Question about Mitsubishi Televison & Video
I have a mitsubishi wd 60737. How can I check the bulb time? I can't find where I need to look to find that. I feel like it's gotta be really high. My picture is dimming. Thanks for the help.
  • Mitsubishi Master
  • 3,957 Answers
After reviewing both the user and service manuals, it appears that this option is not available. If your picture is dimming, and resetting the brightness levels does not help, it is time for a bulb change (which you can do yourself - plenty of references on the net.)
Posted on Apr 15, 2015
  • 23 Answers
Hey, if still interested the hours for the bulb is available only in the factory mode settings in which u do not need to go into unless a service tech because of if settings are changed in certain areas could result in set not coming back on and then will have to get a repair to work on it and costing more money. To help pull bulb out behind the lamp door loosing screws and being careful not to touch glass and take a flashlight shine down to see the back of filament and look for either a dark spot or white spot and this will also tell u lamp on its last leg, hope this helps.
Posted on Apr 21, 2015
    Top Expert:
  • Mitsubishi Master
  • 74,136 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
  • The Knight
    The Knight Apr 15, 2015
    Just search the above linked site by type in "How to replace lamp Mitsubishi projection TV" in the search box at the top right of the opening window. You can get details from it.
  • 556 Answers
SOURCE: Our Mitsubishi DLP WD-60737 is only one month old.
Call Mitsubishi and find out who is the closest warranty repair service station in your area, they will take care of this for you.
Posted on Sep 04, 2009
  • 541 Answers
SOURCE: Mitsubishi WD-60737 will shut off on its own while
These units had problems with capacitors in the power supply and main boards. Unless you like really hard CHINESE PUZZLES you are best to leave this to a pro.
Posted on Oct 13, 2009
lovejoy91
  • 691 Answers
SOURCE: listening to tv audio sound
Try to do a hard reset first
Posted on Dec 14, 2010
SOURCE: Mitsubishi Wd-60737 cut off on its own. Sound works, no picture
How do you clean tha filter in mitsubishi television
Posted on Apr 14, 2011
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WD- 73737 73 in. Screen if dim or dark. Changed contrast, brightness, and restored default settings but that didn't work. Help?
I am not sure about your model but a call to Mitsubishi to ask if the set has one or two mirrors would offer a possible explanation---the ones with two mirrors have a small one at the bottom--it gets coated with dust and brightness drops up to 75 percent----other possible reason is the lamp may be nearing the end of its life.
I would have Mitsubishi look to see if this model uses the two mirrors--if that is the case cleaning will cure this--if you find it has two mirrors I can tell you what is involved--on Vacation but do look here--let me know what you find.
Posted on Jun 26, 2012
WD 60737 error code 12 what do i need to do. We replaced bulb and now it just flashes red
Error code 12 is no problem found. I would make sure I had the right bulb, make sure it is seated properly, and make sure the door to the lamp box is on correctly. If that doesn't work, and you still have the old bulb, put it back in. Even if it doesn't work it will display a bad bulb code and not the current one if your new bulb is incompatible. Sometimes that happens when you get a new bulb with incompatible specs.
Sep 11, 2016 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi wd-60737 fan problems
i have the same tv i replaced the lamp n now its a oange blinking light on
Feb 27, 2014 | Mitsubishi WD-60737 TV
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Oct 25, 2012 | Mitsubishi WD-60737 TV
Fan broken mitsubishi wd 60737 want to repair replace
Fan should be easy to replace try Encompass Parts Look on their website or try Mats Electronics for replacement fan.
Oct 08, 2012 | Mitsubishi WD-60737 TV
Flashing orange light on mitsubishi 60737
The orange blinking light means a light bulb needs to be replaced. You should go to a Mitsubishi store and see if you can get one. Good luck
Take the old one with if you can get it out.
Aug 01, 2012 | Mitsubishi WD-60737 60 in. HDTV
Mitsubishi WD-60737 will shut off on its own while running on it's own surge protector and it's not overheating
Oct 12, 2009 | Mitsubishi WD-60737 60 in. HDTV
Our Mitsubishi DLP WD-60737 is only one month old. As of last night there are solid vertical lines running through the entire set. Please help
Sep 04, 2009 | Mitsubishi WD-60737 60 in. HDTV
Televison & Video Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
