Question about Sylvania Televison & Video
I have a sylvania 32" flat screen TV with DVD built in don't have remote it is flashing different colors and power button to turn off and on don't work stays on so I have to unplug it
    Top Expert:
  • Sylvania Master
  • 75,311 Answers
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Apr 16, 2015
5 Suggested Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
  • 718 Answers
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
  • 5 Answers
SOURCE: 32" Sylvania TV/DVD won't work with my AT&T UVerse Remote
I bought a 32 inch sylvania LD320SSX TV/DVD and had trouble with a Media-Com remote. Finally got it to work using code 1864
Good Luck
Posted on Nov 30, 2009
Raditronic
  • 196 Answers
SOURCE: AKAI 32" Power Malfunction
check all 1000mf-16v & 470mf-16v in power supply. may be blow.
Posted on May 06, 2010
My flat screen Sylvania TV is flashing different colors what's wrong
Better late than never. The problem is that your TV is in the service mode. There are many ways this can happen. But, lets just get down to fixin this! With the original remote and the TV on. If the TV will not shut off, do this. Press the left cursor button on the remote, followed with pressing the right cursor. Power off the TV with remote, or press off button on TV.
Secondly, your TV will power on and off. But you have flashing colors. Do this. With the original remote and TV on. Press the up cursor button, on the remote, followed with pressing the down cursor. Power off TV with remote, or press off power of TV. Thanks for asking me, Matt of Martins TV Repair.
Jan 20, 2016 | Sylvania Televison & Video
How do I remove stuck DVD?
If this is a combo unit the first thing you have to do is remove that dvd from inside the player. Open up the unit and do the deed. THEN see what happens. Often when the player gets jammed or whatever, it will render the rest of the set useless until the hassle is removed. In this case get that disk outta there.
If still nothing disconnect the power line that feeds the dvd to see if that has any effect on overall tv operation.
Sep 05, 2015 | Sylvania Televison & Video
Color problem on tv
The TV remote control can recovery your color as you want
Jun 08, 2012 | Sylvania LD320SSX LCD TV
Flashing red,blue, green screen
last week i had an emerson 21 inch with built in dvd.,it was flashing colours.none of the front buttons would work.i unplugged the front buttons and plugged them back in again.set is working fine.ican not remember if i did it with the power on or off.try both.some how the front buttons were locking up the micro.
Nov 24, 2011 | Emerson LC320EM9 32 in. LCD HDTV
Sylvania tv not recognizing DVD player
Do one thing press the SCREEN MODE button on the remote repeatedly and check is there is any difference in the screen. If there is no difference then yu tv Have problem wit the T Con board, T con board is on which drives pixels the lcd screen. You can find the T con board of your tv in the following link.
Normally you can find the T con board inside the tv at the bottom center covered by metal cover or aluminum foil. Replacing this board will solve the problem.
http://www.ebay.com/itm/BUF320G04012-T-CON-SYLVANIA-LC320SS8-/140556173476
If you need any more assistance feel free to contact me through fixya
Ajin
Nov 23, 2011 | Sylvania LC320SS8 32 in. LCD Television
Sylvania LD320SSX 32-Inch 720p LCD HDTV/DVD Combo fails to turn on(power light flashes green, turns solid green 10-15 minutes then red). Leading up to this condition it would take several attempts to turn...
You checked for bad capacitors, but did you check for bad soldier joints?
I would start there. Also, be prepared to replace the Power Supply Board.
Aug 30, 2011 | Sylvania LD320SSX LCD TV
32 inch sylvania flashes red, blue, black, then white over and over and over, turns on automatically when plugged then goes through these series of colors. need help please
check the main power switch of the TV, then also check the control buttons on the front panel of the TV maybe one of the button s on the front panel is press (normally close state), or maybe the buttons is defective (maybe the menu button)
Jul 22, 2011 | Sylvania LC320SSX 32 in. LCD TV
I have a lc320slx sylvania tv and I pushed some button, but now it keeps flashing different colors on the screen. It flashes red, green, blue, white, etc. The remote won't control the tv and the only way...
This problems will not be solved by a remote control.Ur tv Tuner board is dead.Take it to the shop they will order a refurbish the Main Tuner signal board for u and replaced it.It will cost about half the price of the new tv.
Apr 28, 2010 | Sylvania LC320SLX 32 in. LCD TV
Comcast Universal Remote code for Sylvania LC370SL8
10030 or 10054
  1. Turn on your device (i.e. TV).
  2. PRESS the button for the device you want to program (TV, VCR, CABLE, AUD, etc.) then RELEASE.
  3. PRESS and HOLD the SETUP button until the red LED for the selected device flashes twice, then RELEASE.
  4. ENTER the 5 digit code for your brand from the list above.
  5. You should receive 2 quick flashes on the LED for the selected device after entering your code.
  6. PRESS the POWER button to test the code. (On VCR,LD,and CD players use PLAY)
Dec 04, 2008 | Sylvania LC320SS8 32 in. LCD Television
Televison & Video Logo
70 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
