Question about Garden
My new homelight leaf blower either revs too much or stops it wont idle it is the cheap model and I cant see any screws for adjustment.
Bought yesterday and goes but revs too much either full revs or half but no idle it just cuts out and I cant see how to adjust the carby.
  • 2,760 Answers
Idle should be adjustable , but if it was purchased in the u s of a since 2012 then sorry it's got a C.A.R.B. type carb on it ( google that acronym) and sorry fuel mixtures are not adjustable anymore the clean air folks took care of that for us! I thank them everyday for looking out for us all .
look on top of carb right next to cam that moves when you press throttle down , there you'll see a very small screw that's your idle adjustment
Posted on May 28, 2015
  • 4 Answers
SOURCE: Carb adjustment on McCulloch 32cc?
the l is for idle and the h is for top end but thats not ur problem it sounds like ur carb is clogged there is a screen inside of the carb the fuel gets crystalized and blocks off some and sometimes all of the fuel ill bet thats the problembut u can try the adjustments first give the unit full throttle and turn the h adjustment screw in and or out till it sounds great and at full power if that dont work then do the screen in the carb
Posted on Nov 14, 2008
boscia
  • 163 Answers
SOURCE: Leaf blower will not achieve full RPM's
try removing the muffler and scraping out any carbon build up in the exhaust mouth of the block. if that doesnt help you will probably need to replace the carb.
Posted on Nov 29, 2008
  • 398 Answers
SOURCE: I relpaced the fuel lines on my Mccullough Eager ****** leaf blow
ok then these are the low and high speed adjusting screws. first make sure the spark plug is clean of buildup or new . what you need to do is first try to get it to idle with the low adj screw. now im not sure which ones which so try one and if it makes no difference during idle then try the other. start it if it dies turn the screw , repeat this until you get the right sound and steady idle.once you figure out the low screw trun it all the way clockwise then turn it counter about 2 turns. then tune the idle from here. you want it to have a steady sounding idle. now the idle sounds good use the high screw to adjust the throttle. give it about half throttle and turn the high screw until it sounds steady here. then go to full throttle and turn high screw until it sounds steady here. now it should sound steady at idle and throttle. and try not to trun the screws more than 1/8 to 1/4 turn at a time,especially the high, you dont want to blow it up. lemme know how it goes
Posted on Mar 22, 2009
SOURCE: low rpm's from Echo PB-251 leaf blower
Too much oil in gas.
Posted on May 25, 2009
bbap
  • 71 Answers
SOURCE: I have a John Deere 2E leaf blower. Lately it has
The H (High Speed) and L (low Speed) should not typically need adjustment. What happens is the diaphragms get stiff and do not operate efficiently. If the unit is over 5 years old and/or the fuel is not completely drained with the unit run dry at the end of the fall, then I would suggest replacing the diaphragms within the carburetor. This along with spark plug change, air filter cleaning and a check of the muffler to insure it is not clogged is considered a basic tune-up.
Posted on Sep 27, 2010
How to start to adjust,idling screw on blower
Idling screw or 'tick over' is adjusted by a tuning screw on the carb, usually marked with an [ I ] Turn it clockwise until the revs increase and the engine ticks over without stalling
Apr 23, 2016 | Garden
I have a echo 330 evl it ran good till i left it set 3 years it started easy wont rev got a rebuild kit soaked in carb cleaner all nite blew it out assembled it put gas in started still wont rev
air cleaner is clean? was rebuilt ? good spark plug? is there a air / fuel adjustment screw or a high / low idle screw on the side of carb. that may be out of adjustment? fuel lines are in good shape? (not cracked or broken sucking air in)?
Jan 11, 2016 | Echo Garden
I have a 5hp 2cycle snow blower. It revs too high. What should I do?
You can adjust the idle screw, u can also make the spring tension a little loose than before.. if someone removed the linkage, then it was reinstalled incorrect. Also your carburetor may have the air adjustment screw on the side of it. U turn that in short increments to adjust the air fuel ratio.
Nov 20, 2015 | Garden
I have a echo pb251 gas blower,stop running,has spark,rebuildt carb.fuel filter,after no start,plug is wet & sparks but wont hit/start
screw air mix screws in the out like a half turn each, one controls the high end speed and one controls the idle, do idle first and adjust just a little rich then do high speed screw.
Nov 03, 2014 | Echo Garden
My 130bt blower with start an idle fine but wont rev up
adjust the high speed screw on the carb. It is marked with an "H".
Nov 07, 2012 | Husqvarna 295cc Back Pack Blower HVH 130BT
What does "h" or "l" stand for on a carburator adjustment screw ?
H is the high speed adjustment ( screw in to lean the mixture and increase the revs, screw out to richen and decrease revs ) I is the idle screw, this will adjust the tick over speed of the engine, you can also have a srew marked L this is to adjust the low speed running by leaning or richening the fuel mixture
Jul 21, 2012 | Garden
Echo pb-620st will not crank
Simply use a srewdriver to adjust the mixture screw. Its located on the carburator. Clockwise is lean, counterclockwise is rich. If you can get the thing to idle, let it warm up first. Adjust the mixture lean until it just starts to sputter, then adjust it rich 1/2 turn. Test full throttle, if it sputters, you can adjust the mixture a little more rich so that it runs good at full throttle.
I would suggest steering away from investing in 2 cycle engines for a pawn shop, unless you can see them running. These little engines are very picky and they only run well if they are in good shape. If you cant get them to start easily, there is probably a lot of internal wear/damage and these engines are hard to find parts and are not cheap to fix.
Bad investments would include 2 cycle leaf blowers, trimmers, chainsaws, boat motors, and motorcycles that do not start easily. Believe me, they are a headache to fix.
Mar 27, 2012 | RTO Echo 25.4 Cc Backpack Leaf Blower -...
Wont idle have to run on 1/2 choke
yes, i have one myself. you must adjust the carb. there should be two screws to adjust the gas and air flow. try adjusting them to the right, both of thlem
May 15, 2010 | Homelite Consumer Products MightyLite...
How to adjust a carburetor on a Mighty Lite Handheld Gas Blower model# UT 08520 ?
if you take apart the carburator youll see a screen under the plate on one side once together turn the mixture screws in all the way till you feel it seat or tighten then back out each screw 1 to 1 and 1/2 turns then start the engine the key is to get it to idle once it idles turn the mixture screw the low side it will say l or h below the screw turn it in which clockwise till it runs smooth then back out slightly till it just starts to miss then rev up the throttle and adjust the high side which is towards the filter turn the mixture screw in till it revs to the highest point which I call the sweet spot your pretty close to what you need
Nov 08, 2009 | Homelite 'Yard Broom' Leaf Blower
I have a hb180 homelite leaf blower and want to know how to adjust the 'two' little screws on the side and what they do
if its the carb screws your talking about
one it for fule mixture the other is for air,,,
air for tickover fule mixture for rev's
if its running well leave them be?
Oct 30, 2009 | Garden
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
