Turns black after the wisdows ultimate appears
Hangs in safe mode
  • 3,320 Answers
Usually this caused by driver error, especially after a Windows update. Try pressing F8 before actually starting Windows. This loads only the basic drivers. Start your computer in safe mode Windows Help
Posted on Apr 15, 2015
Dell vostro1000 , windows7 hangs after login,blank screen and no any icon black and blank screen only.
your user profile could be corrupt. can you boot into safe mode ok? (press f8 on boot before windows logo appears)
Jan 19, 2013 | Computers & Internet
When I turn on my Dell Latitude D600 PC, the windows xp loading page appears. After it has loaded the screen turns black and does not make any further progress.
It appears that your display works fine until Windows XP loads. Try tapping the key when powering on the laptop. Select boot in safe mode and see if the laptop works.Here's a description of safe mode by Microsoft.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
If your display works in safe mode then you have a video driver issue or virus or software issue.
Jun 20, 2011 | Dell Latitude D600 Notebook
Hangs on startup
Try booting in safe mode then run a chkdisk scan to see if it shows errors. To boot in safe mode power the computer completely down...wait a few seconds...when you power it back up keep tapping the F8 key on your keyboard. If done correctly a black advanced boot screen will appear with a choice to boot in safe mode. If you are able to boot in safe mode, it's likely that your hdd isn't the problem. It has to do with something in your startup programs. To disable some unwanted startup items Click Start--> RUN-> in the box type msconfig then click on the tab that says startup and uncheck any unwanted items. Reboot the machine and see if it boots regular.
Aug 13, 2010 | Compaq Evo D500 PC Desktop
Inspiron 1520-before finishes loading desktop screen goes black..
As it works ok in safe mode, I suggest you check that your graphics drivers are up to date.
You should be able to download the latest from the Dell website.
Mar 20, 2010 | Dell Inspiron 1520 Motherboard
Blue screen of death. how can i ifix>? running windows 7 ultimate 64 bit
First try to start the computer in safe mode.
Restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
Mar 10, 2010 | MSI P55-CD53 (4719072129125) Motherboard
PC BOOTS HALF WAY
Try booting into safe mode. If it's a driver problem, safe mode will allow you to start Windows with only the bare minimum of hardware and drivers being engaged. To get to safe mode, press the F8 button on your keyboard during the Windows boot process until it takes you to a screen to let you select Normal, Safe Mode, Safe Mode with networking, etc. I would suggest not using anything other than just Safe Mode. From there, uninstall any software or new drivers that you recently installed. Alternatively, you can use the System Restore feature to rollback to a previous restore point.
Aug 10, 2009 | HP Computers & Internet
Wmi error comes and vista hangs
Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected.
Boot into safe mode. First, open services and stop the Windows Management Instrumentation Service. Take ownership of the folder or the contents of the folder "C:\Windows\System32\wbem\Repository." I've done this three times now on different installs and didn't have any issues after doing this, but I suggest you back up the folder to be certain. Delete the contents of the folder. Reboot. When you boot into Vistamag-glass_10x10.gif, you might notice a half dozen or so application errors...it's OK.
Reboot again, and Event ID 10 will be gone, along with the afore mentioned application errors.
Good luck, I'm not responsible for you hosing your system, & all that.
Jun 07, 2009 | Microsoft Windows Vista Ultimate Edition
Toshiba A-215 will not boot after windows update
Hi there.
Boot the machine into safe mode by restarting the PC, as it boots up hit the F8 key until it giver you a sub menu with safe mode at the top and select that.
Hopefully the system will boot into safe mode, if it does you want system restore (if you use Vista a pop up window will appear on the right hand side of the screen, click on system restore, with XP just follow on-screen instructions)
All you have to do is select a date to before you performed the updated and restore from there.
Please keep us posted!!
Good luck and thanks for using FixYa!!
Mar 24, 2009 | Computers & Internet
Acer 3690 hangs with black screen
hi , check if u can run the system in :"safe mode with VGA"option, or just the safe mode???if it works in safe mode, u will need to restore the O/S to previous checkpoint, or reinstall the OS using "repair" option.let me know
Jan 14, 2008 | Acer Aspire 3690-2196 Notebook
Computers & Internet Logo
David Payne
David Payne
