Question about Dryers
It takes a long time for My profile to dry clothes
    Master:
  • 501 Answers
Check the lint in the big screen,also check its on hot setting,check the back,to see if outlet air hole not blocked
Posted on Apr 15, 2015
  • 188 Answers
SOURCE: dryer not heating properly..taking longer to dry clothes
If there's heat inside the drum the heater coils should be ok, however your model has 2. With the door open and the machine running, look inside at the back of the drum and look for 2 glowing element coils. If one is not working you will not have enough heat.
Check the exhaust vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
If there is no heat, first check for 240V at the outlet. If you have 240V, it could be the element, the hi-limit thermostat, the thermal cut-off, the timer, the motor or a wiring issue (loose or shorted).
Good luck!.
Posted on Mar 06, 2009
carlsbiz
  • 1124 Answers
SOURCE: Dryer takes a very long time to dry a load.
Some dryers have more than one heating elliment..
A way to check is -- take the exaust hose off.. Put a mirror so you can see into the hole & hopefully see the heating elliment(s).. When running they should glow like a stove burner..
If it is not gloing its not working & needs to be replaced..
I suspect that one may have went out..
I hope this helps !!
Please rate me good ;o)
Posted on Jul 12, 2009
localwonder
  • 6784 Answers
SOURCE: I have a GE Profile dryer. The dryer is squeekly
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Concerning the squeaking sounds. this can be caused by a bad drum belt or a leveling issue as well. more issues will be bad drum support rollers or, a failing bearing assembly in the idler pulley. the blower, baffles and guides will deteriorate as well, causing noise overtime. These are most of the uncommon issue that will cause this issue, but the most common issue will be failed idler pulley bearings. The pulley will tend to squeak very loudly if the bearings are worn.
Access to the idler pulley varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be taught and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Turn the idler pulley wheel, it should turn smoothly, quietly and without any wobble. Inspect it for cracks or uneven wear. If the idler pulley does not maintain proper tension or is damaged it should be replaced. Depending upon your model, the entire assembly or just the wheel or bearing may be replaced.
Posted on Jul 30, 2009
SOURCE: GE Profile takes too long to dry a full load of clothes
could be holding coils not opening all the time
Posted on Sep 27, 2009
  • 256 Answers
SOURCE: My dryer runs and gets hot but cloths don't dry.
Your problem may be attributed to a clogged exhaust system (e.g.: clogged inside the dryer's vent, flexible vent behind dryer clogged and/or clogged inside wall, etc.).
Posted on Feb 22, 2010
The dryer is not drying the clothes. It takes two
Take you vent off and remove the restrictions. How about a few repair pix?
Sep 25, 2009 | GE Profile Prodigy DPSR513GA Dryer
My dryer is taking 2-3 cycles to dry clothes most of the time, but last night it did two loads the first try and then is back to 2-3 cycles today.
Remove the connecting vent material from the rear of the dryer. Run a regular cycle. If it dries normally,find and clean the blockage in the connecting vent.
Aug 26, 2009 | GE Profile Prodigy DPSR513GA Dryer
My dryer takes long time to dry the clothes. It
1. Venting
2. Thermostat
3. Heating element
NOTE***(This unit is equipped with a dryness control board. if all points above check out ok, replace this board).
Jul 21, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer taking too long to dry clothes
Hello :)
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem.
Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Apr 03, 2009 | GE Profile DPSB620ECWW Electric Dryer
Taking long time to dry
An innovative dryer, the General Electric Profile Harmony DPGT750GCW(gas) / DPGT750ECW (electric) has the ability to communicate with its matching washer via the manufacturer's CleanSpeak system. More specifically, this Profile dryer is wired to the Harmony washer, allowing electronic communication between the two. If you're wondering what these two have to talk about, the answer is simple. They talk about your laundry and how to dry it.
CleanSpeak works by transferring information about a wash load to the dryer and setting it automatically so you don't have to make any. Machine-determined optimal settings for each load are selected by the information about each load size and type. Your job is simply to place the wet laundry in the dryer and press start.
That is where the problem begins, when you interrupt the drying cycle. The machine is then rest to small load dependent on when the interruption occurred. The dryer computes the duration of drying time again the wash load. Each time you load the washer, the dryer is computed to using the shorted time. Thus, we have double cycle.
you will need to override the automated settings and enter your own preferences. Doing so can be a bit complicated, as this machine has lots of intricate, detailed controls that may take some getting used to. In fact, we suspect that's why this dryer is designed to be set by the washer. Having individuals set it, with all its options, takes some patience. The good news is that once you have manually set cycles you have found to use often or like, you can enter them in the memory, allowing the machines to set them your way in the future.
Option is to unplug the machine and wait minimum of 2 minutes and plug in the machine, hit power on.
I would recommend unplugging both machines, and rest both to factory default.
good luck
Nov 05, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
before we do that run a load in the dryer with the vent in the rear off the unit It sounds like the vent going to the outside is clogged more than a dryer problem if it drys ok then you know that is the problem if not it is internal I will send you the book either way let me know
Aug 03, 2008 | GE Profile Harmony DPGT750GC Gas Dryer
Clothes are not drying
your blower motor is probably not working. enter the troubleshooting mode by pressing and holding my cycles and help at the same time for 3 seconds. this will tell you the problem. if blower is not getting up to speed you'll have to replace it.
Dec 03, 2007 | GE Profile Harmony DPGT750GC Gas Dryer
Dryers Logo
48 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
