Question about John Deere Garden
I have a john Deere 445 garden tractor with a coolant leak up by water pump. Would this just be a gasket or does it have a weap hole
  • John Deere Master
  • 1,920 Answers
Check hoses before you tear anything apart. The water pump could be bad as I don't think there should be any moisture around anything. Bad hose will leak some times where they fasten on the pump or could just need to be tightened.
Good luck.
Posted on Apr 15, 2015
2 Suggested Answers
nova2nv
  • 197 Answers
SOURCE: John Deere 445 lawn tractor is leaking coolant
This model has a weap hole just under water pump.If it leaks enough it will stain front cover just to the side of crankshaft.Do not buy the rebuild kit,just replace pump.
Posted on Nov 14, 2009
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
My 1995 6200 John Deere is running hotter than normal. Done coolant flush. Blown out aircleaner, washed out radiator fins. Whats next?
IF YOU ARE NOT HAVING WATER BLOWING OUT WHEN YOU START IT IT PROBLEY NOT HEAD GASKET I WOULD LOOK AT WATER PUMP THE IMPALER COULD BE BAD IN THE WATER PUMP
Nov 10, 2012 | John Deere 6300,6300l,6400,6400l Tractor...
John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Apr 18, 2010 | John Deere 420,1020,2010,2020,2510,2520...
How can I tell the year of my John Deere 445 lawn tractor. Product # M00445C096237 ?
1993: 010001
1994: 020001
1995: 030001
1996: 040001
1997: 050001
1998: 060001
1999: 070001
2000: 080001
2001: 090001
http://www.tractordata.com/lawn-tractors/000/0/4/45-john-deere-445.html
Mar 10, 2010 | Garden
John deere 445 with 22 hp kawasoki engine wont run take 1 plug out it runs dont mater what side stick finger in plug hole engine shuts off ,but wont start with both plugs in
Remove fuel cap to see if there is alot of fuel spraying back into tank.I have replaced ALOT of fuel pump hoses that have split between pump and sender clamp inside of tank.Lack of fuel pressure creates a very lean condition with the injected models.
Sep 03, 2009 | John Deere Garden
Apr 18, 2009 | Garden
Garden Logo
213 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
