Question about One Touch Cell Phones
What is the magnet placement inside the one touch pop7 p310a There are 5 of them, we're do they go.
  • One Touch Master
  • 20,318 Answers
See if this helps although different model.
Alcatel One Touch Scribe HD disassembly
Posted on Dec 22, 2015
I have a a alcatel one touch I cannot hear a ring tone when i make a call How do i rectify thanks
I used to have Alcatel One Touch Pop7. I'd recommend you to check Sound in settings of the phone. Maybe it is in "silent' mode?
Apr 24, 2017 | Alcatel Cell Phones
Tip
Nady RSM-5 Review and Modification
Want an inexpensive ribbon microphone with a Royer-like feature? The Nady RSM-5 has a ribbon motor similar to a Royer R121 but needs some help to live up to its potential.
In the RSM-5s I've seen, the ribbon material is thicker than specified and causes sub-optimal performance. This mic is spec'd as having a 2 micron ribbon but upon inspection I found the ribbon to be made from the same heavier 6 micron material used in the RSM-4.
And, about 30%-50% of the hundred or so Chinese-manufactured ribbon mics I've seen have come from the overseas manufacturer with improperly tensioned ribbons - often with 80% of the ribbon length sagging out of the magnetic gap.
So the first step to get an RSM-5 to be a top-shelf performer is to replace the stock ribbon with a lighter and more responsive 1.8 micron ribbon.
The ribbon motor used in this mic mimics the patented Royer technique of offset ribbon placement in the magnetic gap. In the Royer mics, the ribbon is placed closer to the front of the magnetic ribbon gap. This allows the ribbon to move further into the gap at high SPL and still remain in the magnetic field.
To avoid an obvious patent infringement, the RSM-5 has the ribbon located asymmetrically toward the back of the mic when it is addressed from the front! Simply use the back side of the RSM-5 and you'll get the same "offset ribbon / high SPL" benefit offered by the front side of a Royer ribbon. The offset ribbon placement has the additional benefit of providing different front and back frequency response curves - almost like two mics in one.
While asymmetrical ribbon placement is not ideal for M-S or Blumlein usage were a symmetrical figure 8 pattern is desired, the offset does offer the advantage of slightly different response between front and back.
Ribbon mics are simple devices, but a big part of their sound is the output transformer. Installation of a premium Lundahl ribbon microphone transformer will reduce midrange ringing distortion and really extend the low end of the RSM-5.
Once modified, this medium length 35mm ribbon mic offers a musically useful low frequency resonance without accentuating unwanted LF rumble. Plus the high frequency response sounds like a high quality ribbon mic should - righteous.
on Oct 31, 2007 | Nady Systems RSM-5 Professional Microphone
Ihave a p310a tablet and its saying im low on storage but i cant be as i have very few pics on it and only a couple of apps, why?
It has 8GB of storage of which about 2 Gb will be the operating system. All your images are 2Mb. It you have WhatsApp or Text SMS service and people sent you images, they are stored within those apps.
There are massages about storage and one says it is caused by Facebook when using it. There are a few suggested fixes.
p310a tablet Google Search
Sometimes you just have to bite the bullet and buy an iPad :>)
Dec 14, 2016 | Tablets & eReaders
How to pair Bluetooth speaker to one touch pop7 tablet?
If a Android OS you find the gear/setup, bluetooth and then tell it to scan. You need to make sure you turn the BT speaker on. The brand of speaker should popup on the tablet. Select it to pair.
Oct 18, 2015 | Tablets & eReaders
Where does the magnet go on a model number ltf2940es
Good Morning Annie, thank you for your post!
Generally speaking, the magnet is located in the dispenser drawer. Double check the drawer and if it is closed, remove the drawer and examine the placement of the magnet and reinstall. If the magnet is missing or defective, the magnet probably needs replacing. However, if the magnet is in good condition and in place, an experienced technician may need to examine the reed switch or main control board.
Nov 12, 2013 | Frigidaire ATF6000ES Front Load Washer
Where is the correct spot to put the magnet on the spoke for the v12 mini
The only placement requirement for the magnet is that it pass exactly next to the sending unit you mount on the fork (there is usually a mark on the unit). So, really the placement of the sending unit determines the "correct" placement of the magnet on the spoke.
May 09, 2010 | Topeak Panoram V12 Mini 12 Function Cycle...
What is best Sirius antenna placement on C5 Corvette?
You could actually bury the antenna in the roof header if the roof is all fiberglass, as it won't block the signal as much as a metal roof will. You could leave a piece of sheet metal stuck to the magnet antenna, but I would bury it INSIDE the car with a chunk of metal under it. Should work pretty decet that way, especially if your city has terrestrial repeaters.
Nov 28, 2009 | Sirius Satellite Radio Receiver
Cell Phones Logo
337 people viewed this question
Top One Touch Cell Phones Experts
john smith
Lawrence Oravetz
Are you an One Touch Cell Phone Expert? Answer questions, earn points and help others
