Question about Boating
My boat just stopped running and I can not get it to run again.
  • 1 more comment
  • Alexander lubbers
    Alexander lubbers Apr 17, 2015
    it is a 7004 rc double horse boat
  • Ian Summerfield
    Ian Summerfield Apr 17, 2015
    whats a double horse boat?
  • Ian Summerfield
    theres about a 1000 reasons why a boat stops.also try marineengine.com
    Master:
  • 501 Answers
Try new batteries
Posted on Apr 15, 2015
I have a merc 40 hp x 4 engine starts and runs fine but every 20 to 30 minutes it decides to just stop dead after a few minutes it runs fine again,
this is HP computer forum , not BOATS
but can answer ,
bad fuel!! all boat fuel goes bad, parked, so long, ALL DO.
too much oil in fuel (is it 2 stroke engine? no year given,so.,....)
carb, filthy, im cleaning my 40 hp now, in the garage, and wheel grease.. (fishing next,cat fish... hummm)
can be bad spark plugs. ever tune it up. with new ones?
water in fuel. rust in tank if tank is steel.
wrong fuel someone put in diesel
low compression (3 cylinders like mine?)
May 25, 2017 | HP Computers & Internet
Intermittent starter issues. On my boat it very hard to access the starter and solenoid. When my boat starts it runs perfect. I can start and run it and shut it off numerous times. Now twice it has refused...
replace the solenoid,but,if you are worried about being stranded,while you are there,replace the starter and on all connections,use electrical grease,to keep corrosion away,always use lock washers so nothing gets loose too.
Jul 20, 2015 | Cars & Trucks
35 hp mercury
Pices of impeller could be stuck in block,put hand on top of block and feel if it is running hot,blow compressed air into tell tale and see if that helps
May 12, 2014 | Boating
Engine cuts out when slowing down
Start off by cleaning carbs,sounds like idle jets are blocked
Feb 27, 2014 | Boating
1989 maxum boat manual
CHECK COIL OUTPUT WHEN IT STOPS RUNNING. A HEATED COIL CAN HAVE INTERNAL WIRING THAT LOOSES CONNECTION AFTER HEATING UP
Jul 21, 2013 | Boating
Evinrude troubleshooting power trim
1. check all connections to the switch and pump and make sure they are not crossed.
2. Replace the switch
May 08, 2017 | Boating
What would cause the lawn mower to stop running when not out of gas? If you give it a few seconds and restart it it will run again for awhile then stops. I have noticed if I pump the primer a couple of...
Try using non-ethanol gas. It's death on small engines. Starter fluid gives it a boost if higher octane. Have a reputable repair place clean out the gunk, then use good gas. Best of luck finding non-ethanol. Boating marinas carry it.
Jul 20, 2010 | Mtd 22" Yard Machine Push Mower
Boating Logo
435 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
