Question about Chevrolet 2010 HHR Engine/Motor g62324050h 2.2L VIN B, 8th digit, opt LE8 Savannah, Georgia
WHERE IS THE CAMSHAFT SENSOR LOCATOR NEAR? - Chevrolet 2010 HHR Engine/Motor g62324050h 2.2L VIN B, 8th digit, opt LE8 Savannah, Georgia
savdragon
  • 37 Answers
SOURCE: locate camshaft sensor 2002 chevy trailblazer
Assuming you have a 4.2L engine here is the location.
Hope this helps out,
if so please rate my answers.
Brett
Posted on Mar 19, 2009
emissionwiz
  • 76164 Answers
SOURCE: camshaft position sensor location
At the right rear of the engine under the intake manifold and to the left of the oil filter. You will probably need to go under the car to spot it, it's the sensor with a three-wire connector arranged vertically. But you can take it out from above. It's held in with a single bolt with an eight MM head located just above the sensor. Un-clip and remove the electrical connector. Unscrew the bolt with a socket wrench & extension bar. Wiggle and pull the sensor out.
here is a picture.
Posted on Apr 10, 2009
  • 462 Answers
SOURCE: 99 suburban 5.7 1500 location of camshaft sensor
It's in the distributor. There is 2 connectors on the outside of the distributor to it. Make sure they are both connected before replacing parts. The gear on the distributor wears out too.
Posted on Sep 12, 2009
  • 110 Answers
SOURCE: where is the camshaft position sensor located
inside distributor
Posted on May 10, 2010
airjer995
  • 5332 Answers
As your standing in fron of the car. the exhaust cam sensor will be on the passenger side right below the valve cover kind of tucked in were the water pipe and the power steering pump are. The intake cam sensor is on the drivers side of the front of the engine just below the valve cover and kind of right behind where the serp belt comes across that area.
Posted on Dec 15, 2012
Where is the camshaft position sensor located in a
The camshaft position sensor is located on top of the engine near the ignition coils.
The camshaft position sensor is located on the engine near the timing belt cover and under the upper radiator hose.
The camshaft position sensor is either located near the top of the engine, passenger-s side, or on the right side of the engine near the ignition coils.
The camshaft position sensor is located on the engine near the camshaft pulley.
This sensor is located at the front of the engine near the camshaft gear this is what I got 6 different locations manual covers 99-05
Oct 10, 2014 | Cars & Trucks
Where is bank 1 o2 sensor kia optima 4 cylinder
This car have a Crankshaft and camshaft sensor the crankshaft sensor is loceted in near the pulley crankshaft and the camshaft sensor is located in the camshaft cover behind the radiator. good loock
Jul 08, 2014 | 2004 Kia Optima
Location of camshaft position sensor on 2009 saturn aura
2.4L cmp sensor exhaust located upper rear of the engine near camshaft cover. 2.4L cmp sensor intake located upper front of the engine near the camshaft cover. the 3.5L cmp sensor located right side of engine compartment above the timing chain cover.below power steering pump.3.6L cmp sensor located right side of the engine near the front and rear.
Sep 26, 2013 | Cars & Trucks
2004 escape where is the crank position sensor located?
We would recommend taking a look at the front of your motor, by either of the camshafts and where they exit the head(s). The sensor is either a optical or hall effect sensor, so try and find a housing that is near or around your intake or exhaust camshaft ( or just single camshaft) for the location of your camshaft position sensor
Jan 27, 2010 | 2003 Ford Escape
Where is cam sensor on Volvo V40 (exact location)
Take a look at the front of your motor, The sensor is either a optical or hall effect sensor, so try and find a housing that is near or around your intake or exhaust camshaft or just single camshaft for the location of your camshaft position senso.
Sep 03, 2009 | 2003 Volvo V40
Where is the cam a sensor located in a 2004 hyundai santa fe
On the 2.4L and 2.7L engines, the camshaft position sensor is located on top of the engine near the ignition coils. On the 3.5L engine, the sensor is located at the front of the engine near the camshaft gear.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jul 03, 2009 | 2004 Hyundai Santa Fe
Where crank shaft and camshaft?
The camshaft position sensor is located on the timing cover, near the top of the motor. The crankshaft position sensor is located on the same timing cover near the crankshaft. Just a side note, more than likely the crankshaft position is your issue and it's under a recall from Nissan and they will replace it for free.
May 23, 2009 | 2002 Nissan Altima
Where is located the camshaft sensor on a dodge sx 2.0 2003?
camshaft sensor located on end of cylinder head near battery..remove battery..4 bolts and wire connector..clean mounting surface and install new sensor
Mar 14, 2009 | 2003 Dodge Neon
Camshaft position sensor
The camshaft position sensor is usually located on the cylinder head near the camshaft. It may be under the timing cover. It has a small plug and the sensor is where the plug is plugged on.
Jan 23, 2009 | 2003 Mitsubishi Lancer
Chevrolet 2010 HHR Engine/Motor g62324050h 2.2L VIN B, 8th digit, opt LE8 Savannah, Georgia Logo
477 people viewed this question
Top Chevrolet Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Chevrolet Craft and Hobby Expert? Answer questions, earn points and help others
