Question about Radio Communications
Should the radio turn on with just a power supply and ground
  • 3,519 Answers
Hi Joey:
You and your radio should have a fine time. All you need is a 12 volt battery. Positive (Red) to + terminal. Black to the - (Sometimes Black to positive and white to negative on some obscure ones)
Connect some speakers and the antennae and you'll have the world available at 2:30 AM every clear night.
Posted on Apr 15, 2015
94 Mazda b2300 radio wiring system diagram
sorry no idea without a look .if unsure about power supply then check with a multimeter ,if your fitting another radio .thier will be a permanent supply ,supply when ign turned on and a earth or ground ,on the radio theri could be another cable thats for a electric aerial
Dec 17, 2016 | Mazda Cars & Trucks
Any trick to power up radio? Radio has 12 V connected and will not turn on
There should not be a "trick" to getting the radio to work. Make sure that the power connection is actually sending 12v. Also verify that the ground is good, that can cause issues. If possible, connect another 12v device to the power and ground and see if that one works.
If so, there may be a fuse on the radio that is blown. There are often fuses inside the case, near the power supply. If you are comfortable doing it, open the radio and see if you can find a fuse and verify that it is good. If not, take it to a radio shop and have them check it.
Oct 31, 2014 | Boating
Galaxy dx 66 will not turn on
reverse polarity diode may be blown .
Oct 16, 2012 | Galaxy Radios DX-66V Base CB Radio
How do you install a Maxon radio repeeter. It only has two wires that apear to be a Hot(Red) wire and a Black(ground). Should I just ground it and hook it up to a power suply?
Your correct the red wire is the positive and the black is the negative. You must also make sure to use a power supply with enough current to operate the radio. Usually a 12 volt supply that supplies about 4 to 8 amps should do the trick
Oct 29, 2011 | Maxon MCB-30 40-Channels Base CB Radio
I disconnected and reconnected the cobra 29 nw ltd classic and now my voice is heard very low and slow it was working fine just before disconnection. can you help
How did you disconnect it?? Antenna wire?? Power supply?? Microphone?? May be that you have a short in your coax in back of radio. Try taking it loose and screw it back in. Try new coax. Turn up Mic gain knob or change microphone. Make sure power wires are connected RED to RED(+) and Black to Black(-). Try grounding radio to metal ; if inside house ground to metal water pipes, filing cabinet, breaker box or meter box or 8 foot rod into earth. Measure SWR it should read 1.1 to 1.5. Measure power supply with Voltmeter it should be 12 to 15 volts. Check antenna plug in back of radio is my guess or microphone itself.
May 09, 2011 | Cobra 29 LTD CB Radio
My midland 1001z has power to it but all it does is give a humming sound!The mic. will key up and the tx light comes on but when I release the mic. the humming sound gets louder,is the unit screwed? thks...
If you are using a power supply. Get you a better power supply(full filtered) RADIO SHACK has many 12 volt 3 amp models. Run power wires away from radio about 10 feet away to eliminate hum. AM does hum when its near power lines, household appliances. Keep it away from TV's etc. Turn off TV then listen to it. Make sure you have good outdoor antenna like Antron A99 18ft. Fiberglass on Tv pole or Tower. If its inside car --its the engine. you need a Radio Shack Power filter. A coil of wire wrapped around a core and big capacitor on the (+) side shunted to ground by a 470uf Capacitor. Turn off engine then listen.
Apr 04, 2011 | Midland 1001Z 40-Channels Base CB Radio
Model D3057F3H Want to use it to power a car radio. What is the on / off connection and what is the 12V out let than can handle 5amp
Check the label on the power supply for the current rating on 12 volts.
The +12 volt is the yellow colored wire and the black is the ground.
To turn on the switch mode power supply connect pin 14 (for a 20pin connector) or pin 18 (for a 24pin connector) to ground.
You can use a switch so you can turn the power supply ON and OFF.
Please click on this link for diagrams of the 20 and 24 connector pinouts :-
http://pinouts.ru/Power/atxpower_pinout.shtml
http://pinouts.ru/Power/atx_v2_pinout.shtml
Sep 12, 2010 | Hi-Pro (HP-P401W) (HPP401W) Power Supply
TRC520 CB wont power up
Hello, First of all you only have the Power wire Red, and the ground wire Black to connect for 12v DC to power the unit. If you memory power it is usually connected to a constant power source such as the cigarette lighter or continuous 12V dc powersupply off of the battery. These are the only connections that should be connected to provide power. Since the unit will not turn on I suspect that the CB's power supply and regulator have been blown. Another possible choice is that the radio was working and someone removed the antenna cable and the the RF power amplifier malfunctioned taking the power supply and regulator with it. To solve this problem, check the voltages on the wires before connecting them to the radio (these should be the 12 volt power off of the radio circuit, and the 12 volt power off of the continuous 12V connector (or the cigarette lighter). These voltages should read 12V. Connect the CB with it turned off and measure the voltages (should be 12V) Turn the radio on and check the voltages (should be a little less than 12V) If the radio does not come on then the internal power supply of the radio might be defective (In this case I would advise taking the CB to a qualified radio repair shop) I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 11, 2009 | Radio Shack TRC-521 CB Radio
Safe light boston gt 20 amp
First,check the output functions of your radio.
Then test the power lead for 12+ volts and ground at the amp, also be sure the "turn-on/remote power" lead from the radio is supplying 12+ volts when the radio is turned on.
Good luck...
Feb 22, 2009 | Boston Acoustics GT-42 Car Audio Amplifier
Reads dc/dc error @ high volume
more than likely you have a bad ground and/or a power supply problem: bad wire connection, bad alternator - but check the radio's ground wire first.
Oct 15, 2008 | Pioneer DEH-P80MP CD Player
Radio Communications Logo
49 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
