Ir 6570 error code e0004 e00103 - Office Equipment & Supplies
  • 744 Answers
E004-0103 The IH power supply is faulty/the IH control mechanism is faulty. After correcting the fault, be sure to reset the error. (COPIER>FUNCTION>CLEAR>ERR)
The IH current is faulty. (no current) - Check the connector for any fault in connection. - Replace the fixing heater power supply. - Replace the DC controller PCB.
This link also offers a down loadable pdf service manual.http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR6570
Posted on Apr 15, 2015
petez12
SOURCE: canon ir 6570 error
Im new to this forum. I have an IR6570 giving me an error code E808-001, please help,
Posted on Jul 18, 2009
spinal
  • 287 Answers
SOURCE: canon ir 6570 E0004-106
Hello Raj, The code means that the fuser (the assembly near the paper exit area that provides the extreme heat and pressure required to bond the toner to the paper for your finished document) has detected a problem within itself. From the service manual it means "THe IH voltage is too low". IH means inductive heater which is the unique method the Canon IR6570 uses to generate the heat required th melt and bake the toner to the paper. All copier manufactures realize how important it is to closely monitor this extreme temp (192 degrees celcius) as to not cause a fire.So any and all deviations in temperature or voltage in the fuser area will cause the device to shut down (and there are MANY codes) for safety reasons even if the problem is momentary. You can reset the code and give the device an opportunity to recover in the event you perhaps had a power surge in your environment. At the control panel follow this sequence. Press the additional functions button, next depress the numbers 2 and 8 at the same time, next press additional functions again. This will summon the service mode. Select "COPIER" from the menu.Then select FUNCTION from the tabs at the top. Then select CLEAR from the menu.Then select ERR.Once selected, press the "OK" button located at the lower right corner of the screen.Then unplug the device for 5 seconds. plug it back in and the device will attempt to return to a ready condition.If it was a temporary problem then it will indeed recover.If the code immediately returns then you have a problem that WILL require a service tech Best of luck ! :-)
Posted on Apr 03, 2010
SOURCE: i have canon ir 6570 continueing error code
E000004-010
Posted on Sep 09, 2010
  • 122 Answers
SOURCE: e0025 error code in machine
check the toner bottle.place it properly and lock properly if still error code appears check bttle drive assembly and motor.
Posted on Jan 04, 2011
SOURCE: ir 6570 error code 400
821-0001
Posted on Apr 12, 2011
E821 error code in canon IR 6570 ?
error code relative to the clogging of toner inside the waste toner auger tube. this will require a technician.
Feb 17, 2015 | Canon Office Equipment & Supplies
Error code E000005-0001 cannon ir-adv 6055
I have a problem with my machine,
Canon IR 6570 with error code E000005-0001
beg for a solution
Nov 09, 2011 | Office Equipment & Supplies
There is an error in imagerunner 6570 copier E0004-010 it is resolved then Error E00004-0103 occur. What would be the solution. What is the complaint?
press the [shutdown]key. After the machine has been shutdown turn the main power switchon the main units right side
[shutdown]
if the machine still does not operate normally contact your service representative with the error code below
E000025-0001
Sep 06, 2011 | Canon IMAGERUNNER 6570 Copier
6570 e0004-0106
6570 e0004-0106 pls give solutions for above said problem (error code)
Apr 14, 2011 | Home
Eror e00014 pada ir 5000, sudah dierror *28* tetapi tetap masih eror. motor pemanas tetap gak jalan gimana yaaaa? tolong dong solusinya...
bos tolong nih, kode error E00004-0010 pada mesin canon ir 6570, gimana solusinya. terimakasih sebelumnya
Mar 17, 2011 | Canon imageRUNNER 5000 Copier
CanonPC6RE
I don't know if this addresses your problem, but check this link. If Canon has not already repaired your unit (since September 2006), they may help you out.
May 15, 2008 | Canon IMAGERUNNER 6570 Copier
Canon ir 6570 error
May 15, 2008 | Canon imageRUNNER 5570 Copier
287 people viewed this question
jasbo
jasbo
