Question about Whirlpool Washing Machines
WHIRLPOOL WASHING MACHINE WILL NOT SPIN SEE ADDITIONAL DETAILS
WHIRLPOOL WASHER MODEL NUMBER GSX9885JQ0 GOLD CATALYST MODEL DIGITAL IS MAKING A WHIRRING ROARING NOISE AND NOT SPINNING. WILLING TO PAY AN EXPERIENCED TECH TO DIAGNOSE THE PROBLEM. I HAVE RESEARCHED THE ANSWERS MYSELF, BUT I HAVE ALWAYS HAD SUCCESS PAYING TECHS ON FIXYA OVER THE YEARS. SO IS IT A TRANS, CLUTCH ASSY. OR SOMETHING ELSE? I AM AUTO MECHANIC MYSELF AND WOULD LIKE TO DISCUSS THIS REPAIR WITH A WASHER TECH WHO HAS REPAIRED THIS PROBLEM BEFORE. THANKS
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
Sounds like your gear casing is broken inside, motor is spinning but transmission shaft where agitator sits on, is not spinning.
Posted on Apr 17, 2015
docjohn174
  • 943 Answers
SOURCE: Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Posted on Oct 14, 2008
  • 130 Answers
SOURCE: Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Posted on Feb 16, 2009
  • 38 Answers
SOURCE: kenmore frontloader washing machine making roaring
Your rear bearing is bad. Check warranty to see if rear tub is still covered.
Posted on Mar 08, 2009
garing
  • 998 Answers
SOURCE: Hoover Washing machine wont spin
look at the belt and thumbs up
Posted on Aug 09, 2009
  • 291 Answers
SOURCE: washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Posted on Feb 16, 2010
Washer making whining noise wash cycle
see this steps and fix it. God bless you
Tub Bearing
If the washer is making a loud noise the tub bearing might be worn out, this is a common problem. The bearing can be replaced. On some models the bearing is part of the outer tub and the outer tub will need to be replaced.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is making a loud noise the tub seal and bearing kit may need to be replaced. This is a common problem. sometimes the tub seal and bearing are part of the outer tub and the outer tub would then need to be replaced.
Rear Drum with Bearing
If the washer is making a loud noise the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, the problem is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Bearing
If the washer is making a loud noise the bearing might be worn out. As bearings wear out from friction they gradually get worse and worse until they fail. In the meantime they get louder. If the noise primarily happens during the spin cycle the bearing is likely the problem.
Drive Pulley
If the washer is making a loud noise the drive pulley might be worn out, cracked, loose or bent. Remove the drive pulley and inspect it carefully. If it is damaged or defective replace it.
Pulley
If the washer is making a loud noise the drive pulley may be worn out. If the drive pulley is loose or wobbling it will need to be replaced
U-Joint Kit
If the washer is making a loud noise the U-Joint may have failed. This is the primary drive mechanism for the agitation motion in this washer. Although this is not a very difficult repair for a DIY'er with some experience, the part is expensive and so it may be worth considering a new washer.
Motor Coupling
If the washer is making a loud noise the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Clutch
If the washer is making a loud noise in the spin cycle, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may become loud during spin or just after the spin cycle finishes. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Drive Belt
If the washer is making a loud noise the drive belt might be defective. Over time the drive belt will dry out and start cracking, eventually a piece of the belt can break off resulting in a loud noise whenever the motor is running.
Transmission
If the washer is making a loud noise the transmission might be worn out or defective. There are many other more likely causes for noise from a washer. If the noise turns out to be caused by the transmission it may have to be replaced.
Drain Pump
If the washer is making a loud noise the drain pump might be going bad or might have something caught in it. Remove the drain pump from the washer and inspect it carefully. Look for anything that might be caught in it, a piece of wire, plastic, etc. If nothing is wrong with the pump, but it's still noisy it will have to be replaced.
Drive Motor
If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced.
Water Inlet Valve
If the washer is noisy or loud, particularly when the washer is filling, the water inlet valve is at fault and will need to be replaced.
Jul 20, 2013 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a gold catalyst gsx9885jq0. It has a code reading, F3. It won't do anything.
If I recall correctly, your F3 code has to do with the lid switch. You may need to replace it. Here is a link to the part you need.
http://www.appliancepartspros.com/part_details.aspx?part_id=3020600
Nov 21, 2010 | Whirlpool GSX9885J Top Load Washer
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
Bill
May 22, 2010 | Kenmore Washing Machines
My whirlpool gold model gsx9885jq0 will not spin.
I was amazed at the excellent utube video on washing machine repair, I expect you will find your solution there. For your encouragement, it's not likely to be the timer.
Nov 20, 2009 | Washing Machines
Feb 15, 2009 | Whirlpool Washing Machines
Agitator will not circulate the water during wash cycle
i bet you just need the agit-dogs but send me the complete model number from under the lid and i will see about helping you / larryyb
Nov 28, 2008 | Whirlpool GSC9455 Top Load Washer
Washer won't start to agitate or drain the water
this could be caused by a bad motor.
  • but i would first check the wire harness that goes to the motor and make sure it has not worked loose.
  • you should be able to see it from under the machine.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 01, 2008 | Washing Machines
Washing Machines Logo
123 people viewed this question
Dan Webster
Dan Webster
Sal De
