Question about Hunter Douglas Sheer Horizontal Window Shading 53-1/4" x 47", Picket Fence
Roller sheer blinds cord Broke now cord is stuck and can not move blind up or down
How to remove inside mount hortizonal blinds
I am pretty sure that there will be a set of brackets that hold it in place but they are usually cleverly made so as to not interfere with the look of them , I suggest you use a small ladder so that you can view the very top and even inside the top section that has the mechanism that controls the blind slats as it might be inside there that the brackets are hidden. If need be use a small mirror and a torch so that you can inspect it properly and usually they will be of a clip type in nature that needs to be unclipped using a small flat headed screwdriver to release there hold on the blind but you will probably find they are also screwed into the wall ether by way of wooden batten or into concrete or brick but it shouldn't be necessary to remove these. A hint in what to look for thin metal strips painted same color as blind sometimes been attached directly under neath as a support or been used on the inside where the blind adjustment mechanism parts are also the blind could be supported by a system that hooks onto the wall and the only way to remove it is to apply a force in a upward motion ( usually by using the palm of the hand and knocking it straight upward ) as normally it would never receive any upward pressure in normal use only a downward one so this method gets used frequently to support objects . But your best bet is to inspect it carefully as there are many methods industry can use .
Oct 23, 2017 | Cars & Trucks
Where do I go on your website to find out the types of blinds you have and wether they can be made to order. Your website is not informative
You say blinds? You mean roller blinds or vertical blinds? I have used 'Capricorn Blinds' in the past. Not sure whether they are still going. They're a little expensive, but make a decent product to the size you request.
If you enter on the search on your computer. 'blinds' ? Roller blinds, vertical blinds you should have a number of companies show.
If your going to do this over the internet, you are going to have to measure up the blinds yourself and they will then make them to the spec you want. I would advise you do not measure in inches, but use centimeters OR millimeters as that will make the measurement more accurate.
Apr 12, 2017 | The Computers & Internet
Accordion blind repair and removal. bedroom blind in 396V on drivers side. strings are broke, and blind cannot be removed?
take it to an rv repair shop or a blind and curtain repair shop
it is installed as a unit so removal will be the opposite
it is the method that you will have to get advice on
Feb 04, 2017 | RVs
How do I repair a horizontal blind
Do you mean a roller blind
Mar 05, 2015 | Sewing Machines
Could it be rollers that don't pick up paper
I would guess it is the rollers. You can try to replace them. You can order them online. To find out what type you need, look on the back of the printer for the make and model.
Elisa Jed ' http://www.blinds2go.com.au/blind-parts/roller-blind-parts/
Apr 07, 2014 | Brother MFC 7420 All-In-One Laser Printer
Velux blind problem stuck
Check the wires to the blind mechanism. Power might not be getting to it.
Mar 31, 2014 | Velux VSE-C06-2104-RM Copper Frame VSE...
How to repair the pull cord on window blinds
it takes time and patience. if there is extra cord you can pull it through and try to make it work. Sometimes if you have shortened the binds ther ewill be extra cord. use this.
Sep 22, 2012 | Televison & Video
Can not open the wooden window blindes.
try to see if the rope that controls the up and down motion for the blind is not binding against the stick knob that it is attached to in order to see this you have to take the blind down and look at it from the top
Nov 12, 2008 | Hardware & Accessories
Hunter Douglas Sheer Horizontal Window Shading 53-1/4" x 47", Picket Fence Logo
742 people viewed this question
Top Hunter Douglas Home Fencing Experts
crkuc
 Russ Hill
Russ Hill
ray gallant
Are you a Hunter Douglas Home Fencing Expert? Answer questions, earn points and help others
