Question about Leupold GX-3 Digital Golf Rangefinder
My distance readout red numbers on the screen is very dim for the lower half of the numbers so that I can't make it out. Any thoughts or suggestions please ?
LG 55LH90-UB LED TV I have an LG 55LH90-UB LED tv that has, what seems to be, sections of dim areas.
Hi ,
try swapping the screen with another one to just see if it is behaving the same, because some times the screen circuitry or the led screen could be damaged .
good luck buddy
May 18, 2017 | LG Televison & Video
Digital readout on one side is dim
Display beginning to dim from the left towards center ... - iFixit
https://www.ifixit.com/.../Display+beginning+to+dim+from+the+left...
iFixitApr 15, 2011 - The display on my brother's MacBook Pro 17" 2.5 GHZ (early 2008) has begun to dim, but just on the left side, as though one column of lights ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Dec 14, 2013 - Uploaded by lcdmasters.net
The video shows the process involved in repairing the following lcd & led tv screen display problems ...Missing: digital
C5 Climate Control dim/dark display fix - Corvette Forum
www.corvetteforum.com/.../1583758-c5-climate-control-...
CorvetteForumDec 28, 2006 - C5 Climate Control dim/dark display fix C5 Tech. ... 4 screws total, size 15 torx screws, two on the top, one on each side towards the bottom. ..... WoW I have a digital display that works, I have been driving around guessing ...
Cheap Fix for a Dim Display on an Oven Control Panel ...
fixitnow.com/.../cheap-fix-for-a-dim-display-on-an-oven-control-panel/
Jan 28, 2009 - A common problem on ovens and ranges with the digital display is that the display ... 1. Replace the electronic control board, typical cost: $250.
Dec 13, 2015 | Image 15.5s TREADMILL Console
I have a Powertred 7.0 Softrak treadmill made by Hebb Industries. The LED Readouts for speed, distance and time will only read 000.Pressing the reset key does nothing. Any suggestions on how to fix
adjust the Reed switch see the diagram attached, clean it, and tigh the plug very well.
2) tight the ribbon inside for keypad, and clean it.
3)tight the connector from display board vs lower board.
4) Run finally the software calibration for diagnostic, troubleshooting and fix it.
God bless you
Sep 21, 2012 | Exercise & Fitness
Asus Eee PC 1215n half screen on the right is white, the other half is fine
The LCD screen in your laptop is defective, the only option is to replace. Go to www.ebay.com Type: make and model of laptop, refine search to screen.
May 23, 2012 | ASUS Eee PC Seashell 1215N-PU17-RD...
LED readout is getting very dim. I reset the computer but it's still dim, and only about half the numbers are visable.
Hi
The issue is with the display panel that is bad or the connection to the control is loose. TO check what is causing this issue you will have to take it apart and check the board, if bad then it should be replaced. Hope this helps...
Daniel
Jan 07, 2011 | Microwave Ovens
17" flat screen upper half is dark until "thumped"!
The inverter board that controls the lighting on the screen is dying. since its a 5 year old monitor and only a 17 inch. the cost to repair is greater than the cost of buying a new one. unless you know how to replace the part yourself. I think its best to just buy a new monitor
May 04, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
Samsung HPR-5052X Plasma issues. Recently started
If the picture os goint to lines right from the midpoint downward then most likely you will have to replace the lower y-buffer board part number BN96-02027A. The board is mounted on the left side of the plasma panel when you take the back off. The upper y-buffer board sounds like it is failing as well and this was a very common issue on the older Samsung plasmas. The part number for it is BN96-02026A. Please take a moment and rate my answer. Thanks...
Nov 26, 2009 | Televison & Video
Lower half of monitor goes dim
Replace the backlight in this unit will bring you back in business.
Thanks please rate.
Aug 19, 2009 | Star Logic 17" LCD Monitor
Altec Lansing im600
GET IT REPAIRED IT HAS A TECHINICAL FAULT
Nov 24, 2007 | Altec Lansing iM3 Computer Speakers
Screen goes dim under different user
could be an issue of his resolution and refresh rate settings are close to being out of range for the monitor. Try lowering these settings to get better performance.
Oct 25, 2007 | HP Vs17 17" LCD Flat Panel Monitor
Leupold GX-3 Digital Golf Rangefinder Logo
449 people viewed this question
Top Leupold Optics Experts
ray gallant
Bill Boyd
Are you a Leupold Optic Expert? Answer questions, earn points and help others
