IS THAT SYSTEM HDMI SUPPORTED? - Audio Players & Recorders
    Top Expert:
  • 10,875 Answers
Does it have an hdmi plug?? if not it doesnt,if yes,it does
Posted on Apr 15, 2015
Does the Compaq Presario SR1538X have an HDMI plug?
according to specks no there is no HDMI port on that system. You would have to see if there is a video card that will work on that system with HDMI support.
Apr 28, 2014 | HP CPQ SR1538x-B Desktop Bundle from...
Dx4870-ur3d no audio from hdmi port
It may be your system does not support sound over HDMI, as some computers don't. I would double check this is a feature your system supports.
Mar 18, 2014 | Gateway Computers & Internet
How to connect a 3D Player to Bose Lifestyle T20 Home Theater
run HDMI of 3D player to TV and optical out from 3D player to Bose system. Your Bose System does not have HDMI 1.4 (3D) pass through; this is your problem.
May 30, 2011 | LG Televison & Video
When I connect my laptop to my tv with an HDMI cable the video works but the sound comes out the laptops speakers. How do I get sound to the tv?
What operating system are you using? If you are using Windows 7, right click on the Volume icon on the system tray and select "Playback Devices". A window would pop up showing you speaker and HDMI. Select HDMI and then choose the "Set Default" Button on top of the OK button. Thats it! If you want the sound to come out of the laptop again when you disconnect the HDMI from your TV, you have to do this again, then choose the speakers.
Cheers!
Mar 01, 2011 | Vizio 42 in. LCD TV
I have a Panasonic Model TC-p42X1 TV hooked up to a Panasonic SC-PT480 Home Theater system by an HDMI cable from HDMI 1 on TV to HDMI on Theater unit. System setup test okay for speaker sound connections...
It's possible that you have the wrong type of HDMI cable. You need one that has Audio Return if you want to feed your Home Theater system with audio from the TV. There are several types of HDMI cable,some with audio return and some without. The two basic types (not including Ethernet) are described below - you need the High Speed version, which does have Audio Return.
hdmi-standard.jpgHDMI Standard This is the most basic HDMI standard which all cables have to meet. Cable should contain all the connections required for HD transmission, and have to deliver at least a resolution of 720p, (Video mode of 1280 x 720 meaning 720 Horizontal lines). These cables do not contain an Ethernet connection, or audio return.
hdmi-high-speed.jpgHDMI High Speed HDMI High Speed cables will support higher resolutions of 1080p. This means at least 1080 Horizontal lines, and cables rated at this specification may well support high resolutions of up to 4096 x 2160 (2160 Horizontal lines), check individual cables specifications for this data. Cables in this specification will also support a data transfer speed of 10.2Gbs (not to be confused with ethernet data speeds which are different), and a clock speed of 320Mhz. These cables do not contain an Ethernet connection, but do include an Audio Return Channel.
Feb 03, 2011 | Panasonic SCPT480 Theater System
Hi I have a Yamaha yht 292 surround sound system with a model htr 6230 reciever. I have a panasonic (42'') plasma HDTV (model TC P42X1) attached to the receiver by a HDMI cable. I also have a Samsung Blue...
As per HTR-6230 specifications (http://www.yamaha.com/yec/products/productdetail.html?CNTID=5028494&CTID=5000400&ATRID=1020&DETYP=ATTRIBUTE) the HDMI function is only "audio-passthru", which means your receiver is not able to get the audio from HDMI cable, it can only pass it forward to TV. You would need a receiver with "HDMI switch" to be able to listen to audio via HDMI cable. You can find such receiver by looking if it supports TrueHD audio (which can be transferred ONLY via HDMI cable).
With your current receiver, you can connect it to the Blue-ray player via Optical SPDIF cable. I have checked the specs and both receiver and BD player supports optical connection.
Feb 25, 2010 | Yamaha YHT-390 Theater System
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
No play back from HDTV to threater system
Do you have set-top-box or antenna-cable directly to TV?
You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output.
You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV.
But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound.
But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Jan 25, 2009 | Sony STR-DG520 Receiver
XBOX 360 Elite HDMI SOUND PROBLEM
First you have to activate the HDMI audio option in your Sony suround system options so as to activate it. Please try this and then tell me what happens.
Nov 25, 2008 | Microsoft Xbox 360 Elite Console
150 people viewed this question
 Grubhead
Grubhead
