Question about Samsung CoolTech Plus / Basic Bottom Mount Refrigerator SR-L676EV
Refrigerator temperature set at 3 Celsius but freezer temp keeps flashing between -14 & -22 with a very annoying alarm going off. How do I reset this and stop the alarm going off?
  • Lyn Paola
    Lyn Paola Apr 16, 2015
    Alarm has now stopped and temperatures have reset by themselves. Thank you for trying to help.
    Top Expert:
  • Samsung Master
  • 10,875 Answers
Set it to 10 c
Posted on Apr 16, 2015
I had this problem on my RL34 Samsung. Alarm goes on without reason; temp is ok and light off when door closed. I opened the small plastic cover on its backside and cut the supply for the Beeper: Done!
refrigerator temperature set at 3 Celsius but free - refrigerator-temperature-set-3-celsius-vmazde3ijvdrctdgk4gqn0bf-4-0.jpg
Posted on Feb 06, 2016
SOURCE: fridge tempertature
I have the same symptom too - freezer temperature flashes at -2. "Power Freezer" or setting it to any other temperature is not working either.
As a result, no ice being made. Please help!
Posted on Sep 01, 2008
  • 400 Answers
SOURCE: samsung refrigerator freezer not freezing
-2 although below freezing temperature, is not really enough to keep food really frozen. I am presuming we are talking in Celcuis. You need to set the freezer to a lower setpoint.
Posted on Mar 09, 2009
SOURCE: Samsung double door refrigerator/freezer is not
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
Posted on Jun 21, 2009
  • 66 Answers
SOURCE: My Samsung Refrigerator can not keep the set temperature.
Normally your fridge is set +2 degrees C. with a differential of 3 so when it reaches +5 it should switch back on. if this is not doing this then a new thermostat may be in order.
Posted on Apr 18, 2010
MNTECH
  • 1543 Answers
SOURCE: The digital display resets to 0 F for BOTH the
The OF OF display is the OFF setting, used for display purposes, so the light and controls light, but the refrigerator does not run while it is on display at a dealer. Try pushing in and holding the top two buttons on the left side of the display for about 5 seconds at the same time to get it out of the display mode. You should be able to set temps then.
Posted on Jun 20, 2010
Testimonial: "Thank you MNTECH, that seems to have worked. (I have it on power freeze and power cool now to quickly return to the proper temps) Background: We had family & friends over using it for ice & cold water and one person unfamiliar with the feature was tapping the buttons. She must have hit the sequence to send it into "display" mode as you correctly surmised. Will check the frig in 20min to see if it is getting cold again. But I think that was it. (The display does now read -4F and 34F which are the temps I typically have it set at)"
Model E402b. Why is the alarm going off?
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jun 02, 2015 | Fisher and Paykel Refrigerators
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
May 03, 2015 | Refrigerators
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Apr 10, 2015 | Refrigerators
Open door 18 beeps lights flash red green fridge not cooling
Mar 14, 2015 | Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
My whirlpool side by side fridge freezer power cut alarm will not stop going off temp display is reading -7 degrees Celsius in freezer but I put therometer in it and that is saying -17 degrees Celsius...
Are you sure it's not a temperature alarm rather than power? Check the thermistor isn't in a block of ice, give the freezer a good defrost, and check the condenser is nice and clean.
Apr 25, 2014 | Refrigerators
What is ideal freezer temp setting ?
dear sir /madam
the ideal freezer temperature is 0 fahrenheit(-18 celsius) for storing food. and - 10 fahrenheit (-23 celsius) is recommend when freezing food.
and generally 3 to 5 celsius (37 to 41 fahrenheit) is ideal for refrigerator
hope answer the question
thank you
please vote!
Aug 17, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Freezer temp
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} hi!! we have read your problem..every problem has a solution.the temp depends upon your need.if you are using stronly freezers for storing food items like meat, then you can set the temperature to (0-10) degree celsius. else you can set it to (5-15) degrees.always keep the liquid items closed in the refrigerator failing to which it causes crystals.it also costs dearer since you have to defrost then. so always keep your food items covered.hope your problem is tackled..have a nice day
May 22, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerators Logo
405 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
