17M45)
    Grease • Idler Bearings ................................................................................................WE25X46
    SERVICE NOTE:
    Some replacement parts may have more terminal connections that the original part. Wire the
    new part to the same numbered terminals as the original part and disregard the unused
    terminals unless a special instruction is provided.
    IMPORTANT
    Reconnect all earthing devices. All parts of this appliance capable of conducting electrical
    current are earthed. If earthing wires, screws, straps clips, nuts or washers used to complete a
    path to earth are removed for service, they must be returned to their original position and
    properly fastened.
    SERVICE MODE TEST
    How to enter to service mode and navigate:
    • From Idle state, Press and alternate between the ‘My cycle’ and ‘Delay Start’ buttons to enter
    service mode.
    • Upon entering the service mode, the Control shall be in test selection mode and display the
    list of tests on the VFD. Scroll through the list of tests by using the up or down cursor arrows.
    Selection shall be represented by bold text.
    • Once the desired test is highlighted, press ‘Enter’ to begin the test.
    • During a test, press “Power” to terminate it and go back to test selection mode.
    • Press ‘Power’ during the test selection mode to exit the Service mode.
    SERVICE MODE
    TEST SEQUENCE
    t01 enter displays "configure UI"
    Configure UI
    power returns to service mode screen
    t02 enter displays error codes
    Start/pause clear highlighted error code from machine
    Error Codes
    t03 Version Info enter displays the current version of software
    t04 enter Check EEProm
    EEProm
    Check power returns to service mode screen
    t05 enter LEDs light up
    UI Test
    t06 enter to begin testing
    any button
    but Power
    hear beep as button is pressed
    Key
    Continuity
    t07 enter displays outlet thermistor temperature
    Start/pause Drum tumbles and change direction every 30 sec.
    Outlet
    Thermistor
    t08 enter displays inlet thermistor temperature
    Inlet
    Thermistor
    t09 enter displays moisture sensors reading
    Moisture
    Sensor power returns to service mode screen
    t10 enter blower turns on and UI displays rpm
    Blower /
    Exhaust power returns to service mode screen
    t11 enter displays dryer rack temperature
    Dryer Rack
    *For the last two tests the blower fan is active
    Error codes
    Error Code Description
    E1-Interface EEPROM Reading or writing improperly. Replace UI board.
    E101-Power EEPROM Reading or writing improperly. Replace power board.
    E2-Inlet Short Inlet thermistor shorted, check and replace if necessary.
    E4-Inlet Open Inlet thermistor open, check and replace if necessary.
    E3-Outlet Short Inlet thermistor shorted, check and replace if necessary.
    E5-Outlet Open Inlet thermistor open, check and replace if necessary.
    E61-Check Electrical
    Connection Input voltage too high, please check power connections.
    E81-Power Model No model select connector detected, check model selector on
    power board.
    Blower Motor Blower is not rotating properly. Please check.
    E11-Blocked Airflow Check ventilation system.
    E12-Drum Motor Motor is not rotating properly or centrifugal switch is bad.
    Please check.
    E16-LIN Comm Fail There is a problem with the Communication between the
    Machine Control and the User Interface Control.
    E17-VFD Communication
    Error
    There is a problem with the Serial communication interface
    between the UI and VFD.
    E18 - Stuck Button Stuck Keys. Please check
    212D1605P001 rev 1
  • GE Master
  • 473 Answers
Inside control panel should be service paper with info you need.
Posted on Apr 16, 2015
Testimonial: "How to enter service mode. model dpvh880gjmg No service paper ..."
Bought a floor model Hisense 55 in TV. No remote. Cannot get it out of store mode. It does ooeratecwith Directv but then goes to store mode. Hit volume and program returns, etc.
You have to enter its service mode to get it to normal mode; out of hotel/store mode. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 16, 2016 | Directv Televison & Video
Model W240. How can I enter service mode?
enter service mode Mohammad, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Entering Service Mode HP LaserJets
canonipf Service Mode
Service Manual free download schematics datasheets eeprom bins pcb repair...
Ricoh 6000 service mode
Apr 11, 2016 | Ricoh Office Equipment & Supplies
Weston tv model dhoom 2061 servic mode for remots control code
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 07, 2014 | Televison & Video
How do i eras factory off a phillips tv 2008, model 21PT9457/85?
Your TV has entered into service mode [Factory] mode by somway, due to improper buttons press on remote control. You have to get out from this mode, and to select the normal mode. It will be best to contact any service technician in this case, as this is a semi-skilled work, and should have knowledge to enter service mode and to exit out from it. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given.Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin.Be very careful.Note how to "EXIT" the service mode; after entering and adjusting data.This is very important.
Sep 30, 2014 | Televison & Video
Enter service mode
I'm wondering if you realize what little information you have given us to help you with. I have to make major assumptions just to begin... it must be a digital washer to have a service mode... so its a recent model. Generally, service modes are entered by doing things that a consumer would be unlikely to do, like holding several buttons down while turning the unit on. I assume also it has some sort of display to tell you what is going on.
Really, I can't be much help until you give more info - make and model are essential, and perhaps why you want to enter the service mode.
Sep 26, 2014 | Washing Machines
How do i get my panasonic tv out of the service mode
If you wish to know how to enter and exit Panasonic TVs, check this link. Pull up older posts there. Different models have different ways to enter and to exit service mode, To get into service mode and to exit to different models of Panasonic TVs are given in detail in that site. If your TV is not listed, inform me with its exact model number.
Mar 20, 2013 | Televison & Video
I don't know the model code
Hello
You are a technician and you whats to know the model service code I thinks, and posts this solution.
Use the Remote Commander (RM-Y183, RM-Y184) to perform the circuit adjustments in this section
SETTING THE SERVICE ADJUSTMENT
MODE
1. Standby mode (Power off).
2. Press the following buttons on the remote commander within one
second of each other:
DISPLAY Channel 5 Sound Volume + Power
READING THE MEMORY
1. Enter into service mode.
2. Press 0 on the remote commander.
3. Press ENTER to read memory.
ADJUSTING THE PICTURE
2. Press 2 or 5 on the remote to select the device item.
3. Press 1 or 4 on the remote to select an item.
4. Press 3 or 6 on the remote to change the data.
RESETTING THE DATA
Note: Be careful when using the remote! It will clear and re-initialize
ALL NVM data including defl ection adjustment data if not reset
properly as follows:
5. Press MUTING then ENTER to write into memory.
RESETTING THE DEFLECTION NVM DATA
2. Press 7 , then MENU, and then press ENTER on the remote.
RESETTING THE SYSTEM NVM DATA
2. Press 7 , then 9 , and then press ENTER on the remote.
2. Press 8 and then press ENTER on the remote.
MEMORY WRITE CONFIRMATION
METHOD
1. After adjustment, pull out the plug from the AC outlet, then replace the
plug in the AC outlet again.
2. Turn the power switch ON and set to Service Mode.
3. Call the adjusted items again to confi rm they were adjusted.
Ok.
Nov 30, 2010 | Sony KV-32XBR250 TV
Service mode code
How to enter the service mode using the user remote control.
Turn the set on.
Direct the remote control to the reception window of TV.
Push buttons of remote control in sequence as follows.
→MUTE
→DISPLAY
→MUTE
Here you also get a service manual for a similar model.
Jan 06, 2009 | Daewoo Televison & Video
Dryers Logo
135 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
