Question about Karcher Garden
Used unit for 30 minutes then just stopped working. Has power and water to unit
Descaling rancilio
Use Citric Acid.
  1. Dissolve about one tablespoon of citric acid in the water reservoir.
  2. Fill the boiler completely. Open the steam valve and start a hot water cycle until water comes out the steam vent. Stop the hot water cycle, close the vent.
  3. Let the boiler heat up about 5 minutes. Then turn off the power.
  4. Let the acid solution work for about 1/2 hour.
  5. Pull a 30 second shot to change the water in the boiler.
  6. Repeat flushing cycles (steps 3, 4, & 5) until the water looks clear. Refill the reservoir with water and acid as needed.
  7. Wash out the water reservoir.
  8. Pull 5 or shots to get the acidic water out of the boiler. Run a hot water cycle to clean the acidic water out of the steam vent.
  9. Let the unit come to temperature and look for leaks.
  10. Make some coffee and look for leaks.
  11. Froth some milk and look for leaks.
Jan 18, 2014 | Rancilio Audrey
I have a Duracaraft Humidifier DWM-250 series. It was working perfectly fine for 2 days. Then it stopped producing mist. I have cleaned the heating element, not used it for almost 24 hours just in case...
It may have a scale and mineral build up, prior to using bottled water.
To clean it, empty the tank of any water that's already in it and fill it with a 50/50 solution of White Vinegar and Bottled Distilled Water. Allow the solution to sit in the tank for 30 minutes, before turning the humidifier ON. Once the unit is ON allow it to run for at least 30 minutes, then check to see it if it's misting, by holding your hand in front of the nozzle. If it is, allow it to run until the tank is 3/4's empty. Turn the unit OFF, unplug it and pour out the remaining solution. Then fill the tank with Bottled Distilled Water and run the unit for one hour. This will allow enough time, for the Distilled Water to flush the system. After that, fill it again with Bottled Distilled Water and use the humidifier as you normally do.
If it didn't start misting when you turned it ON. Allow the solution to set for 3 hours and then try it again.
Hopefully, this will solve your problem. It does 95% of the time. Please let me know if it worked for you. Thanks.
May 05, 2011 | Heating & Cooling
Water pressure has decreased and now heater only works once in a while
The unit is clogged with mineral buildup. You will need to pump an appliance cleaner or just vinegar through the unit for around 20 the 30 minutes to remove the buildup. Contact Bosch for replacement washers, you need them to reassemble the unit.
Sep 07, 2010 | Bosch & Power Vent Water Heater
I have a Goldstar GHD30 dehumidifer that I bought used last week. It's pulling 20-30 pints of water each day out of my basement so it appears to be working. The compressor only runs for 1-2 minutes at a...
yes cycles should be longer either that or the unit is keeping close to desired humidity. Also the unit is under sized 30 pint is for 400sqft. or 20 by 20 room. humidity should be 30/50 percent check your level desired room temp is 70 degrees but its a basemnt 60 works.
Jul 28, 2009 | Goldstar DH504EL Dehumidifier
I own a 3.86 model and have used it two times. I
was you using the machine on a electic extension & was it full unwoven.
chance thermal overload in switch knocked out.
there is also a little micro switch on the bypass valve that might be stucking , just in clip and test.
Jul 02, 2009 | Northstar Professional Series Pressure...
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Garmin C340 GPS - Will Not Power On
Thanks. This helped me fix the problem.
Apr 02, 2008 | Garmin StreetPilot c340 GPS Receiver
Dehumidifier
IS THE ROOM HUMIDITY LOW. IF IT IS BELOW 30% THE HUMIDISTAT WILL SHUT DOWN THE UNIT. THE AMMBIENT TEMP SHOULD BE ABOVE 65 DEGREES AND THE HUMIDITY SHOULD BE ABOVE 50 %.
Mar 26, 2008 | Kenmore 53301 Dehumidifier
Starter keep trying to start when cook top is off.
If you have recently cleaned unit and got moisture behind knobs, this may stop when the spark switches dry out. If not you will need to replace spark switches behind the knobs.
Nov 14, 2007 | GE 30 in. JGP337 Gas Cooktop
Garden Logo
65 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
