Question about Home
I use C2O cartridges in my whipcream dispenser. Can I interchange these in my Fizzini? Only diff seems to be the price.
  • Sophia Gubbins
    Sophia Gubbins Apr 18, 2015
    I have an older whipcream bottle (commercial grade -- name unknown) I buy generic C2O cylinders from my 'bakers supplies' to charge it. The cylinders that came with Fizzini (Yule gift) LOOK exactly same. I have not TRIED generics in Fizzinni. Worried about potentially voiding warantee.
Are cheetah and daisy cartridges interchangeable?
the make of the cartridge is irrelevant
the number on the side has to be the same
for example a hp genuine 61 xl is the same cartridge as a generic 61xl
go to a printer re- inker shop and ask them for interchangeable cartridges
Sep 03, 2015 | Epson Office Equipment & Supplies
Can you switch a rear diff from a 1997 subaru legacy wagen with a 2.2l inter changeable with a 1997 subaru legacy outback with a 2.5l ?
the biggest draw back that you will have to check first is the ratio of the diffs you want to change. If they are not the same but will fit then you will destroy the 3rd diff in the transmission from excessive use.
Aug 09, 2014 | 1997 Subaru Legacy
Will a 3.1 liter engine out of a 94 pontiac grand prix fit into a 98 chevy malibu, and what is the significance of vin code "m"?
I looked it up and it shows that these engine have diff. sensors to comunicate with computer and possible exhaust and intake are diff.,
check it out, 94 has OBDI the 98 has OBDII
I put the engines next to each other and compair,
94 engines are all by it's self.
98-99 engines are interchangeable
Good luck
May 20, 2010 | 1998 Chevrolet Malibu
Are the ink cartridges interchangable between the lexmark 4650 and the 4690? They certainly appear identical in every aspect.
Hello. The only common cartridge the X4650 and the X4690 uses is the #31 photo color print cartridge. Other cartridges for the printers are non-interchangeable. For your reference, you can click on this links to the Lexmark website. http://bit.ly/asi8dB and http://bit.ly/bvNeOa . First link shows you compatible cartridges for Lexmark X4650 and the second link is for Lexmark X4690. Hope this helps.
Mar 14, 2010 | Lexmark X4690 Wireless InkJet Printer
Dishwasher rinse aid doesn't dispense, glasses are spotty.
ok here is the best i have on this matter.
your question should have included a model #/make,only so i can givealittle more info. whenever your dispenser is not working 9-times out of 10 the dispenser has tobe changed. on some models you can get a kit to recondition the dispenser ,but to me its always better to replace the dispenser. replaceing a dispenser is not that hard if you have the no how. the door panel has to come off and the dispeser in some cases has to be unplugged from the unit. the dispenser normally has tabs that has to be snapped in and snapped out. after the snaps push the dispenser in the opposite way to remove and when you change go in the other direction. 1 tip the gasket can be lubricated to snap in easier. once you snap in plug back up and rescrew the panelthat should do it . if you need to have it service you can go to searspartsdirect.comand see the image and order the part at this site. call ten tech and askthem whats the price on changing the dispenser only .who ever has the best price and seems like they know what they are doing go with them. if this helps. send me a 4 thumbs up post thanks !
Mar 03, 2010 | Dishwashers
Soap dispenser not pumping. should i send this or is there an easy fix
Inside the dispensor pump cartridge is a small ball that acts like a valve; it gets stuck or gummed-up,or dirt particles may lodge against it therefore the ball does not seal the valve hole and no pumping occurs. You can disassemble the cartridge if you have the patience, or contact price pfister for a replacement. Note: the handle is not part of the replacement; the cartridge is a general part that fits many styles of decorative matching fauctes. Goodluck, Macgivor
Jan 15, 2010 | Price Pfister Marielle Kitchen Faucet with...
Soap dispenser drips contiually after use, It doesn't seem to matter how much soap the dispenser has in it, once it is used it will continue to drip until it is almost empty.
You got a dud.  Take it back to the store for exchange or refund if your within 30 days.  If not call Price Pfister and tell them your model # and they will send you a replacement for free.  They have really good customer service.
Price Pfister Help Line:7:30am to 4:00pm PST, Mon-Sat
1-800-PFAUCET (1-800-732-8238)
Fax: 1-800-713-7080
Oct 25, 2009 | Price Pfister Marielle Kitchen Faucet with...
Cocoa latte hot drink maker
replacement parts for valve, lid, and bowl can be found here
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3169&secid=53&linkon=subsection&linkid=118
part no. description Price
U27-2 Lid, White. CA series
$3.50
U18-182 Blending Jar with Built-In Stir Paddle
$12.00
U17-104 Dispensing Valve, Beige. Interchangeable with all Cocoa Latte Models
$5.00
Jan 23, 2009 | Back to Basics CM300 Coffee Maker
I have an copycentre c2o with open heat error is there anything i can do to fix it
Replace the fuser. There is a weird induction heater in the heat roller that blows . Look up "the parts drop" on google. Call Britt and he will give you as good a price as you will receive anywhere.
Its very very easy to change, takes less than 5 minutes if you have no clue what your doing.
Aug 25, 2008 | Xerox Office Equipment & Supplies
Home Logo
550 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
