Question about Element Electronics Element 40" LED 1080P 60HZ HDTV - Black ELEFT405
Is element 40 model # eleFW408 able to use the universal remote from comcast?
Was told by element technical support that this TV is not set up to use remote codes is this true? If so I don't want the piece of crap.
  • Larry Moore
    Larry Moore Apr 17, 2015
    Comcast universal silver with red buttton in middle will not turn on or off element 40 ELEWF408 TV all codes have been used from element and comcast Comcast tech was at my residence and could not find anything wrong with the cable tried 5 different remotes with negative results returned TV and got another one witch has the same results how much more to I have to give you clarification/
Programing my xfinity remote
About 13,200 results (0.79 seconds) Search Results
    Can't program Comcast remote to Element TV - Comcast Help and ...
    forums.xfinity.com/.../XfinityTV...program-Comcast-remote...Element-T...
    Jun 6, 2011 - I have an Element 47" Class LCD 1080p 60Hz HDTV, ELGFT471. My remote is the Comcast Universal Remote - Red OK/Select Button.
    Comcast - what programing code to use with element tv find ...
    https://www.directly.com/.../comcast-what-programing-code-to-use-with-...
    what programing code to use with element tv find a code does not work ... Mymistake. ... Also found that Element has a remote update for some televisions.Missing: panel
    Element Tv Comcast Remote (Tut) - YouTube
    ? 3:19
    https://www.youtube.com/watch?v=ZDBr-hZN2AI
    Jan 20, 2010 - Uploaded by TopBreakX3
    The tut should be in your comcast remote paper help thing but heres the code if u cant see ... cant see clearly ( 10178 ) This is a vid on how to setup your comcast remote for your element lcd tv. ... Who cares program the Comcast remote already ... this was awesome,,,,my sisters tv is on the go now,,,thanx .Missing: panel
    Comcast Remote Codes for TV - Easy PC Tutorials
    www.easypctutorials.com > Comcast
Jan 27, 2016 | Element Electronics Televison & Video
Does my tv support wireless display/miracast? It is an Element 40" model # ELEFW408
It is an entry level television, so no. One review states this;
Element ELEFW408 specs - This model comes with an LED panel size of 40 inches and a resolution of 1920 x 1080 and an aspect ratio of 16:9, a contract ratio of 4,000:1 and a brightness level of 200cd/m2. This is a Full HD 1080p TV with a refresh rate of 60Hz, so not ideal for some of the faster paced sports games. The ELEFW408 comes with a built-in tuner, 3 HDMI ports, although from the look of it lacks wireless connectivity, but with no Smart TV functions this was to be expected.
Element ELEFW408 TV specs with review indecision
Jan 19, 2016 | Tablets & eReaders
Model elefw408. How do I set it up?
[PDF]40 Full HD Digital LED TV - Webcollage Content Publisher
media.webcollage.net/.../89344b29-22c8-49d4-80db-2b1939698e05.pd...
Read all of the instructions before using this TV and keep the ... ELEFW408 ... Read these instructions - All the safety and operating instructions should be read
Oct 20, 2015 | Element Televison & Video
Need remote code for elefw408
DIRECTV- 10178
Time Warner Cable- 10178
Comcast- 10178
Cox Communications- 10178
Dish Network- 627 or 659
This is from the remote control guide that came in my box for model elefw408 hope this helps
Aug 24, 2015 | Element Electronics Televison & Video
Can't find this on any list except for sale nobody has codes
This is the only code to check with Element brand TV; I can see. It is 0159.
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 15, 2015 | Element Televison & Video
Element 40 led will not accept any remote control codes supplied by element technical support also Comcast technical was at my residence for 1hr tried 5 different remotes nothing works?
Hi Larry,
What did the Comcast Tech say in the end? In such cases either the remote senser inside the TV goes bad or the micro processor stops accepting the command. Unfortunately there is nothing you can do about it yourself. Ask the Comcast or someone else who can fix it.
Apr 13, 2015 | Element ELCHW402 40 in. LCD HDTV
Curtis International TV remote codes for universal remote
Need a Model number of the back of your TV set for one and the model of remote your comcast company is using there. There are different brands in different place's.
Apr 24, 2010 | Televison & Video
Remote Control Code for Element LCD TV -- & Direct TV
We cant find our original element remote control. I just tried 10178 on the direct tv remote control and it worked YEAH!!!! We just can't do the screen size edit thing with it :(. Might still have to order a replacement element remote. This works for now. Thanks.
Oct 03, 2008 | Olevia LT32HVM 32 in. LCD Television
Element Electronics Element 40" LED 1080P 60HZ HDTV - Black ELEFT405 Logo
114 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
