Question about Samsung HM1300 Bluetooth Headset Black
The rubber piece is gone and I don't know how to attach the new one. It has a loop on it that makes no sense. The loop is on the outside and it makes it fall out of my ear. Please help.
3 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: Samsung WEP200
radio shack
best buy
staples
etc.
Posted on Jun 12, 2008
kevin647
  • 13 Answers
SOURCE: bought this approx 2 or 3 months ago. In about a
I would recommend looking into different models. The Plantronics Discovery 925 is a great model out now, but depending on your price range, there should be a great number of solutions from manufacturers like Plantronics or Jabra
Posted on Jun 28, 2011
I just bought an led light set for my new diamondback bike. Which is fine except I don't know how to attach it to the bike the pieces that came with it only attach together. Am I missing something?
If you feel pieces are missing, return the unit and get a new one. Aside from that, you would have to improvise a fastener to attach to the frame or handlebars. 7_16_2013_10_17_55_pm.jpg
Jul 15, 2013 | Cycling
Rubber plunger came off the "i" key on my Dell XPS M1330 keyboard. How do I reconnect it? I have the key and plastic pieces that attach behind it as well.
Dear peg, As you have the plastic pieces, set it as previously it has, may you don't know but do it as much as possible. One think you remember that, set the plastic such that air can give pressure on the sensor. Apply some gum on the side of the rubber. After that see the key have lock which can set on the clamp which is on the key board. Set it and apply a little pressure. It will work. In real today the keyboards are non-repairable. So do it on your own and if you failure buy a new one.
Sep 05, 2011 | Dell 0Y3740 Keyboard
1998 Kia Sportage heater return hose location....
Actually it does make sense. All you need to bypass the heater core is a section of pipe that can be used to connect the Heater core Supply and return lines together. All they actually do is make a loop using the heater core as the turnaround. This is normally 5/8 hose and any metal pipe section can be used as long as the hose fits on it and you can put a water clamp on it to hold it in place. In fact, if you have a control valve on your heater core line going into a piece of hose connected to the Firewall you can disconnect that and use it to connect the two lines together in a pinch. radiator flush kits come with a piece that attaches to these lines for flushing the system. Your supposed to cut the line and put this part in between the two pieces but you can just as easily disconnect the lines from the firewall and attach them with this piece. A Yard water hose slicing kit, metal, would work just as well as long as you have to correct size. Good Luck.
Jun 25, 2010 | 1998 Kia Sportage
PART NAME FOR A BELKIN TUNE BASE #F8Z176 FOR MY IPOD
****, I was hoping someone answered this because this is exactly what I want to know too! I don't want to spend money on a new transmitter when replacing that stupid rubber piece will probably be enough.
Feb 22, 2010 | Belkin TuneBase
99 Beetle Serpentine belt diagram
The serpentine belt on my 2001 Beetle loops around the outside of the large pulley closest to the firewall, at the bottom, then goes around the outside of the forward lower pulley, then crosses to the inside of the one right above the forward lower pulley, then loops over the outside of the alternator pulley at the top front side, then goes inside under the tensioner pulley, and back down to the outside of the big rear pulley.
I hope that description makes sense. A picture would work a lot better, but I don't have an easy way to post it. Also, I know you asked about the '99 Beetle, but I assume its routing is the same as the 2001 (which is the one I have).
Apr 16, 2009 | Volkswagen Beetle Cars & Trucks
2003 Ford Explorer back door latch will not open
Mine just did the exact same thing. The latch may be moving freely because it is not hooked to the latching mechanism anymore. In my case, the handle had broken where the handle hooks to the rod that operates the mechanism. Go to the Ford dealer and buy a new handle. Here in S.C. it was $24. You can't get this at the parts houses. Start by removing the plastic "Ford" cover that is over the liscense plate lights. You then have to remove the aluminum rivets that hold the handle to the tailgate from the outside and remove the broken latch. Remove the pull handle loop on the interior side of the tailgate (2 screws), unsnap the inside plastic tailgate interior panel, and pull down the black plastic sheeting that is underneath the panel to make access to the mechanism inside of the tailgate. There is also a hard plastic cover that you will see that needs to be pulled loose to open another access hole. Install the new tailgate latch handle by sliding back into the mounting holes and attach with two 10-32 screws and nuts. The new handle will come with a new yellow rod attachment piece on the handle. You will see inside of the tailgate a small rod hanging down, most likeky it will have the same rod attachment piece as the one on the new handle. Note the position of the yellow piece on the rod, as you will connect the new piece in the same place. Once the rod is hooked up, relubricate the metal mechanism with a light machine oil, replace the black plastic cover, replace the black plastic sheeting, (secure with a small amount of duct tape), replace the tailgate interior panel, replace the pull handle loop, shut tailgate, replace "Ford" cover over lights, and you're done!
Mar 23, 2009 | 2003 Ford Explorer Sport
I need to replace the door lack how do i do it??
the front boot can be pulled off from the front to get to it
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Samsung HM1300 Bluetooth Headset Black Logo
87 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
