Question about Refrigerators
What is the correct fridge temperature this fridge should be on?
  • Refrigerators Master
  • 473 Answers
If your refrigerator has 2 controls, the start setting is usually at mid point on both dials. That should give you a freezer temp close to 0 and a fresh food temp of 38 to 42 degrees. If only one control---same middle setting should produce about the same inside temps. Fresh food temp is best measures if you can put thermometer in a glass of water to stabilize the temp.
Posted on Apr 16, 2015
The temperature displayed on the front of our fridge is incorrect, How do I fix this?
possible that the rear of the fridge needs space for the condenser to get air to cool
Oct 24, 2015 | Refrigerators
Model XRSS465BB Refrigerator - what is the correct refrigerator setting to avoid frozen vegetables? Also what is the correct deepfreeze setting?
usually meduim setting is good'
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Jun 14, 2015 | Amana Refrigerators
How do I set the temperature for miele fridge freezer pigeon pair kfn 9753 iD?
Wait for it to cool
while it dies you will see flashing bars
wait
it will cool
Feb 24, 2015 | Miele Refrigerators
Fluctuating temperature fridge freezer
Pleaser check temperature and make s\ure it is up to the standart.
Aug 26, 2014 | Refrigerators
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
Correct temperature for freezer & fridge
fridge should be about +4degC and freezer about -18degC
Sep 25, 2008 | Sub-Zero 650 / O Bottom Freezer...
Freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new...
Hi miss_i2000
I'm Harvey the Master Plumber
Your question is: freezer is icing up and fridge temperature has risen to 10 from 5. Also alot of condensation in the fridge and the fan doesnt seem to be working in fridge. Correct temperature on freezer -18 but ice. new frost free fridge freezer bought 1.5 weeks ago
This is no problem for you. You are under warranty and as long as you have not tryed to repair it yourself you are completely covered. Look for the manufacturer's warranty phone number on the paper work that came with it or call the sales man, he will be happy to track that down for you because he wants repeat business.
If you bought it used the only answer is to return it. You could get a local pro to repair it at yuor own expense but I wouldn't recomend that for a frige only 1.5 weeks old!
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Miele Refrigerators
AEG Santo Fridge 3774-6KA
Check the damper between the fridge and freezer. It may be broken or frozen open. If this happens and you have a water reservoir in the fridge then it could freeze and crack - leak and then flood your house... Shut off the water supply until you get the problem fixed.
Jan 20, 2008 | AEG Santo 7085 KG Side by Side...
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
